Replace lighttpd with uhttpd
Hello everyone,
my goal is to be able to easily access the web interface (Luci) of Turris https secured by a let’s encrypt certificate from the local network.
The acme from the OpenWrt repo in combination with uhttpd offers exactly that. I get the certificate automatically via DNS-API.
Since the implementation with lighttpd seems too complicated to me (certificates have to be converted at least) I would like to replace lighttpd with uhttpd.
Are there any problems here (e.g. with Foris) or is it simply a package swap?
Many thanks in advance.
lighttpd and acme-dnsapi work perfectibility fine together without any conversion. What have you tried?
Hello salty,
thanks for reply.
I find the Turris guide super cumbersome.
Then I have the following documentation with the corresponding certificate conversion because lighttpd apparently expects .pem certificates.
How did you implement it?
Where in the lighttpd config do I refer to the acme dir? I only have the certificates as .cer .csr and the key.
Greetings
Addendum:
This is a wildcard certificate which I also want to use on other OpenWrt devices. That’s why uhttpd would be the right choice and there is an option in acme to use the certificate for uttpd. Then I would have it directly in the correct format for the other devices.
/etc/config/acme
config acme
        option state_dir '/etc/acme'
        option account_email 'name.surname@example.com'
        option debug '0'
config cert 'main'
        option keylength 'ec-256'
        list domains 'router.example.com'    # subjectName
        list domains 'srv1.example.com'    # subjectAltName
        list domains 'srv2.example.com'    # subjectAltName
        option enabled '1'
        option validation_method 'dns'
        option dns 'dns_<provider>'   # see https://github.com/acmesh-official/acme.sh/wiki/dnsapi for list of options
        list credentials '<XX>_Username="<username>"'
        list credentials '<XX>_Password="<password>"'
        option use_staging '0'
Updater and lighttpd modifications for SSL support
Updater configuration
/etc/updater/conf.d/lighttpd-ssl-acme.lua
Uninstall("lighttpd-https-cert", { priority = 60 })
Install("lighttpd-mod-openssl")
Lighttpd SSL configuration
/etc/lighttpd/conf.d/39-ssl-acme.conf
ssl.pemfile = "/etc/acme/www.example.com_ecc/fullchain.cer"
ssl.privkey = "/etc/acme/www.example.com_ecc/www.example.com.key"
ssl.openssl.ssl-conf-cmd = (
  "MinProtocol" => "TLSv1.2",
  "Options" => "-ServerPreference",
  "CipherString" => "ECDHE+AESGCM:ECDHE+AES256:CHACHA20:!SHA1:!SHA256:!SHA384"
$SERVER["socket"] == ":443" {
  ssl.engine = "enable"
$SERVER["socket"] == "[::]:443" {
Nothing more, nothing less. Don’t forget to run the pkgupdate to remove lighttpd-https-cert and install lighttpd-mod-openssl, and in the end restart the lighttpd.
Candidate for documentation?
Do you happen to have any tips on how I can get the certificates onto the other three OpenWrt devices? A blunt script which copies the data daily via SCP and restarts the web server…
Somehow that seems like a sledgehammer to me.
Or does it make more sense to run a separate acme on each device and then get one certificate per subdomain rather than wildcard?
Absolutely.
Post must be at least 20 characters
