Etz
November 20, 2016, 2:34pm
1
For example, I have uninstalled multiple packages from my Omnia as I don’t need them:
Transmission
MJPG-Streamer
Wondershaper
MiniDLNA
Samba
hd-idle
…and some others…
Problem is that in less than 24 hours, they have reinstalled themselves, against my will.
Is there any option to avoid this clutter reappearing that I have overlooked?
Etz
November 20, 2016, 2:42pm
3
Ok, then it behaves the very same way as my ISP`s OpenWRT box, they force all sorts of clutter into the router…
Very annoying I must say…
Pepe
November 20, 2016, 2:43pm
4
No, there’s workaround, which is in that thread I mention and also in upcoming update of updater it will be possible.
Etz
November 20, 2016, 2:45pm
5
Yeah, currently digging trough that thread…
As I really would only like to use this as high performance router only…
I already have separate server for other tasks.
vorner
November 20, 2016, 2:56pm
6
You can also go to the foris interface, the updater tab and uncheck all the package groups you don’t need. These kind of list packages you want, in a sense, so they appear back. I think many of the listed ones are part of nas, so if you uncheck that one, they should be gone.
But having them installed (and not running) doesn’t hurt performance.
Etz
November 20, 2016, 3:03pm
7
Trouble is…they are unchecked there…
NAS part is unselected, still Samba got reinstalled…go figure.
Same goes for Web Cam Support, etc…
Yes, they do not affect performance if they are not running, but they do clutter the user interface.
Also I do perfer philosophy “less is more”, less packages, less chance that something breaks or some 0-day vulnerability hits you.
vorner
November 20, 2016, 3:36pm
8
I just checked and this seems to be a bug on our side (the packages also crept into the „base“ system group which can’t be unchecked for obvious reasons). It’s already fixed in the release we are preparing. I thought we fixed this before we started to send out the routers, but obviously not :-(.
So, please be patient, the fix is coming.
mumajs
November 20, 2016, 3:48pm
10
I thank you too! But here is small BUT
Guys, whole forum is full of, we though it is fixed, but we forgot to increase the version number etc…
Is that the better scenario we had from standard SOHO routers which cost 1/5 of the turris price?
The difference at this moment is that cheap SOHO routers authors were aware they are leaving users with unsecure firmware. You? yout think we are secure but we are not, because you forgot something and we have something even worse you think we have. That sounds to me more critical. Guys, I know you are busy these days, but focus on users which have devices with troubles already instead of the missing shipments! There is so much answers we though that we did something… Every human do a mistake, but in case you preffern Turris because it is more secure? That is not more secure behaviour!
A lot of packages are also installed as dependencies of LuCI extensions, like transmission
, which is a dependency for luci-app-transmission
Etz
November 20, 2016, 4:46pm
12
Any documentation, what those checkboxes actually do?
I mean list of packages and their dependencies hidden behind those choices?
Right now it feels like black box, which does some black magic…
Etz
November 20, 2016, 5:38pm
14
OK, by the looks of it, it should be made a bit more granular…
For example luci-app-transmission has dependency as transmission, but it makes little sense to “force” install it, if user does not have any NAS duties specified, etc…
(It means pretty much, that user does not have storage for downloads, hence why he would need transmission then?)
Right now, only viable workaround would be to disable whole “LuCI extensions”, but that means that all luci-app-* packages would be excluded from auto updates, even those which are actually required to have GUI for other packages.
Currently that whole concept looks a bit awkward to me, as updater should actually look for /etc/updater/auto.lua to see what was actually installed, instead of relying on somekind of hardcoded and pre-selected lists.
For quick setup current concept works fine but for continious system updating, not so much.
Also,there seem to be some duplicates between
https://api.turris.cz/openwrt-repo/omnia/lists/nas.lua
and
https://api.turris.cz/openwrt-repo/omnia/lists/luci-controls.lua
Mini-DLNA is listed in both, and Transmission too, also corresponding luci-app-* packages are listed in both lists.
