Turris Omnia - rtrom01
Turris OS 3.9.6
Kernel 4.4.119-082ea0f4a4e204b99821bedcb349ed54-0
Unbound 1.6.8
Either the neglience resides in parsing the settings at all or in the output of the parsed unbound.conf
Assuming that all below, which been added in the “config resolver ‘unbound’” section of /etc/config/resolver, can be parsed by uci
option dhcp_link ‘dnsmasq’
option logfile ‘/data/log/unbound.log’
option so_sndbuf ‘4m’
option so_rcvbuf ‘4m’
option so_reuseport ‘yes’
option cache_max_ttl ‘14400’
option ssl_upstream ‘yes’
option rrset_roundrobin ‘yes’
option module_config ‘validator iterator’
option ratelimit ‘150’
option hide_identity ‘yes’
option hide_version ‘yes’
option hide_trustanchor ‘yes’
option use_caps_for_id ‘yes’
There are no errors when
/etc/init.d/resolver restart
However none is showing in the output of unbound.conf
Tried all/any in the unbound syntax (e.g. rrset-roundrobin: yes) through
list include_path "/etc/unbound/unbound_srv.conf"
but that is just throwing
error: syntax error
