Thanks for your help. Here is the output…
stick inserted in rear port:
[163332.438557] usb 4-1: new high-speed USB device number 3 using xhci-hcd
[163332.619694] usb-storage 4-1:1.0: USB Mass Storage device detected
[163332.626213] scsi host3: usb-storage 4-1:1.0
[163333.679252] scsi 3:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6
[163333.688273] sd 3:0:0:0: [sdb] 60062500 512-byte logical blocks: (30.8 GB/28.6 GiB)
[163333.697492] sd 3:0:0:0: [sdb] Write Protect is off
[163333.702498] sd 3:0:0:0: [sdb] Mode Sense: 43 00 00 00
[163333.702776] sd 3:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[163333.719550] sdb: sdb1
[163333.723572] sd 3:0:0:0: [sdb] Attached SCSI removable disk
root@turris:~# lsusb -tv
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
|__ Port 1: Dev 3, If 0, Class=Mass Storage, Driver=usb-storage, 480M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=orion-ehci/1p, 480M
and this is with the front port:
[163522.906498] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
[163522.937521] usb-storage 3-1:1.0: USB Mass Storage device detected
[163522.943879] scsi host3: usb-storage 3-1:1.0
[163523.987131] scsi 3:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6
[163523.995973] sd 3:0:0:0: [sdb] 60062500 512-byte logical blocks: (30.8 GB/28.6 GiB)
[163524.004973] sd 3:0:0:0: [sdb] Write Protect is off
[163524.009873] sd 3:0:0:0: [sdb] Mode Sense: 43 00 00 00
[163524.010123] sd 3:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[163524.025269] sdb: sdb1
[163524.029041] sd 3:0:0:0: [sdb] Attached SCSI removable disk
|__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