Not quite sure, why it would be needed to update/install those twice, but hey…I did not build or designed it
(Actually they are listed at least in three lists, in base.lua as well as Voerner already pointed out earlier)
The thing is, there is now ongoing transition between old shell-based updater
, which is still in use in the old generations of Turris routers and the new C&Lua-based updater-ng
, which is utilized in the Omnia.
The old updater was not able to keep track of user-installed packages, therefore the only way how to select which packages to install and keep up-to-date, was through these lists. The new updater-ng
is much smarter and is able to even track user-installed packages, which makes such package sets not necessary anymore. In the future, it will also keep track of user-uninstalled packages. But until that, it is quite safe to uncheck all the sets and just manually install packages you like.
After rollback to factory reset I have unchecked all package lists except “CA root certificates” and “LXC utilities” but all packages continue are installed. After reboot all continue equal:
root@turris:~# opkg list-installed
6in4 - 21-2
6rd - 9-2
6to4 - 12-2
acl - 20160519-1
ahcpd - 0.53-2
alsa-lib - 1.1.0-1
at - 3.1.16-2
ath10k-firmware-qca988x - 2014-10-28-7d14e337ad25c0ef3e78fc47eac336697ca612e8-1
attr - 20160302-1
badblocks - 1.42.12-1
base-files - 173-r49274
bash - 4.3.42-1
bind-client - 9.9.8-P4-3
bind-dig - 9.9.8-P4-3
bind-libs - 9.9.8-P4-3
blkid - 2.25.2-5
block-mount - 2015-05-24-09027fc86babc3986027a0e677aca1b6999a9e14-1
br2684ctl - 2.5.2-5
btrfs-progs - 4.5.1-1
busybox - 1.23.2-3
bzip2 - 1.0.6-2
c-rehash - 1.7-3
ca-certificates - 20150426
cert-backup - 6
cfdisk - 2.25.2-5
chat - 2.4.7-10
cifsmount - 6.4-1
collectd - 4.10.8-3
collectd-mod-interface - 4.10.8-3
collectd-mod-iwinfo - 4.10.8-3
collectd-mod-load - 4.10.8-3
collectd-mod-network - 4.10.8-3
collectd-mod-rrdtool - 4.10.8-3
comgt - 0.32-25
conntrack-tools - 1.4.2-1
coreutils - 8.23-2
coreutils-base64 - 8.23-2
create_notification - 42
cryptsetup-openssl - 1.7.2-1
curl - 7.51.0-1
cznic-cacert-bundle - 31
cznic-repo-keys - 4
daemon-watchdog - 18
davfs2 - 1.5.4-2
ddns-scripts - 2.7.3-1
ddns-scripts_cloudflare - 2.7.3-1
ddns-scripts_no-ip_com - 2.7.3-1
ddns-scripts_nsupdate - 2.7.3-1
diffutils - 3.3-2
dnsmasq - 2.73-1
dnssec-rootkey - 0.0.1-1
dosfsck - 3.0.28-1
ds-lite - 7-1
e2fsprogs - 1.42.12-1
ebtables - 2.0.10-4-3
etherwake - 1.09-5
fdisk - 2.25.2-5
file - 5.25-1
firewall - 2016-02-17
flock - 2.25.2-5
foris - 71-1
fstools - 2015-05-24-09027fc86babc3986027a0e677aca1b6999a9e14-1
fuse-utils - 2.9.3-2
getopt - 2.25.2-5
glib2 - 2.46.2-2
gnupg - 1.4.20-2
gnupg-utils - 1.4.20-2
hd-idle - 1.04-2
hdparm - 9.48-1
hfsfsck - 332.25-1
hostapd-common - 2016-06-15-2
htop - 2.0.1-1
https-cert - 3
i2c-tools - 3.1.2-1
ip - 4.0.0-2
ip6tables - 1.4.21-3
iptables - 1.4.21-3
iw - 3.17-1
iwinfo - 2015-06-01-ade8b1b299cbd5748db1acf80dd3e9f567938371
jansson - 2.7-1
jshn - 2015-06-14-d1c66ef1131d14f0ed197b368d03f71b964e45f8
jsonfilter - 2014-06-19-cdc760c58077f44fc40adbbe41e1556a67c1b9a9
kernel - 4.4.13-1-05df79f63527051ea0071350f86faf76-9
kmod-ata-ahci - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ata-ahci-platform - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ata-core - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ata-mvebu-ahci - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ath - 4.4.13+2015-12-03-3-05df79f63527051ea0071350f86faf76-9
kmod-ath10k - 4.4.13+2015-12-03-3-05df79f63527051ea0071350f86faf76-9
kmod-ath9k - 4.4.13+2015-12-03-3-05df79f63527051ea0071350f86faf76-9
kmod-ath9k-common - 4.4.13+2015-12-03-3-05df79f63527051ea0071350f86faf76-9
kmod-atm - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-bridge - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-cfg80211 - 4.4.13+2015-12-03-3-05df79f63527051ea0071350f86faf76-9
