Ahoj, Turris mi bootuje do RO filesystemu. Nejsem uplne sbehly v techto vecech, je moznost otestovat tu kartu / filesystem primo na routeru, nebo ji musim vyhodit a otestovat nekde jinde?
Disk /dev/mmcblk0: 7.4 GiB, 7960788992 bytes, 15548416 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x38157d39
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 2048 206847 204800 100M 83 Linux
/dev/mmcblk0p2 206848 15548415 15341568 7.3G 83 Linux
root@turris:/tmp/log# mount
/dev/mmcblk0p2 on / type btrfs (ro,relatime,ssd,space_cache,commit=5,subvolid=257,subvol=/@)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
none on /sys/fs/cgroup type cgroup (rw,relatime,cpuset,cpu,cpuacct,blkio,memory,devices,freezer,net_cls,pids)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,relatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600,ptmxmode=000)
debugfs on /sys/kernel/debug type debugfs (rw,noatime)
mountd(pid6739) on /tmp/run/mountd type autofs (rw,relatime,fd=5,pgrp=6736,timeout=60,minproto=5,maxproto=5,indirect)
message log s errorem ktery zpusobuje ten RO.
2020-09-02 00:38:04 info kernel[]: [ 4.553368] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
2020-09-02 00:38:04 info kernel[]: [ 4.560372] ehci-platform: EHCI generic platform driver
2020-09-02 00:38:04 info kernel[]: [ 4.566199] ehci-fsl: Freescale EHCI Host controller driver
2020-09-02 00:38:04 info kernel[]: [ 4.571854] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
2020-09-02 00:38:04 info kernel[]: [ 4.578503] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
2020-09-02 00:38:04 info kernel[]: [ 4.585792] fsl-ehci fsl-ehci.0: irq 28, io mem 0xffe22000
2020-09-02 00:38:04 info kernel[]: [ 4.596997] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
2020-09-02 00:38:04 info kernel[]: [ 4.603018] hub 1-0:1.0: USB hub found
2020-09-02 00:38:04 info kernel[]: [ 4.606799] hub 1-0:1.0: 1 port detected
2020-09-02 00:38:04 debug kernel[]: [ 4.617128] libata version 3.00 loaded.
2020-09-02 00:38:04 info kernel[]: [ 4.620079] uhci_hcd: USB Universal Host Controller Interface driver
2020-09-02 00:38:04 info kernel[]: [ 4.912000] usb 1-1: new high-speed USB device number 2 using fsl-ehci
2020-09-02 00:38:04 info kernel[]: [ 5.032659] hub 1-1:1.0: USB hub found
2020-09-02 00:38:04 info kernel[]: [ 5.036555] hub 1-1:1.0: 2 ports detected
2020-09-02 00:38:04 info kernel[]: 5.062231] init: - preinit -
2020-09-02 00:38:04 notice kernel[]: [ 5.999724] random: mktemp: uninitialized urandom read (6 bytes read, 96 bits of entropy available)
2020-09-02 00:38:04 notice kernel[]: [ 6.010879] random: mktemp: uninitialized urandom read (6 bytes read, 96 bits of entropy available)
2020-09-02 00:38:04 notice kernel[]: [ 6.021915] random: mktemp: uninitialized urandom read (6 bytes read, 96 bits of entropy available)
2020-09-02 00:38:04 notice kernel[]: [ 9.058040] random: nonblocking pool is initialized
2020-09-02 00:38:04 err kernel[]: [ 13.067025] mmcblk0: error -110 transferring data, sector 5404544, nr 32, cmd response 0x900, card status 0x200b00
2020-09-02 00:38:04 warning kernel[]: [ 13.077424] mmcblk0: retrying using single block read
2020-09-02 00:38:04 err kernel[]: [ 14.089318] mmcblk0: error -110 transferring data, sector 5404544, nr 32, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 14.099250] blk_update_request: I/O error, dev mmcblk0, sector 5404544
2020-09-02 00:38:04 err kernel[]: [ 15.112621] mmcblk0: error -110 transferring data, sector 5404545, nr 31, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 15.122551] blk_update_request: I/O error, dev mmcblk0, sector 5404545
2020-09-02 00:38:04 err kernel[]: [ 16.135922] mmcblk0: error -110 transferring data, sector 5404546, nr 30, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 16.145853] blk_update_request: I/O error, dev mmcblk0, sector 5404546
