I have mPCI SATA ASM1061 2 ports controller attached to the 1st mPCI slot (from the left). When I reboot the router, the controller is not available. But when I halt the router, unplug it from the power, wait cca 20s and power it up, it works.
I have TurrisOS 5, but it didn’t work even with with TurrisOS 3, 4. The upgrade to Turris OS 5 was with rollback to the clean facory reset with Turris OS 5. The disk is powered from the internal router header (in the top right corner, only 5V and GND). I have also connected the “original” Wi-Fi 2.5/5Ghz card in the 2nd mPCI slot.
Does anyone know what is wrong please?
Dmesg after boot when controller is NOT available:
Booting Linux on physical CPU 0x0
Linux version 4.14.264 (packaging@turris.cz) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11397+89-524cbcf6f5)) #0 SMP Tue Feb 8 00:42:25 2022
CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: Turris Omnia
Memory policy: Data cache writealloc
On node 0 totalpages: 524288
free_area_init_node: node 0, pgdat c0b3c7c0, node_mem_map eedf9000
Normal zone: 1728 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 196608 pages, LIFO batch:31
HighMem zone: 327680 pages, LIFO batch:31
random: get_random_bytes called from start_kernel+0x8c/0x4cc with crng_init=0
percpu: Embedded 11 pages/cpu s15372 r8192 d21492 u45056
pcpu-alloc: s15372 r8192 d21492 u45056 alloc=11*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists, mobility grouping on. Total pages: 522560
Kernel command line: earlyprintk console=ttyS0,115200 rootfstype=btrfs rootdelay=2 root=b301 rootflags=subvol=@,commit=5 rw cfg80211.freg=**
Bootloader command line not present
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 2066960K/2097152K available (7168K kernel code, 244K rwdata, 1696K rodata, 1024K init, 260K bss, 30192K reserved, 0K cma-reserved, 1310720K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0800000 (8160 kB)
.init : 0xc0a00000 - 0xc0b00000 (1024 kB)
.data : 0xc0b00000 - 0xc0b3d0c0 ( 245 kB)
.bss : 0xc0b3d0c0 - 0xc0b7e3d0 ( 261 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
L2C: DT/platform modifies aux control register: 0x06070000 -> 0x16070000
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 D prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
Switching to timer-based delay loop, resolution 1ns
Ignoring duplicate/late registration of read_current_timer delay
clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: Spectre v2: using BPIALL workaround
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x100000 - 0x100060
mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
mvebu-pmsu: Initializing Power Management Service Unit
Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
Booting CPU 1
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU1: Spectre v2: using BPIALL workaround
smp: Brought up 1 node, 2 CPUs
SMP: Total of 2 processors activated (3200.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
xor: measuring software checksum speed
arm4regs : 2393.600 MB/sec
8regs : 1936.000 MB/sec
32regs : 2050.800 MB/sec
neon : 1837.200 MB/sec
xor: using function: arm4regs (2393.600 MB/sec)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
raid6: int32x1 gen() 171 MB/s
raid6: int32x1 xor() 243 MB/s
raid6: int32x2 gen() 255 MB/s
raid6: int32x2 xor() 288 MB/s
raid6: int32x4 gen() 305 MB/s
raid6: int32x4 xor() 263 MB/s
raid6: int32x8 gen() 328 MB/s
raid6: int32x8 xor() 229 MB/s
raid6: neonx1 gen() 1111 MB/s
raid6: neonx1 xor() 1058 MB/s
raid6: neonx2 gen() 1303 MB/s
raid6: neonx2 xor() 1351 MB/s
raid6: neonx4 gen() 1070 MB/s
raid6: neonx4 xor() 1328 MB/s
raid6: neonx8 gen() 1014 MB/s
raid6: neonx8 xor() 914 MB/s
raid6: using algorithm neonx2 gen() 1303 MB/s
raid6: .... xor() 1351 MB/s, rmw enabled
raid6: using neon recovery algorithm
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
clocksource: Switched to clocksource arm_global_timer
NET: Registered protocol family 2
IP idents hash table entries: 16384 (order: 5, 131072 bytes)
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
PCI: CLS 0 bytes, default 64
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Crashlog allocated RAM at address 0x3f00000
workingset: timestamp_bits=14 max_order=19 bucket_order=5
squashfs: version 4.0 (2009/01/31) Phillip Lougher
jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler bfq registered
armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x1000-0xfffff]
pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