kmod-crypto-aead - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-authenc - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-cbc - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-ccm - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-cmac - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-crc32c - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-ctr - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-deflate - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-des - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-ecb - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-fcrypt - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-gf128 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-hash - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-hmac - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-iv - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-manager - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-marvell-cesa - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-md4 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-md5 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-null - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-pcbc - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-pcompress - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-rng - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-rng-jitterentropy - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-seqiv - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-sha1 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-sha256 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-sha512 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-user - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-wq - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-crypto-xts - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-cryptodev - 4.4.13+1.8-mvebu-2
kmod-dm - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-dnsresolver - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ebtables - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-afs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-autofs4 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-btrfs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-cifs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-configfs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-cramfs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-exfat - 4.4.13+git-20151121-2
kmod-fs-exportfs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-ext4 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-f2fs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-fscache - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-hfs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-hfsplus - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-isofs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-jfs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-minix - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-msdos - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-nfs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-nfs-common - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-nfsd - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-ntfs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-udf - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-vfat - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fs-xfs - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-fuse - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-gre - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-hwmon-core - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-i2c-core - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-i2c-mv64xxx - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-input-core - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ip6-tunnel - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ip6tables - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ipt-conntrack - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ipt-core - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ipt-nat - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-iptunnel - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-iptunnel4 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-iptunnel6 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ledtrig-default-on - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ledtrig-gpio - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ledtrig-heartbeat - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ledtrig-morse - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ledtrig-netdev - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ledtrig-netfilter - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ledtrig-oneshot - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ledtrig-timer - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ledtrig-transient - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ledtrig-usbdev - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-lib-crc-ccitt - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-lib-crc-itu-t - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-lib-crc16 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-lib-crc32c - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-lib-lzo - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-lib-raid6 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-lib-textsearch - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-lib-xor - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-lib-zlib - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-llc - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-mac80211 - 4.4.13+2015-12-03-3-05df79f63527051ea0071350f86faf76-9
kmod-md-linear - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-md-mod - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-md-multipath - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-md-raid0 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-md-raid1 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-md-raid10 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-md-raid456 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-mii - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-mmc - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-mppe - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-mvsdio - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nf-conntrack - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nf-conntrack-netlink - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nf-conntrack6 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nf-ipt - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nf-ipt6 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nf-nat - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nf-nathelper - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nf-nathelper-extra - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nfnetlink - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-base - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-cp1250 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-cp1251 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-cp437 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-cp775 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-cp850 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-cp852 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-cp862 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-cp864 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-cp866 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-cp932 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-iso8859-1 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-iso8859-13 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-iso8859-15 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-iso8859-2 