I have two Turris devices: mine and a friends.
With mine, I attached two HDDs formatted ext4
to the Turris, then mounted sda1
. As my other posting suggested, I don’t think I did this correctly.
As such, decided to follow this posting.
Before I started the instructions, I mounted each HDD and reformatted them ext4
. Next I wrote a file to each to ensure that they were RW. I removed the files, unmounted the HDDs and rebooted.
Once the device was available I did some preliminary checks:
~# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 1.8T 0 disk
sdb 8:16 0 1.8T 0 disk
mtdblock0 31:0 0 1M 0 disk
mtdblock1 31:1 0 7M 0 disk
mmcblk0 179:0 0 7.3G 0 disk
`-mmcblk0p1 179:1 0 7.3G 0 part /
mmcblk0boot0 179:8 0 4M 1 disk
mmcblk0boot1 179:16 0 4M 1 disk
mmcblk0rpmb 179:24 0 4M 0 disk
I created the RAID1 device:
mdadm --create --verbose /dev/md0 --level=mirror --raid-devices=2 /dev/sda /dev/sdb
I checked its status:
# cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [multipath]
md0 : active raid1 sdb[1] sda[0]
1953383360 blocks super 1.2 [2/2] [UU]
[>....................] resync = 0.0% (823488/1953383360) finish=276.6min speed=117641K/sec
checked the blocks:
# lb
NAME SIZE MOUNTPOINT STATE FSTYPE MODEL SERIAL UUID LABEL
sda 1.8T running ST32000542
`-md0 1.8T
sdb 1.8T running ST32000542
`-md0 1.8T
mtdblock0 1M
mtdblock1 7M
mmcblk0 7.3G 0x0ea2ec8d
`-mmcblk0p1 7.3G / btrfs 9e857b64-9b5e-4a3f-8433-ccf6f4ff47fb
mmcblk0boot0 4M
mmcblk0boot1 4M
mmcblk0rpmb 4M
Some time later, I returned to check the status of mdadm
# cat /proc/mdstat
md0 : active raid1 sdb[1](F) sda[0]
1953383360 blocks super 1.2 [2/1] [U_]
details:
# mdadm --detail /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Sat Jul 22 17:49:16 2017
Raid Level : raid1
Array Size : 1953383360 (1862.89 GiB 2000.26 GB)
Used Dev Size : 1953383360 (1862.89 GiB 2000.26 GB)
Raid Devices : 2
Total Devices : 2
Persistence : Superblock is persistent
Update Time : Sat Jul 22 17:55:52 2017
State : clean, degraded
Active Devices : 1
Working Devices : 1
Failed Devices : 1
Spare Devices : 0
Number Major Minor RaidDevice State
0 8 0 0 active sync /dev/sda
1 0 0 1 removed
1 8 16 - faulty spare /dev/sdb
dmesg
has logged a number of errors:
[ 383.127878] md: bind<sda>
[ 383.137854] md: bind<sdb>
[ 383.138175] md/raid1:md0: not clean -- starting background reconstruction
[ 383.138181] md/raid1:md0: active with 2 out of 2 mirrors
[ 383.138232] md0: detected capacity change from 0 to 2000264560640
[ 383.138316] md: resync of RAID array md0
[ 383.138322] md: minimum _guaranteed_ speed: 1000 KB/sec/disk.
[ 383.138325] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for resync.
[ 383.138330] md: using 128k window, over a total of 1953383360k.
