Samba crashes and doesn’t start when set to listen on the wireguard interface.
Log:
Nov 27 22:39:16 ares nmbd[16163]: [2021/11/27 23:39:16.068704, 0] ../../source3/nmbd/nmbd.c:59(terminate) Nov 27 22:39:16 ares nmbd[16163]: Got SIGTERM: going down... Nov 27 22:39:16 ares nmbd[26083]: [2021/11/27 23:39:16.155416, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:16 ares nmbd[26083]: WARNING: no network interfaces found Nov 27 22:39:16 ares nmbd[26083]: [2021/11/27 23:39:16.155603, 0] ../../lib/util/become_daemon.c:147(daemon_status) Nov 27 22:39:16 ares nmbd[26083]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ... Nov 27 22:39:16 ares nmbd[26083]: [2021/11/27 23:39:16.155684, 0] ../../source3/nmbd/nmbd_subnetdb.c:254(create_subnets) Nov 27 22:39:16 ares nmbd[26083]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6). Nov 27 22:39:16 ares smbd[26082]: [2021/11/27 23:39:16.204804, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:16 ares smbd[26082]: WARNING: no network interfaces found Nov 27 22:39:16 ares smbd[26082]: [2021/11/27 23:39:16.225642, 0] ../../lib/util/become_daemon.c:136(daemon_ready) Nov 27 22:39:16 ares smbd[26082]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections Nov 27 22:39:16 ares smbd[26082]: [2021/11/27 23:39:16.225871, 0] ../../source3/smbd/server.c:1241(open_sockets_smbd) Nov 27 22:39:16 ares smbd[26082]: open_sockets_smbd: No sockets available to bind to. Nov 27 22:39:16 ares smbd[26082]: [2021/11/27 23:39:16.226373, 0] ../../source3/lib/util.c:824(smb_panic_s3) Nov 27 22:39:16 ares smbd[26082]: PANIC (pid 26082): open_sockets_smbd() failed Nov 27 22:39:16 ares smbd[26082]: [2021/11/27 23:39:16.226466, 0] ../../lib/util/fault.c:277(log_stack_trace) Nov 27 22:39:16 ares smbd[26082]: unable to produce a stack trace on this platform Nov 27 22:39:16 ares smbd[26082]: [2021/11/27 23:39:16.226536, 0] ../../source3/lib/dumpcore.c:283(dump_core) Nov 27 22:39:16 ares smbd[26082]: Exiting on internal error (core file administratively disabled) Nov 27 22:39:21 ares nmbd[26083]: [2021/11/27 23:39:21.156407, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:21 ares nmbd[26083]: WARNING: no network interfaces found Nov 27 22:39:21 ares smbd[26103]: [2021/11/27 23:39:21.353790, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:21 ares smbd[26103]: WARNING: no network interfaces found Nov 27 22:39:21 ares smbd[26103]: [2021/11/27 23:39:21.378254, 0] ../../lib/util/become_daemon.c:136(daemon_ready) Nov 27 22:39:21 ares smbd[26103]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections Nov 27 22:39:21 ares smbd[26103]: [2021/11/27 23:39:21.379021, 0] ../../source3/smbd/server.c:1241(open_sockets_smbd) Nov 27 22:39:21 ares smbd[26103]: open_sockets_smbd: No sockets available to bind to. Nov 27 22:39:21 ares smbd[26103]: [2021/11/27 23:39:21.379874, 0] ../../source3/lib/util.c:824(smb_panic_s3) Nov 27 22:39:21 ares smbd[26103]: PANIC (pid 26103): open_sockets_smbd() failed Nov 27 22:39:21 ares smbd[26103]: [2021/11/27 23:39:21.380217, 0] ../../lib/util/fault.c:277(log_stack_trace) Nov 27 22:39:21 ares smbd[26103]: unable to produce a stack trace on this platform Nov 27 22:39:21 ares smbd[26103]: [2021/11/27 