pci_bus 0000:00: root bus resource [bus 00-ff]
pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
PCI: bus0: Fast back to back transfers disabled
pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
PCI: bus1: Fast back to back transfers enabled
pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
pci 0000:02:00.0: reg 0x10: [mem 0xe8000000-0xe81fffff 64bit]
pci 0000:02:00.0: reg 0x30: [mem 0xe8200000-0xe820ffff pref]
pci 0000:02:00.0: supports D1 D2
PCI: bus2: Fast back to back transfers disabled
pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
PCI: bus3: Fast back to back transfers enabled
pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
pci 0000:00:02.0: BAR 8: assigned [mem 0xe0000000-0xe02fffff]
pci 0000:00:01.0: PCI bridge to [bus 01]
pci 0000:02:00.0: BAR 0: assigned [mem 0xe0000000-0xe01fffff 64bit]
pci 0000:02:00.0: BAR 6: assigned [mem 0xe0200000-0xe020ffff pref]
pci 0000:00:02.0: PCI bridge to [bus 02]
pci 0000:00:02.0: bridge window [mem 0xe0000000-0xe02fffff]
pci 0000:00:03.0: PCI bridge to [bus 03]
mv_xor f1060800.xor: Marvell shared XOR driver
mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
mv_xor f1060900.xor: Marvell shared XOR driver
mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
console [ttyS0] disabled
f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22, base_baud = 15625000) is a 16550A
console [ttyS0] enabled
f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23, base_baud = 15625000) is a 16550A
loop: module loaded
ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
scsi host0: ahci-mvebu
scsi host1: ahci-mvebu
ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 44
ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 44
m25p80 spi0.0: s25fl164k (8192 Kbytes)
2 fixed-partitions partitions found on MTD device spi0.0
Creating 2 MTD partitions on "spi0.0":
0x000000000000-0x000000100000 : "U-Boot"
0x000000100000-0x000000800000 : "Rescue system"
mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
mvneta f1070000.ethernet eth0: Using hardware mac address d8:58:d7:00:5a:77
mvneta f1030000.ethernet eth1: Using hardware mac address d8:58:d7:00:5a:75
mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:00:5a:76
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ehci-platform: EHCI generic platform driver
ehci-orion: EHCI orion driver
orion-ehci f1058000.usb: EHCI Host Controller
orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
orion-ehci f1058000.usb: irq 40, io mem 0xf1058000
orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
xhci-hcd f10f0000.usb3: xHCI Host Controller
xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
hub 2-0:1.0: USB hub found
ata1: SATA link down (SStatus 0 SControl 300)
hub 2-0:1.0: 1 port detected
ata2: SATA link down (SStatus 0 SControl 300)
xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
xhci-hcd f10f8000.usb3: xHCI Host Controller
xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
armada38x-rtc f10a3800.rtc: registered as rtc0
i2c /dev entries driver
(NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
orion_wdt: Initial timeout 171 sec
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
sdhci-pltfm: SDHCI platform and OF driver helper
marvell-cesa f1090000.crypto: CESA device successfully registered
NET: Registered protocol family 10
Segment Routing with IPv6
NET: Registered protocol family 17
bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
8021q: 802.1Q VLAN Support v1.8
Registering SWP/SWPB emulation handler
Btrfs loaded, crc32c=crc32c-generic
usb 4-1: new high-speed USB device number 2 using xhci-hcd
mmc0: new high speed MMC card at address 0001
mmcblk0: mmc0:0001 H8G4a▒ 7.28 GiB
mmcblk0boot0: mmc0:0001 H8G4a▒ partition 1 4.00 MiB
mmcblk0boot1: mmc0:0001 H8G4a▒ partition 2 4.00 MiB
mmcblk0rpmb: mmc0:0001 H8G4a▒ partition 3 4.00 MiB, chardev (250:0)
mmcblk0: p1
DSA: switch 0 0 parsed
DSA: tree 0 parsed
hub 4-1:1.0: USB hub found
hub 4-1:1.0: 7 ports detected
usb 4-1.2: new full-speed USB device number 3 using xhci-hcd
mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540]
mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540]
mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540]
mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540]
mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540]
armada38x-rtc f10a3800.rtc: setting system clock to 2022-03-02 18:16:07 UTC (1646244967)
Waiting 2 sec before mounting root device...