[ 493.027523] ata2.00: exception Emask 0x0 SAct 0x700 SErr 0x0 action 0x6 frozen
[ 493.034778] ata2.00: cmd 61/80:40:00:94:16/01:00:01:00:00/40 tag 8 ncq 196608 out
[ 493.034778] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 493.049709] ata2.00: cmd 61/80:48:80:95:16/05:00:01:00:00/40 tag 9 ncq 720896 out
[ 493.049709] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 493.064632] ata2.00: cmd 61/00:50:00:9b:16/02:00:01:00:00/40 tag 10 ncq 262144 out
[ 493.064632] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 493.079642] ata2: hard resetting link
[ 493.079700] ata1.00: exception Emask 0x0 SAct 0xc0 SErr 0x0 action 0x6 frozen
[ 493.086862] ata1.00: cmd 60/00:30:00:9d:16/05:00:01:00:00/40 tag 6 ncq 655360 in
[ 493.086862] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 493.101703] ata1.00: cmd 60/80:38:00:a2:16/01:00:01:00:00/40 tag 7 ncq 196608 in
[ 493.101703] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[ 493.116531] ata1: hard resetting link
[ 503.077117] ata2: softreset failed (1st FIS failed)
[ 503.082016] ata2: hard resetting link
[ 503.117126] ata1: softreset failed (1st FIS failed)
[ 503.122020] ata1: hard resetting link
[ 513.076723] ata2: softreset failed (1st FIS failed)
[ 513.081617] ata2: hard resetting link
[ 513.116717] ata1: softreset failed (1st FIS failed)
[ 513.121607] ata1: hard resetting link
[ 548.074836] ata2: softreset failed (1st FIS failed)
[ 548.079731] ata2: limiting SATA link speed to 1.5 Gbps
[ 548.079736] ata2: hard resetting link
[ 548.114903] ata1: softreset failed (1st FIS failed)
[ 548.119809] ata1: limiting SATA link speed to 1.5 Gbps
[ 548.119816] ata1: hard resetting link
[ 553.074580] ata2: softreset failed (1st FIS failed)
[ 553.079476] ata2: reset failed, giving up
[ 553.083493] ata2.00: disabled
[ 553.083501] ata2.00: device reported invalid CHS sector 0
[ 553.083505] ata2.00: device reported invalid CHS sector 0
[ 553.083508] ata2.00: device reported invalid CHS sector 0
[ 553.083525] ata2: EH complete
[ 553.083565] sd 1:0:0:0: [sdb] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 553.083574] sd 1:0:0:0: [sdb] tag#11 CDB: opcode=0x2a 2a 00 01 16 9b 00 00 02 00 00
[ 553.083579] blk_update_request: I/O error, dev sdb, sector 18258688
[ 553.089910] sd 1:0:0:0: [sdb] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 553.089917] sd 1:0:0:0: [sdb] tag#12 CDB: opcode=0x2a 2a 00 01 16 95 80 00 05 80 00
[ 553.089924] blk_update_request: I/O error, dev sdb, sector 18257280
[ 553.090595] md/raid1:md0: Disk failure on sdb, disabling device.
[ 553.090595] md/raid1:md0: Operation continuing on 1 devices.
[ 553.090660] md: md0: resync interrupted.
[ 553.107928] sd 1:0:0:0: [sdb] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 553.107935] sd 1:0:0:0: [sdb] tag#13 CDB: opcode=0x2a 2a 00 01 16 94 00 00 01 80 00
[ 553.107939] blk_update_request: I/O error, dev sdb, sector 18256896
[ 553.344570] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 558.344321] ata1.00: qc timeout (cmd 0xec)
[ 558.344335] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 558.344340] ata1.00: revalidation failed (errno=-5)
[ 558.349232] ata1: hard resetting link
[ 568.353829] ata1: softreset failed (1st FIS failed)
[ 568.358726] ata1: hard resetting link
[ 578.363359] ata1: softreset failed (1st FIS failed)
[ 578.368258] ata1: hard resetting link
[ 613.371837] ata1: softreset failed (1st FIS failed)
[ 613.376741] ata1: hard resetting link
[ 618.581627] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 628.581219] ata1.00: qc timeout (cmd 0xec)
[ 628.581235] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 628.581239] ata1.00: revalidation failed (errno=-5)
[ 628.586149] ata1: hard resetting link
[ 638.590824] ata1: softreset failed (1st FIS failed)
[ 638.595769] ata1: hard resetting link
[ 648.600340] ata1: softreset failed (1st FIS failed)
[ 648.605234] ata1: hard resetting link
[ 683.607930] ata1: softreset failed (1st FIS failed)
[ 683.612866] ata1: hard resetting link
[ 688.817603] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 718.815790] ata1.00: qc timeout (cmd 0xec)
