I just upgraded from Turris OS 5 to 6.4.4 (including firmware reset). I am missing rainbow. Where can set the LED colors now? Also, under “System > LED Configuration” I am missing the option to trigger from USB activity.
Rainbow was changed in OS 6 - check “rainbow – help” in CLI.
Thanks, I did. So the Luci GUI was removed? Any way to add it again?
rainbow all 110000
sets all LEDs to red. How do I get that reboot persistent?
Also, is there a config file and better documentation than “-h”?
How do I set LED A to USB activity, for example?
Try to search this forum, Documentation [Turris wiki], official documentation… For reboot persistence you can use cron with “@reboot” clause.
I did search the forum and didn’t find anything. Hence my post.
Identified the problem: the following packages are missing in OS 6 and need to be installed
kmod-usb-ledtrig-usbport
luci-app-ledtrig-usbport
uci-app-rainbow
