I have been using a router cascade with an openwrt based router behind a fritzbox which I must use for internet access.
Now I wanted to replace my old openwrt based router with the turris omnia and I am seeing weird problems.
I used to be able to access the configuration webpages of my fritzbox from a computer connected to the openwrt router. The fritzbox has the ip 192.168.178.1. The turris omnia has the ip 192.168.1.1 and my computer behind the turris has 192.168.1.50. When I ping the fritzbox (192.168.178.1) everything appears to be fine, but the http webpage of the fritbox configuration does not load. When I revert back to my other openwrt based router (which assigns the same ip to my computer) everything is fine. I have no idea why the webpage should not load if I can ping the fritzbox.
For ipv6 access I set my fritzbox up for prefix delegation and enabled dhcpv6. This used to work just fine with my old openwrt router. The turris omnia has been set to dhcp for ipv6 wan. An ip adress and dns server are assigned and everything appears to be fine, but computers behind the turris omnia can not reach any ipv6 host on the internet (network is unreachable).
The only guess is a firewall inside the FritzBox allowing admin access only from the external address of former router not from the address of Omnia.
This could mean the DHCPv6 PD pool was depleted on the FritzBox side. Check the status of Omnia using command ifstatus wan6. You should see the assigned prefix under the "ipv6-prefix" item.
I did check the status of the Omnia with the “ifstatus wan6” command. I can see that a \62 prefix has been assigned to the wan6 interface. All computers behind the Omnia receive ipv6 adresses. However, I can not reach any ipv6 host on the internet - I always get the error “network unreachable”.
The other problem (fritzbox configuration page not accessible) just vanished into thin air after a reboot of all devices.
Can you try tracerouting from the Omnia and from the computer behind omnia? It would determine which device is responsible for that. Have you done some special setup regarding to IPv6? There should be visible assignment to the lan interface in the output of ifstatus wan6 command, like this:
Unfortunately I only found an article in german. Sorry. So basically the problem is, that .box became an official top level domain, so the DNS resolver might be trying to resolve that address outside of your network. And you might wanna put the IP of the fritz box into the hosts file on the turris.