[ 718.815805] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[ 718.815812] ata1.00: revalidation failed (errno=-5)
[ 718.820718] ata1.00: disabled
[ 718.820729] ata1.00: device reported invalid CHS sector 0
[ 718.820733] ata1.00: device reported invalid CHS sector 0
[ 718.820745] ata1: hard resetting link
[ 728.825222] ata1: softreset failed (1st FIS failed)
[ 728.830118] ata1: hard resetting link
[ 738.834666] ata1: softreset failed (1st FIS failed)
[ 738.839560] ata1: hard resetting link
[ 773.832878] ata1: softreset failed (1st FIS failed)
[ 773.838038] ata1: hard resetting link
[ 779.042620] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 779.042651] ata1: EH complete
[ 779.042684] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 779.042686] sd 0:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 779.042692] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[ 779.042699] blk_update_request: I/O error, dev sda, sector 8
[ 779.042701] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 01 16 a2 00 00 01 80 00
[ 779.042705] blk_update_request: I/O error, dev sda, sector 18260480
[ 779.054653] md: super_written gets error=-5
[ 779.054699] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 779.054706] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 01 16 9d 00 00 05 00 00
[ 779.054710] blk_update_request: I/O error, dev sda, sector 18259200
[ 779.055003] sd 0:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 779.055008] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 01 16 a2 00 00 00 08 00
[ 779.055011] blk_update_request: I/O error, dev sda, sector 18260480
[ 779.055045] sd 1:0:0:0: [sdb] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 779.055049] sd 1:0:0:0: [sdb] tag#14 CDB: opcode=0x28 28 00 01 16 a2 00 00 00 08 00
[ 779.055051] blk_update_request: I/O error, dev sdb, sector 18260480
[ 779.055062] md/raid1:md0: sda: unrecoverable I/O read error for block 17998336
[ 779.055093] sd 0:0:0:0: [sda] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 779.055097] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 01 16 a2 80 00 00 08 00
[ 779.055099] blk_update_request: I/O error, dev sda, sector 18260608
[ 779.055123] sd 1:0:0:0: [sdb] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 779.055127] sd 1:0:0:0: [sdb] tag#15 CDB: opcode=0x28 28 00 01 16 a2 80 00 00 08 00
[ 779.055129] blk_update_request: I/O error, dev sdb, sector 18260608
[ 779.055137] md/raid1:md0: sda: unrecoverable I/O read error for block 17998464
[ 779.055170] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 779.055174] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 01 16 a3 00 00 00 08 00
[ 779.055176] blk_update_request: I/O error, dev sda, sector 18260736
[ 779.055199] sd 1:0:0:0: [sdb] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 779.055203] sd 1:0:0:0: [sdb] tag#16 CDB: opcode=0x28 28 00 01 16 a3 00 00 00 08 00
[ 779.055205] blk_update_request: I/O error, dev sdb, sector 18260736
[ 779.055212] md/raid1:md0: sda: unrecoverable I/O read error for block 17998592
[ 779.120448] sd 0:0:0:0: [sda] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 779.120458] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 01 16 9d 00 00 00 08 00
[ 779.120462] blk_update_request: I/O error, dev sda, sector 18259200
[ 779.127025] md/raid1:md0: sda: unrecoverable I/O read error for block 17997056
[ 779.134377] md/raid1:md0: sda: unrecoverable I/O read error for block 17997184
[ 779.141692] md/raid1:md0: sda: unrecoverable I/O read error for block 17997312
[ 779.149155] md/raid1:md0: sda: unrecoverable I/O read error for block 17997440
[ 779.156506] md/raid1:md0: sda: unrecoverable I/O read error for block 17997568
[ 779.163818] md/raid1:md0: sda: unrecoverable I/O read error for block 17997696
[ 779.171134] md/raid1:md0: sda: unrecoverable I/O read error for block 17997824
[ 779.178443] md/raid1:md0: sda: unrecoverable I/O read error for block 17997952
[ 779.185840] md/raid1:md0: sda: unrecoverable I/O read error for block 17998080
[ 779.193173] md/raid1:md0: sda: unrecoverable I/O read error for block 17998208
[ 779.200711] md: checkpointing resync of md0.
