I upgraded the secure-firmware (/dev/mtd0
) and a53-firmware (/dev/mtd1
) partitions from ancient release versions of Turris MOX, and now need to reset the u-boot environment to default values instead of the currently stored ones.
How do I reset u-boot environment to defaults in Turris MOX? I assume they are the ones stored in the u-boot-env (/dev/mtd2
) partition but it might be somewhere else too.
EDIT:
I ran the commands:
fw_setenv bootcmd 'env default -f -a; saveenv; reset'
reboot
and after reboot the u-boot-env (/dev/mtd2
) partition had newly generated values that I assume are the correct ones.
I would still like confirmation from someone that this is the correct way of resetting the values to default on the Turris MOX.
