I’m experiencing strange behavior when roaming between APs with openwrt or not(meraki AP) and my turris omnia router. By roaming I mean moving from one AP to another - it happens also when I disconnect and connect manually to the omnia router.
When I connect to the omnia router I have to wait more than 3minutes to have any connection - the only ip is working is the router ip. Everything else is not reachable. After 3 mins I’m allowed to access network without any issues, internet works.
I have DHCP disabled for both IPv4 and v6. When I connect to the omnia within the same network - the same ip address is assigned to me(DHCP server is OK), but I’m blocked until some timer expires.
I have two SSIDs - EAP Enterprise and WPA2 PSK and both are behave the same.
I have another openwrt linksys router and moving between APs is working fine, with identical settings.
Any ideas are appreciated.