[ 779.200750] md: super_written gets error=-5
[ 779.200840] md: super_written gets error=-5
[ 779.200876] RAID1 conf printout:
[ 779.200881] --- wd:1 rd:2
[ 779.200885] disk 0, wo:0, o:1, dev:sda
[ 779.200888] disk 1, wo:1, o:0, dev:sdb
[ 779.222612] RAID1 conf printout:
[ 779.222618] --- wd:1 rd:2
[ 779.222622] disk 0, wo:0, o:1, dev:sda
[ 779.222690] md: super_written gets error=-5
[ 779.222748] md: super_written gets error=-5
[ 779.222795] md: super_written gets error=-5
[ 779.222854] md: resync of RAID array md0
[ 779.222858] md: minimum _guaranteed_ speed: 1000 KB/sec/disk.
[ 779.222861] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for resync.
[ 779.222866] md: using 128k window, over a total of 1953383360k.
[ 779.223057] md: md0: resync done.
[ 779.223275] md: super_written gets error=-5
[ 779.223323] md: super_written gets error=-5
[ 1205.064107] scsi_io_completion: 26 callbacks suppressed
[ 1205.064121] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 1205.064129] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 e8 e0 88 00 00 00 08 00
[ 1205.064133] blk_update_request: 26 callbacks suppressed
[ 1205.064137] blk_update_request: I/O error, dev sda, sector 3907028992
[ 1205.070630] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 1205.070636] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 e8 e0 88 00 00 00 08 00
[ 1205.070640] blk_update_request: I/O error, dev sda, sector 3907028992
[ 1205.077123] Buffer I/O error on dev sda, logical block 488378624, async page read
[ 1205.085128] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 1205.085137] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 e8 e0 87 00 00 00 08 00
[ 1205.085142] blk_update_request: I/O error, dev sda, sector 3907028736
[ 1205.091651] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 1205.091658] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 e8 e0 87 00 00 00 08 00
[ 1205.091662] blk_update_request: I/O error, dev sda, sector 3907028736
[ 1205.098136] Buffer I/O error on dev md0, logical block 488345824, async page read
[ 1205.106155] sd 1:0:0:0: [sdb] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 1205.106164] sd 1:0:0:0: [sdb] tag#27 CDB: opcode=0x28 28 00 e8 e0 88 00 00 00 08 00
[ 1205.106169] blk_update_request: I/O error, dev sdb, sector 3907028992
[ 1205.112759] sd 1:0:0:0: [sdb] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 1205.112766] sd 1:0:0:0: [sdb] tag#28 CDB: opcode=0x28 28 00 e8 e0 88 00 00 00 08 00
[ 1205.112770] blk_update_request: I/O error, dev sdb, sector 3907028992
[ 1205.119228] Buffer I/O error on dev sdb, logical block 488378624, async page read
[ 1205.127186] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 1205.127199] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 e8 e0 87 00 00 00 08 00
[ 1205.127206] blk_update_request: I/O error, dev sda, sector 3907028736
[ 1205.133738] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 1205.133745] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 e8 e0 87 00 00 00 08 00
[ 1205.133749] blk_update_request: I/O error, dev sda, sector 3907028736
[ 1205.140227] Buffer I/O error on dev md0, logical block 488345824, async page read
[ 1828.017218] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 1828.017230] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x1b 1b 00 00 00 00 00
[ 1828.017298] sd 1:0:0:0: [sdb] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[ 1828.017305] sd 1:0:0:0: [sdb] tag#30 CDB: opcode=0x1b 1b 00 00 00 00 00
I followed a similar process on my friend’s Turris, which resulted in a similar situation. I also ran badblocks -v
on both of my friend’s HDDs, but no bad blocks were reported.
What am I doing wrong? I can’t believe that 2 sets of HDDs would fail like this.
Any assistance is greatly appreciated.