2020-09-02 00:38:04 err kernel[]: [ 17.159223] mmcblk0: error -110 transferring data, sector 5404547, nr 29, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 17.169154] blk_update_request: I/O error, dev mmcblk0, sector 5404547
2020-09-02 00:38:04 err kernel[]: [ 18.182526] mmcblk0: error -110 transferring data, sector 5404548, nr 28, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 18.192456] blk_update_request: I/O error, dev mmcblk0, sector 5404548
2020-09-02 00:38:04 err kernel[]: [ 19.205826] mmcblk0: error -110 transferring data, sector 5404549, nr 27, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 19.215757] blk_update_request: I/O error, dev mmcblk0, sector 5404549
2020-09-02 00:38:04 err kernel[]: [ 20.229127] mmcblk0: error -110 transferring data, sector 5404550, nr 26, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 20.239059] blk_update_request: I/O error, dev mmcblk0, sector 5404550
2020-09-02 00:38:04 err kernel[]: [ 21.252428] mmcblk0: error -110 transferring data, sector 5404551, nr 25, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 21.262359] blk_update_request: I/O error, dev mmcblk0, sector 5404551
2020-09-02 00:38:04 err kernel[]: [ 22.275730] mmcblk0: error -110 transferring data, sector 5404552, nr 24, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 22.285661] blk_update_request: I/O error, dev mmcblk0, sector 5404552
2020-09-02 00:38:04 err kernel[]: [ 23.299031] mmcblk0: error -110 transferring data, sector 5404553, nr 23, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 23.308962] blk_update_request: I/O error, dev mmcblk0, sector 5404553
2020-09-02 00:38:04 err kernel[]: [ 24.322331] mmcblk0: error -110 transferring data, sector 5404554, nr 22, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 24.332262] blk_update_request: I/O error, dev mmcblk0, sector 5404554
2020-09-02 00:38:04 err kernel[]: [ 25.345632] mmcblk0: error -110 transferring data, sector 5404555, nr 21, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 25.355562] blk_update_request: I/O error, dev mmcblk0, sector 5404555
2020-09-02 00:38:04 err kernel[]: [ 26.368933] mmcblk0: error -110 transferring data, sector 5404556, nr 20, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 26.378864] blk_update_request: I/O error, dev mmcblk0, sector 5404556
2020-09-02 00:38:04 err kernel[]: [ 27.392235] mmcblk0: error -110 transferring data, sector 5404557, nr 19, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 27.402170] blk_update_request: I/O error, dev mmcblk0, sector 5404557
2020-09-02 00:38:04 err kernel[]: [ 28.415542] mmcblk0: error -110 transferring data, sector 5404558, nr 18, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 28.425473] blk_update_request: I/O error, dev mmcblk0, sector 5404558
2020-09-02 00:38:04 err kernel[]: [ 29.438844] mmcblk0: error -110 transferring data, sector 5404559, nr 17, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 29.448775] blk_update_request: I/O error, dev mmcblk0, sector 5404559
2020-09-02 00:38:04 err kernel[]: [ 30.462145] mmcblk0: error -110 transferring data, sector 5404560, nr 16, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 30.472075] blk_update_request: I/O error, dev mmcblk0, sector 5404560
2020-09-02 00:38:04 err kernel[]: [ 31.485445] mmcblk0: error -110 transferring data, sector 5404561, nr 15, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 31.495376] blk_update_request: I/O error, dev mmcblk0, sector 5404561
2020-09-02 00:38:04 err kernel[]: [ 32.508747] mmcblk0: error -110 transferring data, sector 5404562, nr 14, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 32.518678] blk_update_request: I/O error, dev mmcblk0, sector 5404562
