HI there,
I’m looking for specification what voltage and what pins in connector are used for PoE.
I have Ubiquiti carrier PoE adapter in drawer which is giving 24V on ethernet pins 4,5 + and 7,8 -
Is this correct injector or there is different requirement for MOX?
Well, powering by a different PoE (non-)standard can be possible by replacing the Ag5300 daughterboard on the PoE module with a different board. See the pinout.
