Hi, I’ve just came across a software for digital asset management called ResourceSpace. I wish to know what do you think about it. Does it makes sense to deploy it on Omnia? Would it be even possible? Or is it just overkill? Thanks for your thoughts.
I just had a quick look. The requirements aren’t any special but still you’d have to make sure to use the Turris in an environment where the dependencies (packages) are available.
Keep in mind that there are lots of tools which can do similar things, e.g. ownCloud which probably has a larger community. As with most comparisons the value of a specific tool highly depends on your use case and requirements.