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-iso8859-6 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-iso8859-8 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-koi8r - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-nls-utf8 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-ppp - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-pppoa - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-pppoe - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-pppox - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-rxrpc - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-sched - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-sched-core - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-scsi-core - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-sit - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-slhc - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-sound-core - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-stp - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-thermal - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-thermal-armada - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-tun - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-core - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-net - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-net-cdc-ether - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-net-qmi-wwan - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-net-rndis - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-serial - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-serial-option - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-serial-qualcomm - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-serial-wwan - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-storage - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-storage-extras - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-uhci - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb-wdm - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb2 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-usb3 - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-veth - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
kmod-wdt-orion - 4.4.13+9-1-05df79f63527051ea0071350f86faf76-9
knot-libdnssec - 2.3.0-2
knot-libknot - 2.3.0-2
knot-libzscanner - 2.3.0-2
knot-resolver - 1.1.1-3
libacl - 20160519-1
libatsha204 - 25
libattr - 20160302-1
libblkid - 2.25.2-5
libblobmsg-json - 2015-06-14-d1c66ef1131d14f0ed197b368d03f71b964e45f8
libbz2 - 1.0.6-2
libc - 1.1.11-4
libcap - 2.24-1
libcurl - 7.51.0-1
libdbi - 0.9.0-4
libdevmapper - 2.02.145-1
libelf1 - 0.161-2
libevent2 - 2.0.22-1
libeventlog - 0.2.9-2
libexif - 0.6.21-1
libexpat - 2.1.0-3
libext2fs - 1.42.12-1
libffi - 3.2.1-2
libffmpeg - 2.7.6-1
libflac - 1.3.1-3
libfuse - 2.9.3-2
libgcc - 4.8-linaro-4
libgcrypt - 1.6.1-2
libgmp - 6.0.0-1
libgnutls - 3.4.14-1
libgpg-error - 1.12-2
libid3tag - 0.15.1b-4
libip4tc - 1.4.21-3
libip6tc - 1.4.21-3
libiwinfo - 2015-06-01-ade8b1b299cbd5748db1acf80dd3e9f567938371
libiwinfo-lua - 2015-06-01-ade8b1b299cbd5748db1acf80dd3e9f567938371
libjpeg - 6b-2
libjson-c - 0.12-1
libjson-script - 2015-06-14-d1c66ef1131d14f0ed197b368d03f71b964e45f8
libldns - 1.6.17-2
libltdl - 2.4-1
liblua - 5.1.5-1
liblxc - 1.1.5-5
liblzma - 5.2.2-1
liblzo - 2.08-1
libmagic - 5.25-1
libmnl - 1.0.3-2
libmount - 2.25.2-5
libncurses - 5.9-2
libneon - 0.30.0-2
libnetconf - 11
libnetfilter-conntrack - 1.0.4-1
libnetfilter-cthelper - 1.0.0-1
libnetfilter-cttimeout - 1.0.0-1
libnetfilter-queue - 1.0.2-1
libnettle - 3.1.1-1
libnfnetlink - 1.0.1-1
libnl-tiny - 0.1-4
libogg - 1.3.2-2
libopenssl - 1.0.2h-2
libpcap - 1.5.3-1
libpcre - 8.39-1
libpopt - 1.16-1
libpthread - 1.1.11-4
libreadline - 6.3-1
librpc - 2015-04-10-308e9964bfb623773dc0dcc99ef9d18d1551d6ae
librrd1 - 1.0.50-2
librt - 1.1.11-4
libsensors - 3.3.5-3
