Zdravim,
nevíte někdo jak se zbavit importovnaného snapshotu? U jeho čísla se objeví zavináč a nemůžu se ho pak uz nikdy nějak zbavit z toho seznamu a kvůli tomu, snapsoty nemůžy synchronizovat na NAS.
root@turris:~# schnapps list
# | Type | Size | Date | Description
@1 | single | | 2020-12-01 10:27:41 +0100 | User created snapshot
@7 | single | | 2020-12-01 10:27:41 +0100 | User created snapshot
3 | single | 1.85MiB | 2020-12-02 16:22:45 +0100 | log-spam-fix
4 | single | 9.88MiB | 2020-12-02 16:37:41 +0100 | restored new conf fixed
5 | single | 224.00KiB | 2020-12-02 16:54:29 +0100 | base-2020-12-02
6 | rollback | 273.56MiB | 2020-12-02 17:20:19 +0100 | Rollback to snapshot 5
root@turris:~# schnapps delete 7
Snapshot 7 deleted.
root@turris:~# schnapps delete 1 7
WARNING: Snapshot number 1 does not exists!
WARNING: Snapshot number 7 does not exists!
root@turris:~# schnapps sync
mount.davfs: the server certificate does not match the server name
mount.davfs: the server certificate is not trusted
issuer: Synology Inc., Taipei, TW
subject: Synology Inc., Taipei, TW
identity: synology.com
fingerprint: b3:99:93:1e:25:40:b0:b1:2d:d5:10:3c:b1:45:a6:47:b0:9c:0a:08
You only should accept this certificate, if you can
verify the fingerprint! The server might be faked
or there might be a man-in-the-middle-attack.
Accept certificate for this session? [y,N] y
/usr/bin/schnapps: .: line 669: can't open '/mnt/.snapshots//mnt/.snapshots/@1.info.info': No such file or directory
nějaký nápad co s tím abych rozběhal ten sync? Manuální upload funguje, ale to je na prd.