23:39:21.380914, 0] ../../source3/lib/dumpcore.c:283(dump_core) Nov 27 22:39:21 ares smbd[26103]: Exiting on internal error (core file administratively disabled) Nov 27 22:39:26 ares nmbd[26083]: [2021/11/27 23:39:26.157161, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:26 ares nmbd[26083]: WARNING: no network interfaces found Nov 27 22:39:26 ares smbd[26119]: [2021/11/27 23:39:26.512279, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:26 ares smbd[26119]: WARNING: no network interfaces found Nov 27 22:39:26 ares smbd[26119]: [2021/11/27 23:39:26.533113, 0] ../../lib/util/become_daemon.c:136(daemon_ready) Nov 27 22:39:26 ares smbd[26119]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections Nov 27 22:39:26 ares smbd[26119]: [2021/11/27 23:39:26.533282, 0] ../../source3/smbd/server.c:1241(open_sockets_smbd) Nov 27 22:39:26 ares smbd[26119]: open_sockets_smbd: No sockets available to bind to. Nov 27 22:39:26 ares smbd[26119]: [2021/11/27 23:39:26.533694, 0] ../../source3/lib/util.c:824(smb_panic_s3) Nov 27 22:39:26 ares smbd[26119]: PANIC (pid 26119): open_sockets_smbd() failed Nov 27 22:39:26 ares smbd[26119]: [2021/11/27 23:39:26.533778, 0] ../../lib/util/fault.c:277(log_stack_trace) Nov 27 22:39:26 ares smbd[26119]: unable to produce a stack trace on this platform Nov 27 22:39:26 ares smbd[26119]: [2021/11/27 23:39:26.533849, 0] ../../source3/lib/dumpcore.c:283(dump_core) Nov 27 22:39:26 ares smbd[26119]: Exiting on internal error (core file administratively disabled) Nov 27 22:39:31 ares nmbd[26083]: [2021/11/27 23:39:31.157918, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:31 ares nmbd[26083]: WARNING: no network interfaces found Nov 27 22:39:31 ares smbd[26129]: [2021/11/27 23:39:31.657835, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:31 ares smbd[26129]: WARNING: no network interfaces found Nov 27 22:39:31 ares smbd[26129]: [2021/11/27 23:39:31.679418, 0] ../../lib/util/become_daemon.c:136(daemon_ready) Nov 27 22:39:31 ares smbd[26129]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections Nov 27 22:39:31 ares smbd[26129]: [2021/11/27 23:39:31.680276, 0] ../../source3/smbd/server.c:1241(open_sockets_smbd) Nov 27 22:39:31 ares smbd[26129]: open_sockets_smbd: No sockets available to bind to. Nov 27 22:39:31 ares smbd[26129]: [2021/11/27 23:39:31.681178, 0] ../../source3/lib/util.c:824(smb_panic_s3) Nov 27 22:39:31 ares smbd[26129]: PANIC (pid 26129): open_sockets_smbd() failed Nov 27 22:39:31 ares smbd[26129]: [2021/11/27 23:39:31.681822, 0] ../../lib/util/fault.c:277(log_stack_trace) Nov 27 22:39:31 ares smbd[26129]: unable to produce a stack trace on this platform Nov 27 22:39:31 ares smbd[26129]: [2021/11/27 23:39:31.682401, 0] ../../source3/lib/dumpcore.c:283(dump_core) Nov 27 22:39:31 ares smbd[26129]: Exiting on internal error (core file administratively disabled) Nov 27 22:39:36 ares nmbd[26083]: [2021/11/27 23:39:36.158681, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:36 ares nmbd[26083]: WARNING: no network interfaces found Nov 27 22:39:36 ares smbd[26138]: [2021/11/27 23:39:36.811999, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:36 ares smbd[26138]: WARNING: no network interfaces