Searching in forum
Is please possible to disable stealing of ctrl-f keyboard shortcut from firefox browser by forum? Its a bit annoying when you press it, and forum search is displayed. And forum search has limitation for minimum of characters which must be entered to start searching. This limitation does not apply for searching on page from firefox :slight_smile: thank you :slight_smile:
If I press it twice, I got browser search (at least in chrome).
But there is another BIG issue. Because if there are many posts, they are loaded asynchronously, when you move to the bottom of the page. It woudn’t be a problem, I could firstly scroll totally down to load all comments and than search, but when I scroll down, forum hides previous comments. And that is the problem. If they are hidden, search doesn’t work on them.
