after I switched my storage to SSD (This topic) , now I got a problem with the schnapps snapshots.
Every week schnapps - triggerd by the cronjob - deletes the last snapshot, even the schnapps config is set to option max_single '-1'.
root@FW:/# schnapps list
# | Type | Size | Date | Description
6 | time | 7.92MiB | 2023-12-03 01:05:02 +0100 | Snapshot created by cron
This are the config of my Turris, which seams to be default settings:
The syslog tells that previous snapshot got deleted:
Dec 3 00:05:01 FW crond[23308]: (root) CMD (schnapps create -t time "Snapshot created by cron")
Dec 3 00:05:02 FW crond[23305]: (root) CMDOUT (There is no message to send.)
Dec 3 00:05:02 FW crond[23305]: (root) CMDEND (/usr/bin/notifier)
Dec 3 00:05:02 FW crond[23306]: (root) CMDOUT (Snapshot number 6 created)
Dec 3 00:05:02 FW crond[23306]: (root) CMDEND (schnapps create -t time "Snapshot created by cron")
Dec 3 01:05:01 FW crond[29413]: (root) CMD (schnapps cleanup --compare)
Dec 3 01:05:01 FW crond[29410]: (root) CMDOUT (There is no message to send.)
Dec 3 01:05:01 FW crond[29411]: (root) CMDOUT (Searching for snapshots without any change.)
Dec 3 01:05:01 FW crond[29411]: (root) CMDOUT (This can take a while, please be patient.)
Dec 3 01:05:01 FW crond[29411]: (root) CMDOUT ()
Dec 3 01:05:01 FW crond[29410]: (root) CMDEND (/usr/bin/notifier)
Dec 3 01:05:01 FW crond[29411]: (root) CMDOUT ( * checking snaphot 6...)
Dec 3 01:05:20 FW crond[29411]: (root) CMDOUT ( - Snapshot 5 deleted.)
Dec 3 01:05:20 FW crond[29411]: (root) CMDOUT (Looking for old snapshots...)
Dec 3 01:05:20 FW crond[29411]: (root) CMDEND (schnapps cleanup --compare)
After the storage switch to SSD I created the first snapshot manually:
1 | single | 16.00KiB | 2023-11-01 11:03:47 +0100 | Clean-Default-Post-Uboot-Update-Setup-20231101
I’m wondering why schnapps deletes the snapshots?
Is there something I miss?
Hi, I tried to create multiple single (manual) snapshots and then to run schnapps delete --compare and it worked as expected. If a snapshot didn’t contain any change, the previous one was deleted if favor the newer one. If any changes were there the previous snapshot wasn’t deleted.
Your snapshot 5 was deleted probably due to absence of any changes in 6. The max_single option has no effect in this case. But the information provided by schnapps help (or schnapps) is misleading and should be changed - schnapps deletes older snapshots in such cases. I’ll create an issue or a patch for this.
Hi Lukáš,
that seems logical. Since the switch to SSD and the manually snapshot I haven’t changed anything at config level. So it is likely that there was no changes between.
I done the same test like you and all the previous snaphots got deleted:
root@FW:~# schnapps list
6 | time | 7.97MiB | 2023-12-03 01:05:02 +0100 | Snapshot created by cron
7 | single | 7.97MiB | 2023-12-06 11:30:18 +0100 | Snapshot-Backup-Custom-20231206
8 | single | 16.00KiB | 2023-12-06 11:34:06 +0100 | Snapshot-Backup-Custom-20231206-2
root@FW:~# schnapps cleanup --compare
* checking snaphot 7...
- Snapshot 6 deleted.
* checking snaphot 8...
- Snapshot 7 deleted.
8 | single | 7.92MiB | 2023-12-06 11:34:06 +0100 | Snapshot-Backup-Custom-20231206-2
In case of time snapshots. This option max_time '5' get triggered only, when there are differences between the snapshots?
I wonder, because I remember - before the switch to SSD - snapshots created by cron wasn’t deleted every week. Even there was no config changes or updates made. Sometimes there where 3-4 weekly time snapshots in a row. I haven’t saved any screenshot or console output of this to show, but I deleted such snapshot frequently.
Yes, regardless of snapshot types, these limits apply only when there are differences.
I don’t know whether the switch can change the behavior. It surely doesn’t affect the schnapps itself but may affect the files that are snapshotted.