found Nov 27 22:39:36 ares smbd[26138]: [2021/11/27 23:39:36.832631, 0] ../../lib/util/become_daemon.c:136(daemon_ready) Nov 27 22:39:36 ares smbd[26138]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections Nov 27 22:39:36 ares smbd[26138]: [2021/11/27 23:39:36.832800, 0] ../../source3/smbd/server.c:1241(open_sockets_smbd) Nov 27 22:39:36 ares smbd[26138]: open_sockets_smbd: No sockets available to bind to. Nov 27 22:39:36 ares smbd[26138]: [2021/11/27 23:39:36.833275, 0] ../../source3/lib/util.c:824(smb_panic_s3) Nov 27 22:39:36 ares smbd[26138]: PANIC (pid 26138): open_sockets_smbd() failed Nov 27 22:39:36 ares smbd[26138]: [2021/11/27 23:39:36.833365, 0] ../../lib/util/fault.c:277(log_stack_trace) Nov 27 22:39:36 ares smbd[26138]: unable to produce a stack trace on this platform Nov 27 22:39:36 ares smbd[26138]: [2021/11/27 23:39:36.833436, 0] ../../source3/lib/dumpcore.c:283(dump_core) Nov 27 22:39:36 ares smbd[26138]: Exiting on internal error (core file administratively disabled) Nov 27 22:39:41 ares nmbd[26083]: [2021/11/27 23:39:41.159438, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:41 ares nmbd[26083]: WARNING: no network interfaces found Nov 27 22:39:41 ares smbd[26147]: [2021/11/27 23:39:41.959000, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:41 ares smbd[26147]: WARNING: no network interfaces found Nov 27 22:39:41 ares smbd[26147]: [2021/11/27 23:39:41.980502, 0] ../../lib/util/become_daemon.c:136(daemon_ready) Nov 27 22:39:41 ares smbd[26147]: daemon_ready: daemon 'smbd' finished starting up and ready to serve connections Nov 27 22:39:41 ares smbd[26147]: [2021/11/27 23:39:41.980671, 0] ../../source3/smbd/server.c:1241(open_sockets_smbd) Nov 27 22:39:41 ares smbd[26147]: open_sockets_smbd: No sockets available to bind to. Nov 27 22:39:41 ares smbd[26147]: [2021/11/27 23:39:41.981137, 0] ../../source3/lib/util.c:824(smb_panic_s3) Nov 27 22:39:41 ares smbd[26147]: PANIC (pid 26147): open_sockets_smbd() failed Nov 27 22:39:41 ares smbd[26147]: [2021/11/27 23:39:41.981230, 0] ../../lib/util/fault.c:277(log_stack_trace) Nov 27 22:39:41 ares smbd[26147]: unable to produce a stack trace on this platform Nov 27 22:39:41 ares smbd[26147]: [2021/11/27 23:39:41.981301, 0] ../../source3/lib/dumpcore.c:283(dump_core) Nov 27 22:39:41 ares smbd[26147]: Exiting on internal error (core file administratively disabled) Nov 27 22:39:41 ares procd: Instance samba4::instance1 s in a crash loop 6 crashes, 0 seconds since last crash Nov 27 22:39:46 ares nmbd[26083]: [2021/11/27 23:39:46.160196, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:46 ares nmbd[26083]: WARNING: no network interfaces found Nov 27 22:39:51 ares nmbd[26083]: [2021/11/27 23:39:51.160953, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:51 ares nmbd[26083]: WARNING: no network interfaces found Nov 27 22:39:56 ares nmbd[26083]: [2021/11/27 23:39:56.161709, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:39:56 ares nmbd[26083]: WARNING: no network interfaces found Nov 27 22:40:01 ares nmbd[26083]: [2021/11/27 23:40:01.162455, 0] ../../source3/lib/interface.c:669(load_interfaces) Nov 27 22:40:01 ares nmbd[26083]: WARNING: no network interfaces found