F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
BTRFS: device fsid aa33c07f-dcc9-437c-814f-c826f1cad5e2 devid 1 transid 4014567 /dev/root
BTRFS info (device mmcblk0p1): disk space caching is enabled
BTRFS info (device mmcblk0p1): has skinny extents
BTRFS info (device mmcblk0p1): enabling ssd optimizations
VFS: Mounted root (btrfs filesystem) on device 0:12.
devtmpfs: mounted
Freeing unused kernel memory: 1024K
random: fast init done
init: Console is alive
init: - watchdog -
kmodloader: loading kernel modules from /etc/modules-boot.d/*
exFAT: Version 1.2.9
SGI XFS with ACLs, security attributes, no debug enabled
usbcore: registered new interface driver uas
kmodloader: done loading kernel modules from /etc/modules-boot.d/*
init: - preinit -
mount_root: mounting /dev/root
mount_root: loading kmods from internal overlay
kmodloader: loading kernel modules from //etc/modules-boot.d/*
kmodloader: done loading kernel modules from //etc/modules-boot.d/*
block: attempting to load /etc/config/fstab
block: extroot: not configured
random: procd: uninitialized urandom read (4 bytes read)
urandom-seed: Seeding with /etc/urandom.seed
procd: - early -
procd: - watchdog -
random: jshn: uninitialized urandom read (4 bytes read)
random: ubusd: uninitialized urandom read (4 bytes read)
procd: - watchdog -
procd: - ubus -
urandom_read: 5 callbacks suppressed
procd: - init -
kmodloader: loading kernel modules from /etc/modules.d/*
device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
Key type dns_resolver registered
Key type cifs.idmap registered
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
ntfs: driver 2.1.32 [Flags: R/O MODULE].
tun: Universal TUN/TAP device driver, 1.6
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
ip6_tables: (C) 2000-2006 Netfilter Core Team
Netfilter messages via NETLINK v0.30.
ip_set: protocol 6
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
i2c i2c-0: Added multiplexed i2c bus 3
i2c i2c-0: Added multiplexed i2c bus 4
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
i2c i2c-0: Added multiplexed i2c bus 7
pca953x 8-0071: 8-0071 supply vcc not found, using dummy regulator
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
Mirror/redirect action on
u32 classifier
input device check on
Actions configured
sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
random: crng init done
sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
fuse init (API version 7.26)
Bridge firewalling registered
Loading modules backported from Linux version v4.19.221-0-g5fd3cce374df
Backport generated by backports.git v4.19.221-1-0-g07fffc43
Ebtables v2.0 registered
ip_tables: (C) 2000-2006 Netfilter Core Team
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
ctnetlink v0.93: registering with nfnetlink.