libsmartcols - 2.25.2-5
libspeex - 1.2rc1-1
libsqlite3 - 3130000-1
libsysfs - 2.1.0-2
libubox - 2015-06-14-d1c66ef1131d14f0ed197b368d03f71b964e45f8
libubus - 2015-05-25-f361bfa5fcb2daadf3b160583ce665024f8d108e
libubus-lua - 2015-05-25-f361bfa5fcb2daadf3b160583ce665024f8d108e
libuci - 2015-04-09.1-1
libuci-lua - 2015-04-09.1-1
libunbound - 1.5.1-8
libusb-1.0 - 1.0.19-1
libuuid - 2.25.2-5
libuv - 1.6.1-1
libvorbis - 1.3.5-1
libwrap - 7.6-1
libxml2 - 2.9.4-1
libxslt - 1.1.28-2
libxtables - 1.4.21-3
lighttpd - 1.4.39-2
lighttpd-mod-alias - 1.4.39-2
lighttpd-mod-cgi - 1.4.39-2
lighttpd-mod-fastcgi - 1.4.39-2
linux-atm - 2.5.2-5
lm-sensors - 3.3.5-3
logrotate - 3.8.1-8
losetup - 2.25.2-5
lsblk - 2.25.2-5
lua - 5.1.5-1
luajit - 2.0.4-1
luasec - 0.5.1-1
luasocket - 3.0-rc1-20130909-3
luci - git-16.212.24666-3200f7d-1
luci-app-ahcp - git-16.212.24666-3200f7d-1
luci-app-commands - git-16.212.24666-3200f7d-1
luci-app-ddns - 2.4.6-2
luci-app-firewall - git-16.212.24666-3200f7d-1
luci-app-hd-idle - git-16.212.24666-3200f7d-1
luci-app-lxc - 20160616
luci-app-minidlna - git-16.212.24666-3200f7d-1
luci-app-mjpg-streamer - git-16.212.24666-3200f7d-1
luci-app-ntpc - git-16.212.24666-3200f7d-1
luci-app-rainbow - 2
luci-app-samba - git-16.212.24666-3200f7d-1
luci-app-statistics - git-16.212.24666-3200f7d-1
luci-app-tinyproxy - git-16.212.24666-3200f7d-1
luci-app-transmission - git-16.212.24666-3200f7d-1
luci-app-upnp - git-16.212.24666-3200f7d-1
luci-app-watchcat - git-16.212.24666-3200f7d-1
luci-app-wol - git-16.212.24666-3200f7d-1
luci-app-wshaper - git-16.212.24666-3200f7d-1
luci-base - git-16.212.24666-3200f7d-1
luci-i18n-ahcp-cs - git-16.212.24666-3200f7d-1
luci-i18n-ahcp-en - git-16.212.24666-3200f7d-1
luci-i18n-base-cs - git-16.212.24666-3200f7d-1
luci-i18n-base-en - git-16.212.24666-3200f7d-1
luci-i18n-commands-cs - git-16.212.24666-3200f7d-1
luci-i18n-commands-en - git-16.212.24666-3200f7d-1
luci-i18n-ddns-cs - 2.4.6-2
luci-i18n-firewall-cs - git-16.212.24666-3200f7d-1
luci-i18n-firewall-en - git-16.212.24666-3200f7d-1
luci-i18n-hd-idle-cs - git-16.212.24666-3200f7d-1
luci-i18n-hd-idle-en - git-16.212.24666-3200f7d-1
luci-i18n-minidlna-cs - git-16.212.24666-3200f7d-1
luci-i18n-minidlna-en - git-16.212.24666-3200f7d-1
luci-i18n-ntpc-cs - git-16.212.24666-3200f7d-1
luci-i18n-ntpc-en - git-16.212.24666-3200f7d-1
luci-i18n-samba-cs - git-16.212.24666-3200f7d-1
luci-i18n-samba-en - git-16.212.24666-3200f7d-1
luci-i18n-statistics-cs - git-16.212.24666-3200f7d-1
luci-i18n-statistics-en - git-16.212.24666-3200f7d-1
luci-i18n-tinyproxy-cs - git-16.212.24666-3200f7d-1
luci-i18n-tinyproxy-en - git-16.212.24666-3200f7d-1
luci-i18n-transmission-cs - git-16.212.24666-3200f7d-1
luci-i18n-transmission-en - git-16.212.24666-3200f7d-1
luci-i18n-upnp-cs - git-16.212.24666-3200f7d-1
luci-i18n-upnp-en - git-16.212.24666-3200f7d-1
luci-i18n-watchcat-cs - git-16.212.24666-3200f7d-1
luci-i18n-watchcat-en - git-16.212.24666-3200f7d-1
luci-i18n-wol-cs - git-16.212.24666-3200f7d-1
luci-i18n-wol-en - git-16.212.24666-3200f7d-1
luci-i18n-wshaper-cs - git-16.212.24666-3200f7d-1
luci-i18n-wshaper-en - git-16.212.24666-3200f7d-1
luci-lib-ip - git-16.212.24666-3200f7d-1
luci-lib-jsonc - git-16.212.24666-3200f7d-1
luci-lib-nixio - git-16.212.24666-3200f7d-1
luci-mod-admin-full - git-16.212.24666-3200f7d-1
luci-proto-3g - git-16.212.24666-3200f7d-1
luci-proto-ipv6 - git-16.212.24666-3200f7d-1
luci-proto-openconnect - git-16.212.24666-3200f7d-1
luci-proto-ppp - git-16.212.24666-3200f7d-1
luci-proto-relay - git-16.212.24666-3200f7d-1
luci-proto-vpnc - 1.0.0-2
luci-theme-bootstrap - git-16.212.24666-3200f7d-1
lvm2 - 2.02.145-1
lxc - 1.1.5-5
lxc-attach - 1.1.5-5
lxc-auto - 1.1.5-5
lxc-autostart - 1.1.5-5
lxc-common - 1.1.5-5
lxc-config - 1.1.5-5
lxc-configs - 1.1.5-5
lxc-console - 1.1.5-5
lxc-create - 1.1.5-5
lxc-hooks - 1.1.5-5
lxc-info - 1.1.5-5
lxc-ls - 1.1.5-5
lxc-monitor - 1.1.5-5
lxc-monitord - 1.1.5-5
lxc-snapshot - 1.1.5-5
lxc-start - 1.1.5-5