2020-09-02 00:38:04 err kernel[]: [ 33.532048] mmcblk0: error -110 transferring data, sector 5404563, nr 13, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 33.541978] blk_update_request: I/O error, dev mmcblk0, sector 5404563
2020-09-02 00:38:04 err kernel[]: [ 34.555353] mmcblk0: error -110 transferring data, sector 5404564, nr 12, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 34.565284] blk_update_request: I/O error, dev mmcblk0, sector 5404564
2020-09-02 00:38:04 err kernel[]: [ 35.578654] mmcblk0: error -110 transferring data, sector 5404565, nr 11, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 35.588586] blk_update_request: I/O error, dev mmcblk0, sector 5404565
2020-09-02 00:38:04 err kernel[]: [ 36.601955] mmcblk0: error -110 transferring data, sector 5404566, nr 10, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 36.611886] blk_update_request: I/O error, dev mmcblk0, sector 5404566
2020-09-02 00:38:04 err kernel[]: [ 37.625257] mmcblk0: error -110 transferring data, sector 5404567, nr 9, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 37.635101] blk_update_request: I/O error, dev mmcblk0, sector 5404567
2020-09-02 00:38:04 err kernel[]: [ 38.648471] mmcblk0: error -110 transferring data, sector 5404568, nr 8, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 38.658315] blk_update_request: I/O error, dev mmcblk0, sector 5404568
2020-09-02 00:38:04 err kernel[]: [ 39.671685] mmcblk0: error -110 transferring data, sector 5404569, nr 7, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 39.681529] blk_update_request: I/O error, dev mmcblk0, sector 5404569
2020-09-02 00:38:04 err kernel[]: [ 40.694899] mmcblk0: error -110 transferring data, sector 5404570, nr 6, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 40.704743] blk_update_request: I/O error, dev mmcblk0, sector 5404570
2020-09-02 00:38:04 err kernel[]: [ 41.718112] mmcblk0: error -110 transferring data, sector 5404571, nr 5, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 41.727956] blk_update_request: I/O error, dev mmcblk0, sector 5404571
2020-09-02 00:38:04 err kernel[]: [ 42.741326] mmcblk0: error -110 transferring data, sector 5404572, nr 4, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 42.751171] blk_update_request: I/O error, dev mmcblk0, sector 5404572
2020-09-02 00:38:04 err kernel[]: [ 43.764540] mmcblk0: error -110 transferring data, sector 5404573, nr 3, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 43.774384] blk_update_request: I/O error, dev mmcblk0, sector 5404573
2020-09-02 00:38:04 err kernel[]: [ 44.787753] mmcblk0: error -110 transferring data, sector 5404574, nr 2, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 44.797597] blk_update_request: I/O error, dev mmcblk0, sector 5404574
2020-09-02 00:38:04 err kernel[]: [ 45.810968] mmcblk0: error -110 transferring data, sector 5404575, nr 1, cmd response 0x900, card status 0x0
2020-09-02 00:38:04 err kernel[]: [ 45.820812] blk_update_request: I/O error, dev mmcblk0, sector 5404575
2020-09-02 00:38:04 err kernel[]: [ 45.827351] BTRFS error (device mmcblk0p2): bdev /dev/root errs: wr 0, rd 76611, flush 0, corrupt 0, gen 0
2020-09-02 00:38:04 warning kernel[]: [ 45.837100] BTRFS warning (device mmcblk0p2): Skipping commit of aborted transaction.
2020-09-02 00:38:04 debug kernel[]: [ 45.844948] BTRFS: Transaction aborted (error -5)
2020-09-02 00:38:04 warning kernel[]: [ 45.845008] ------------[ cut here ]------------
2020-09-02 00:38:04 warning kernel[]: [ 45.849622] WARNING: at fs/btrfs/transaction.c:1840
2020-09-02 00:38:04 warning kernel[]: [ 45.854495] Modules linked in: leds_gpio xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ahci libahci libata ehci_fsl ehci_platform ehci_hcd sd_mod fsl_mph_dr_of uas usb_storage scsi_mod xfs libcrc32c reiserfs jfs f2fs ext4 jbd2 mbcache exfat button_hotplug input_core usbcore usb_common mii aead crypto_null
