Hello
the Qualcomm Atheros QCA9880 802.11bgnac (radio0) is not stable and go down!
after reboot it is there…
have a nice day
vinc
from your post I didn’t find any useful informations except it went down.
Can you provide more details about it?
Is there something about it in file - “messages”?
i do some configuration like changing the chanel and it goes down.
After a reboot sometimes it is up sometime not. and the log is now without information - it is up.
You mean administration for 5 GHz WiFi went down or yours WiFi?
Cant it be related to 500 - Internal Server Error on /wireless/radio0.network1 ?
If you have it in DFS channels/frequencies the card will stop communication until it is sure there are no radars in the frequency. It can take a minute or two before it resumes communications.
Same here. Qualcomm Atheros QCA9880 802.11bgnac (radio0) is super unstable. Using channel 48. Generic 802.11ac Wireless Controller (radio0) shows 0%. The PCI light at the front of the router is off. Only way is to switch off the router and switch it back. Then it’ll fail again a few hours later.
It’s actually really bad since the last router updates…
Firmware version: OpenWrt omnia 15.05 r47055 / LuCI 5ca9e5d2391f6ca149db4e53cda7c8f5d3ef6644 branch (git-16.335.29518-5ca9e5d)
Kernel version: 4.4.35-34abcd5e548fc8ed5390269f3a31d173-15
This is beyond annoying…
in my configuration:
PCI1 = always off (nothing on it)
PCI2 = Qualcomm Atheros QCA9880 802.11bgnac (radio0)
PCI3 = Generic MAC80211 802.11bgn (radio1)
Are all the other settings good?
iw reg get
vi /etc/config/wireless
country = (your country)…do try a European country first.
Also try channel 36 for couple of days and see how that goes.The TX-power put it at MAX 20.
root@turris:~# iw reg get
country GB: DFS-ETSI
(2402 - 2482 @ 40), (N/A, 20), (N/A)
(5170 - 5250 @ 80), (N/A, 20), (N/A)
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS
(5490 - 5710 @ 160), (N/A, 27), (0 ms), DFS
(57000 - 66000 @ 2160), (N/A, 40), (N/A)
TX Power already on 20
root@turris:~# cat /etc/config/wireless
config wifi-device 'radio0’
option type 'mac80211’
option hwmode '11a’
option path 'platform/soc/soc:pcie-controller/pci0000:00/0000:00:02.0/0000:02:00.0’
option htmode 'VHT80’
option disabled '0’
option channel '48’
option txpower '23’
option country ‘GB’
config wifi-iface
option device 'radio0’
option network 'lan’
option mode 'ap’
option disabled '0’
option ssid 'ZZZ1’
option encryption 'psk2+tkip+aes’
option key ‘something’
config wifi-device 'radio1’
option hwmode '11g’
option path 'platform/soc/soc:pcie-controller/pci0000:00/0000:00:01.0/0000:01:00.0’
option htmode 'HT20’
option disabled '0’
option channel 'auto’
option txpower '19’
option country ‘GB’
config wifi-iface
option device 'radio1’
option mode 'ap’
option disabled '0’
option ssid 'ZZZ’
To be on the safe side also set option txpower ‘23’ on 20 in your wireless config. Then try channel 36 to be used
Then give it a
ifconfig wlan0 down
ifconfig wlan0 up
and disable and enable it through LuCI.
Because i also have trouble with it on every other channel besides channel 36.
Ok. Done that.
Let’s see.
Note: This morning the PCI2 was off again… So had to switch off/on the Turris again.
You can try to disable tkip, if you don’t use it.
option encryption 'psk2+ccmp’
Just my opinion. Do you have any apples?
So you mean leave the Wireless Security on Auto instead of the default "Force TKIP and CCMP (AES)?