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-cypress
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-karma
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver ums-usbat
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
wireguard: WireGuard 1.0.20200611 loaded. See www.wireguard.com for information.
wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
xt_time: kernel timezone is -0000
at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
usbcore: registered new interface driver ch341
usbserial: USB Serial support registered for ch341-uart
PPP generic driver version 2.4.2
NET: Registered protocol family 24
usbcore: registered new interface driver snd-usb-audio
pci 0000:00:02.0: enabling device (0140 -> 0142)
ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
ath10k_pci 0000:02:00.0: Falling back to user helper
firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-6.bin failed with error -2
firmware ath10k!QCA988X!hw2.0!firmware-6.bin: firmware_loading_store: map pages failed
ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
ath: EEPROM regdomain: 0x0
ath: EEPROM indicates default country code should be used
ath: doing EEPROM country->regdmn map search
ath: country maps to regdmn code: 0x3a
ath: Country alpha2 being used: US
ath: Regpair used: 0x3a
usbcore: registered new interface driver qcserial
usbserial: USB Serial support registered for Qualcomm USB modem
kmodloader: done loading kernel modules from /etc/modules.d/*
IPv6: ADDRCONF(NETDEV_UP): br-guest_turris: link is not ready
mvneta f1070000.ethernet eth0: configuring for fixed/rgmii link mode
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
mvneta f1070000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
br-guest_turris: port 1(lan4) entered blocking state
br-guest_turris: port 1(lan4) entered disabled state
device lan4 entered promiscuous mode
device eth0 entered promiscuous mode
IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
br-lan: port 1(lan0) entered blocking state
br-lan: port 1(lan0) entered disabled state
device lan0 entered promiscuous mode
device eth1 entered promiscuous mode
mv88e6085 f1072004.mdio-mii:10: p0: hw VLAN 1 already used by br-guest_turris
mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
br-lan: port 2(lan1) entered blocking state
br-lan: port 2(lan1) entered disabled state
device lan1 entered promiscuous mode
mv88e6085 f1072004.mdio-mii:10: p1: hw VLAN 1 already used by br-guest_turris
mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
br-lan: port 3(lan2) entered blocking state
br-lan: port 3(lan2) entered disabled state
device lan2 entered promiscuous mode
mv88e6085 f1072004.mdio-mii:10: p2: hw VLAN 1 already used by br-guest_turris
mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
br-lan: port 4(lan3) entered blocking state
br-lan: port 4(lan3) entered disabled state
device lan3 entered promiscuous mode
mv88e6085 f1072004.mdio-mii:10: p3: hw VLAN 1 already used by br-guest_turris
mvneta f1034000.ethernet eth2: PHY [f1072004.mdio-mii:01] driver [Marvell 88E1510]
mvneta f1034000.ethernet eth2: configuring for phy/sgmii link mode
IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
IPv6: ADDRCONF(NETDEV_UP): br-iot: link is not ready
ath: EEPROM regdomain: 0x80cb
ath: EEPROM indicates we should expect a country code
ath: country maps to regdmn code: 0x37
ath: Country alpha2 being used: CZ
ath: Regpair used: 0x37
ath: regdomain 0x80cb dynamically updated by user
mv88e6085 f1072004.mdio-mii:10 lan3: Link is Up - 100Mbps/Full - flow control rx/tx
mv88e6085 f1072004.mdio-mii:10 lan0: Link is Up - 10Mbps/Full - flow control rx/tx
mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