2020-09-02 00:38:04 warning kernel[]: [ 45.881199] CPU: 0 PID: 1057 Comm: btrfs-transacti Not tainted 4.4.199-f90a52a6230ecb072f657fce5aebd444-0 #1
2020-09-02 00:38:04 warning kernel[]: [ 45.891030] task: da9e3960 ti: de4a2000 task.ti: de4a2000
2020-09-02 00:38:04 warning kernel[]: [ 45.896427] NIP: c01f11d4 LR: c01f11d4 CTR: 00000000
2020-09-02 00:38:04 warning kernel[]: [ 45.901390] REGS: de4a3db0 TRAP: 0700 Not tainted (4.4.199-f90a52a6230ecb072f657fce5aebd444-0)
2020-09-02 00:38:04 warning kernel[]: [ 45.910262] MSR: 00029000 <CE,EE,ME> CR: 28000042 XER: 00000000
2020-09-02 00:38:04 warning kernel[]: [ 45.916368]
2020-09-02 00:38:04 warning kernel[]: [ 45.916368] GPR00: c01f11d4 de4a3e60 da9e3960 00000025 00029000 00000000 00000035 c066622c
2020-09-02 00:38:04 warning kernel[]: [ 45.916368] GPR08: 00000001 c063db74 c063db74 000001ad 42000044 00000000 c0046494 da918360
2020-09-02 00:38:04 warning kernel[]: [ 45.916368] GPR16: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
2020-09-02 00:38:04 warning kernel[]: [ 45.916368] GPR24: 00009449 da43100c da450148 da43104c fffffffb da431000 da41d138 daa73c00
2020-09-02 00:38:04 warning kernel[]: [ 45.946110] NIP [c01f11d4] btrfs_commit_transaction+0xc38/0xde8
2020-09-02 00:38:04 warning kernel[]: [ 45.952030] LR [c01f11d4] btrfs_commit_transaction+0xc38/0xde8
2020-09-02 00:38:04 warning kernel[]: [ 45.957859] Call Trace:
2020-09-02 00:38:04 warning kernel[]: [ 45.960302] [de4a3e60] [c01f11d4] btrfs_commit_transaction+0xc38/0xde8 (unreliable)
2020-09-02 00:38:04 warning kernel[]: [ 45.967965] [de4a3ec0] [c01eadcc] transaction_kthread+0xfc/0x1c8
2020-09-02 00:38:04 warning kernel[]: [ 45.973976] [de4a3ef0] [c0046574] kthread+0xe0/0xe4
2020-09-02 00:38:04 warning kernel[]: [ 45.978858] [de4a3f40] [c000e2c4] ret_from_kernel_thread+0x5c/0x64
2020-09-02 00:38:04 warning kernel[]: [ 45.985036] Instruction dump:
2020-09-02 00:38:04 warning kernel[]: [ 45.987998] 7d005028 7d074b78 7ce0512d 40a2fff4 7c0004ac 71090004 40a2001c 3c60c05a
2020-09-02 00:38:04 warning kernel[]: [ 45.995758] 7f84e378 38635940 4cc63182 482f8121 <0fe00000> 3ca0c050 7fc3f378 38a570c4
2020-09-02 00:38:04 warning kernel[]: [ 46.003695] ---[ end trace f714228ff7586b84 ]---
2020-09-02 00:38:04 crit kernel[]: [ 46.008336] BTRFS: error (device mmcblk0p2) in cleanup_transaction:1840: errno=-5 IO failure
2020-09-02 00:38:04 info kernel[]: [ 46.016793] BTRFS info (device mmcblk0p2): forced readonly
2020-09-02 00:38:04 info kernel[]: [ 46.022289] BTRFS info (device mmcblk0p2): delayed_refs has NO entry
2020-09-02 00:38:04 err kernel[]: [ 46.025872] mmcblk0: error -84 transferring data, sector 1840152, nr 32, cmd response 0x900, card status 0xb00
2020-09-02 00:38:04 warning kernel[]: [ 46.084588] mmc0: tried to reset card
2020-09-02 00:38:04 notice kernel[]: 46.096700] mount_root: mounting /dev/root
2020-09-02 00:38:04 info kernel[]: [ 46.101831] BTRFS info (device mmcblk0p2): disk space caching is enabled
2020-09-02 00:38:04 err kernel[]: [ 46.108561] BTRFS error (device mmcblk0p2): Remounting read-write after error is not allowed
2020-09-02 00:38:04 info kernel[]: 46.121904] mount_root: loading kmods from internal overlay
2020-09-02 00:38:04 info kernel[]: 46.567030] block: attempting to load /etc/config/fstab
2020-09-02 00:38:04 info kernel[]: 46.582944] block: extroot: not configured
2020-09-02 00:38:04 info kernel[]: 46.594533] procd: - early -
2020-09-02 00:38:04 info kernel[]: 46.597632] procd: - watchdog -
2020-09-02 00:38:04 info kernel[]: 47.255884] procd: - ubus -
2020-09-02 00:38:04 info kernel[]: 48.265503] procd: - init -
