I was configuring Wi-Fi in reForis using the hostname URL https://turris.local
but saving the settings resulted in a unknown error
message being displayed.
/var/log/lighttpd/error.log
2023-03-20 21:01:18: (../src/server.c.1588) server started (lighttpd/1.4.67)
2023-03-20 21:20:28: (../src/gw_backend.c.528) connect /tmp/fastcgi.turris_auth.socket-0: Connection refused
2023-03-20 21:20:29: (../src/gw_backend.c.528) connect /tmp/fastcgi.reforis.socket-0: Connection refused
2023-03-20 21:20:32: (../src/mod_fastcgi.c.450) FastCGI-stderr:[2023-03-20 21:20:32,367] WARNING in flask_seasurf: Forbidden (CSRF token missing or incorrect.): /api/wifi
Doing the same operation using the IP URL http://192.168.1.1
worked perfectly!
Note: it was a freshly installed Omnia with Turris OS 6.2.4, re-flashed with the latest medkit.
