Hi Guys,
Last week after several options failed, i decided to look for TOS 4.0. I however did not find it, so i decided to put openWRT on it instead. However things did not go as planned as re-flashing stopped working. After that i was directed to the TOS 4.0 alpha2 topic being released. However to re-flash the Omnia with TOS 4.0, i need to wipe some openWRT settings to get the re-flashing to work as how i have understood it.
Today finally i got the time to connect to a UART cable and manged to have a serial console like with the Omnia. However i’m not sure what to do next as i have not experimented with the serial console before.
This is what i suppose to type in when having the connection, but i am not able to do that.
env default -a
saveenv
When i connect to he Omnia, i get this.
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 10:30:01
Press CTRL-A Z for help on special keys
At the bottom i see this
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7.1 | VT102 | Online 0:0 | ttyUSB0
Nothing more is happening. When i reset the Omnia, until only 1 LED is turned on, i get this
Ut SerDes lanes topology details:
Lane # | peed | Type |
| 0 | 6 | SAT0|
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe |
| 3 | 5 USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
:*Link Gen1,chek the EP capability
PCIe, Idx 1: remains Gen1
:** Link is Gen1, check the EP capability
PCIe, Id : emains Gen1
DDR3 Tining Sequnce Ver TIP-1.29.0
Memory config in EEPROM: 0x02
ng Sitching XBAR Window t FastPath Wind
DDR3 Training Sequence - Ended Successfully
UBoot 215.10-rc(Aug 18 2016 - 20:43: +0200), Build: jenki-omnia-master-23
S: MV88F6820-0
Wtchdog enble
I2C: ready
SPI: e GiB (ECC notled)
Enabling rmad 8 acdg
Dialin CUstartup watchdo.
MM: mv_sdh: 0
F Dtected 25F14 ihpg ie 256 Bytes, erase ize6 KB, total 8 MiB
P001.0 - 168c:003 - Network controller
PCI:
01:00.0 - 11ab:6820 - Memory conroller
0:01.0 - 168c:0033 - Network contrller
Model: ell Armada385 GP
os miaSN: 0000000B0008A67
Regdomaio* A 1 ieot.
AHCI 0001.0000 32 slots SATA mode
flags: 64bit ncq led only pmp fbss pio slu part xs
Net: neta2
neta2: No link.oboot: 5 a2g or PHY auto negotiation to complete.....ME
Wrong Imae Format for bootm comand
ERROR: can't get ernel image!
I have put this medkit on a USB dongle and put the dongle in the front USB.
https://repo.turris.cz/hbs/medkit/omnia-medkit-latest.tar.gz
When trying a re-flash with 4 LEDS turned on, i get this.
U-otSL205.0-r2 (u 820:43:35)
eTh speed PHY - Version: 2.0
Dtce eieI 80is or opoogy
or SrDslaepology details:
| Lane # | Seed | Type |
| 0 | 6 | SATA0 |
| 2 | 5 | PCIe1 |
| 3 | | SB3 HOST1 |
| 4 | 5 | PCIe2 |
| | 0 | SGII2 |
:*LiGeck the EP capability
CIe, Idx 1: remins Gen1
:** Link is Gen1, check the EP capaility
PCIe, Id 2: remains Gen1
DD3 raining Sequen Ver TIP-1.29.0
Meonfig n EPROM: 0x02
DDR3 Traniuen Switchin XBAR WistPt Window
U-o 20510rc (Ag 18 2016 - 0:43:5 +020), Buld:jenkinsomnia-mater-23
SoC: MV88F6820-hdog enaled
I2C: ready
SPI: ready
DRAM: 2 GiB (ECC not enabled)
Enalin Armada 385 watchdog.
Disabling MCU startup watchdo.
MMC: m_sdh: 0to **
SF Detected S2FL164K with page size 256 Bytes, erase size 64 KiB, total 8 MiB
PCI:
00:01.0 - 168c:003c - Network controller
PCI:
01:00.0 - 11ab:6820 - Memory controller
01:01.0 - 168c:0033 - Network controller
Model: Marvell Armada 385 GP
SCSI: MVEBU SATA IIT 000000B00008A67
arget spinup took 0 ms.
SATA link1 tiimpl SAT mode
flags: 64bit cq ld only mp fbss pio slum part sxs
Net: neta2
Hit any key to stop auoboot: 5
otiation to complte........Inea2: No link.
Wrone