ath10k_pci 0000:02:00.0: pdev param 0 not supported by firmware
Dmesg after boot when controller is availabe:
Booting CPU 1
arm4regs : 2403.600 MB/sec
8regs : 1942.400 MB/sec
32regs : 2058.400 MB/sec
neon : 1830.400 MB/sec
xor: using function: arm4regs (2403.600 MB/sec)
pci 0000:03:00.0: [1b21:0612] type 00 class 0x010601
pci 0000:03:00.0: reg 0x10: [io 0xfffffff8-0xffffffff]
pci 0000:03:00.0: reg 0x14: [io 0xfffffffc-0xffffffff]
pci 0000:03:00.0: reg 0x18: [io 0xfffffff8-0xffffffff]
pci 0000:03:00.0: reg 0x1c: [io 0xfffffffc-0xffffffff]
pci 0000:03:00.0: reg 0x20: [io 0xffffffe0-0xffffffff]
pci 0000:03:00.0: reg 0x24: [mem 0xea000000-0xea0001ff]
pci 0000:03:00.0: reg 0x30: [mem 0xea010000-0xea01ffff pref]
PCI: bus3: Fast back to back transfers disabled
pci 0000:00:03.0: BAR 8: assigned [mem 0xe0300000-0xe03fffff]
pci 0000:00:03.0: BAR 7: assigned [io 0x10000-0x10fff]
pci 0000:03:00.0: BAR 6: assigned [mem 0xe0300000-0xe030ffff pref]
pci 0000:03:00.0: BAR 5: assigned [mem 0xe0310000-0xe03101ff]
pci 0000:03:00.0: BAR 4: assigned [io 0x10000-0x1001f]
pci 0000:03:00.0: BAR 0: assigned [io 0x10020-0x10027]
pci 0000:03:00.0: BAR 2: assigned [io 0x10028-0x1002f]
pci 0000:03:00.0: BAR 1: assigned [io 0x10030-0x10033]
pci 0000:03:00.0: BAR 3: assigned [io 0x10034-0x10037]
pci 0000:00:03.0: bridge window [io 0x10000-0x10fff]
pci 0000:00:03.0: bridge window [mem 0xe0300000-0xe03fffff]
loop: module loaded
ahci 0000:03:00.0: version 3.0
pci 0000:00:03.0: enabling device (0140 -> 0143)
ahci 0000:03:00.0: SSS flag set, parallel bus scan disabled
ahci 0000:03:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
ahci 0000:03:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
scsi host0: ahci
scsi host1: ahci
ata1: SATA max UDMA/133 abar m512@0xe0310000 port 0xe0310100 irq 52
ata2: SATA max UDMA/133 abar m512@0xe0310000 port 0xe0310180 irq 52
scsi host2: ahci-mvebu
scsi host3: ahci-mvebu
ata3: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 44
ata4: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 44
ata4: SATA link down (SStatus 0 SControl 300)
ata3: SATA link down (SStatus 0 SControl 300)
mmcblk0: p1
DSA: tree 0 parsed
ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata2.00: HPA detected: current 312573551, native 312581808
ata2.00: ATA-8: TOSHIBA MK1652GSX, LV010J, max UDMA/100
ata2.00: 312573551 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
ata2.00: configured for UDMA/100
scsi 1:0:0:0: Direct-Access ATA TOSHIBA MK1652GS 0J PQ: 0 ANSI: 5
sd 1:0:0:0: [sda] 312573551 512-byte logical blocks: (160 GB/149 GiB)
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sd 1:0:0:0: [sda] Attached SCSI disk
armada38x-rtc f10a3800.rtc: setting system clock to 2022-03-02 18:25:45 UTC (1646245545)
BTRFS: device fsid aa33c07f-dcc9-437c-814f-c826f1cad5e2 devid 1 transid 4014579 /dev/root
devtmpfs: mounted
init: - watchdog -
init: - preinit -
BTRFS: device label srv devid 1 transid 1971942 /dev/sda
procd: - early -
procd: - watchdog -
BTRFS info (device sda): disk space caching is enabled
BTRFS info (device sda): has skinny extents
procd: - watchdog -
procd: - ubus -
procd: - init -
BTRFS info (device sda): start tree-log replay
ip_set: protocol 6
u32 classifier
Actions configured
random: 6 urandom warning(s) missed due to ratelimiting
BTRFS info (device sda): checking UUID tree
lspci when controller is available:
00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04)
00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04)
00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04)
02:00.0 Network controller: Qualcomm Atheros QCA986x/988x 802.11ac Wireless Network Adapter
03:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
When is unavailable, the last line is missing.