lxc-stop - 1.1.5-5
lxc-templates - 1.1.5-5
mdadm - 3.2.5-1
minidlna - 1.1.5-2
miniupnpd - 2.0-1
mjpg-streamer - r182-9
mkdosfs - 3.0.28-1
mkhfs - 332.25-1
mount-utils - 2.25.2-5
mountd - 0.1-6
msmtp - 1.6.2-2
mtd - 21
nethist - 13
netifd - 2015-06-08-8795f9ef89626cd658f615c78c6a17e990c0dcaa
nfs-kernel-server - 1.3.3-3
nfs-kernel-server-utils - 1.3.3-3
ntfs-3g - 2015.3.14-1-fuseext
ntfs-3g-utils - 2015.3.14-1-fuseext
ntpclient - 2010_365-2
ntpdate - 4.2.8p7-1
nuci - 133
nuci-nethist - 133
odhcp6c - 2015-07-13-024525798c5f6aba3af9b2ef7b3af2f3c14f1db8
odhcpd - 2015-05-21-2ebf6c8216287983779c8ec6597d30893b914a7c
oneshot - 18
openconnect - 7.06-5
openssh-client - 7.2p2-2
openssh-client-utils - 7.2p2-2
openssh-keygen - 7.2p2-2
openssh-moduli - 7.2p2-2
openssh-server - 7.2p2-2
openssh-sftp-client - 7.2p2-2
openssh-sftp-server - 7.2p2-2
openssl-util - 1.0.2h-2
openvpn-openssl - 2.3.6-6
opkg - 9c97d5ecd795709c8584e972bfdf3aee3a5b846d-14
opkg-trans - 31
partx-utils - 2.25.2-5
portmap - 6.0-4
ppp - 2.4.7-10
ppp-mod-pppoa - 2.4.7-10
ppp-mod-pppoe - 2.4.7-10
pptpd - 1.4.0-3
procd - 2015-08-16-0da5bf2ff222d1a499172a6e09507388676b5a08
procd-nand - 2015-08-16-0da5bf2ff222d1a499172a6e09507388676b5a08
psmisc - 22.16-1
python-base - 2.7.11-9
python-beaker - 1.6.4-2
python-bottle - 0.12.7-2
python-bottle-i18n - 0.1.5-1
python-codecs - 2.7.11-9
python-email - 2.7.11-9
python-flup - 1.0.2-2
python-light - 2.7.11-9
python-logging - 2.7.11-9
python-ncclient - 0.4pre-2
python-openssl - 2.7.11-9
python-xml - 2.7.11-9
rainbow-omnia - 3
relayd - 2015-03-13-2970ff60bac6b70ecb682779d5c776dc559dc0b9
resize2fs - 1.42.12-1
resolveip - 2
resolver-conf - 0.0.1-4
rpcd - 2015-05-17-3d655417ab44d93aad56a6d4a668daf24b127b84-2
rpcd-mod-lxc - 20141012
rrdtool1 - 1.0.50-2
rsync - 3.1.2-1
rsyncd - 3.1.2-1
samba36-client - 3.6.25-5
samba36-server - 3.6.25-5
schnapps - 0.9-1
sfdisk - 2.25.2-5
sfpswitch - 4
shadow - 4.2.1-6
shadow-chage - 4.2.1-6
shadow-common - 4.2.1-6
shadow-groupadd - 4.2.1-6
shadow-groupdel - 4.2.1-6
shadow-groupmod - 4.2.1-6
shadow-groups - 4.2.1-6
shadow-passwd - 4.2.1-6
shadow-su - 4.2.1-6
shadow-useradd - 4.2.1-6
shadow-userdel - 4.2.1-6
shadow-usermod - 4.2.1-6
shadow-utils - 4.2.1-6
smartd - 6.5-1
smartmontools - 6.5-1
socat - 1.7.3.0-3
sshfs - 2.5-2
start-indicator - 1
swap-utils - 2.25.2-5
swconfig - 11
sysfsutils - 2.1.0-2
syslog-ng3 - 3.0.9-4
tar - 1.29-2
tc - 4.0.0-2
tcpdump - 4.5.1-4
terminfo - 5.9-2
thermometer - 3
tinyproxy - 1.8.3-2
transmission-daemon-openssl - 2.92-3
tune2fs - 1.42.12-1
turris-version - 3.2.1
ubi-utils - 1.5.1-2
uboot-envtools - 2014.10-2
ubox - 2015-07-14-907d046c8929fb74e5a3502a9498198695e62ad8
ubusd - 2015-05-25-f361bfa5fcb2daadf3b160583ce665024f8d108e
uclibcxx - 0.2.4-1
ucollect-config - 117
udev - 173-1
unbound - 1.5.1-8
unbound-anchor - 1.5.1-8
update_mac - 1
updater-ng - 31
uqmi - 2015-09-09-c61815319c1c0e76898048a19151f30844a6989c
usb-modeswitch - 2014-08-26-993a9a542791953c4804f7ddbb3a07756738e37a
usbutils - 007-1
user_notify - 42
userlists - 3
usign - 2015-05-08-cf8dcdb8a4e874c77f3e9a8e9b643e8c17b19131
vim-full - 7.4-3
vixie-cron - 6
vpnc - 0.5.3.r550-5
vpnc-scripts - 20151220-1
vsftpd - 3.0.3-1
watchcat - 1-6
watchdog_adjust - 2
wget - 1.18-1
wireless-tools - 29-5
wol - 0.7.1-3
wpad - 2016-06-15-2
wshaper - 1.1a-1
xfs-fsck - 3.1.7-1
xfs-growfs - 3.1.7-1
xfs-mkfs - 3.1.7-1
xz - 5.2.2-1
xz-utils - 5.2.2-1
zlib - 1.2.8-1
I have tried to execute “updater.sh”:
root@turris:~# updater.sh
WARN:Lock on //var/lock/opkg.lock released by garbage collector
uci: Entry not found
This OpenWRT fork require a lot of work, it is not prepared for deploy… to put it politely…
Etz
November 23, 2016, 9:01pm
17
Well, because they messed up the lists…somehow…
vorner
December 12, 2016, 8:13am
19
Actually, it should have been fixed by this update and by a quick look it has been. Still no luck on your end?
Etz
December 12, 2016, 8:15am
20
Well, it definately resolved istelf on mine…