Could you tell me me the logic behind this? Just so I understand
Mostly Apple devices but also Sky, Sony TV, PS4, etc…
Looks like my Macbook Pro disconnected… This was in /var/log/messages
2016-12-11T13:53:43+00:00 info hostapd[]: wlan0: STA 6c:40:08:b2:24:94 IEEE 802.11: disconnected due to excessive missing ACKs
2016-12-11T13:53:43+00:00 warning kernel[]: [ 6299.958332] ath10k_pci 0000:02:00.0: removing peer, htt peer unmap vdev 0 peer 6c:40:08:b2:24:94 id 353
2016-12-11T13:53:44+00:00 debug kernel[]: [ 6300.794536] ath10k_pci 0000:02:00.0: ath10k_pci ATH10K_DBG_BUFFER:
2016-12-11T13:53:44+00:00 debug kernel[]: [ 6300.794546] ath10k: [0000]: 006286D3 10004C1C 00438D38 00000000 00000000 000000E0 006286D3 14005C02
2016-12-11T13:53:44+00:00 debug kernel[]: [ 6300.794551] ath10k: [0008]: 0043F834 009B8A58 B208406C 00009424 00000001 006286D3 10004C37 71109988
2016-12-11T13:53:44+00:00 debug kernel[]: [ 6300.794556] ath10k: [0016]: 00438D38 009BB1A4 00000011 006286D3 14004C37 00438D38 0043DCC0 00000000
2016-12-11T13:53:44+00:00 debug kernel[]: [ 6300.794561] ath10k: [0024]: 0000000C 00001D8E 006286D3 14004C37 00438D38 009BB1EC 00000006 0000000C
2016-12-11T13:53:44+00:00 debug kernel[]: [ 6300.794565] ath10k: [0032]: 00003D02 006286D3 0C004C30 711000BB 0041EEFC 00438D38
2016-12-11T13:53:44+00:00 debug kernel[]: [ 6300.794569] ath10k_pci 0000:02:00.0: ATH10K_END
2016-12-11T13:53:59+00:00 info hostapd[]: wlan0: STA 9c:d2:1e:28:32:dc WPA: group key handshake completed (RSN)
2016-12-11T13:53:59+00:00 info hostapd[]: wlan0: STA d0:4f:7e:55:4b:8b WPA: group key handshake completed (RSN)
2016-12-11T13:54:00+00:00 info hostapd[]: wlan0: STA 2c:33:61:a8:c3:9a WPA: group key handshake completed (RSN)
2016-12-11T13:54:01+00:00 info /usr/sbin/cron[13101]: (root) CMD (nethist_stats.lua)
2016-12-11T13:54:01+00:00 info /usr/sbin/cron[13102]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2016-12-11T13:54:03+00:00 debug kernel[]: [ 6319.794853] ath10k_pci 0000:02:00.0: ath10k_pci ATH10K_DBG_BUFFER:
2016-12-11T13:54:03+00:00 debug kernel[]: [ 6319.794864] ath10k: [0000]: 0062D3E9 10004C1D 00438C98 00000001 00000000 00000140 0062D3E9 10004C1D
2016-12-11T13:54:03+00:00 debug kernel[]: [ 6319.794869] ath10k: [0008]: 00438C98 00000001 00000004 00000140
2016-12-11T13:54:03+00:00 debug kernel[]: [ 6319.794873] ath10k_pci 0000:02:00.0: ATH10K_END
2016-12-11T13:54:07+00:00 info hostapd[]: wlan0: STA 6c:40:08:b2:24:94 IEEE 802.11: deauthenticated due to local deauth request
2016-12-11T13:55:01+00:00 info hostapd[]: wlan0: STA 6c:40:08:b2:24:94 IEEE 802.11: authenticated
2016-12-11T13:55:01+00:00 warning kernel[]: [ 6378.362620] ath10k_pci 0000:02:00.0: htt peer map vdev 0 peer 6c:40:08:b2:24:94 id 353
2016-12-11T13:55:01+00:00 info hostapd[]: wlan0: STA 6c:40:08:b2:24:94 IEEE 802.11: associated (aid 1)
2016-12-11T13:55:01+00:00 warning kernel[]: [ 6378.363582] ath10k_pci 0000:02:00.0: band: 1 ratemask: 0xffffffff hw-nss: 3
2016-12-11T13:55:01+00:00 info hostapd[]: wlan0: STA 6c:40:08:b2:24:94 RADIUS: starting accounting session CA458A75FF2A0979
2016-12-11T13:55:01+00:00 info hostapd[]: wlan0: STA 6c:40:08:b2:24:94 WPA: pairwise key handshake completed (RSN)
2016-12-11T13:55:01+00:00 info /usr/sbin/cron[13143]: (root) CMD (/usr/bin/watchdog.sh)
2016-12-11T13:55:01+00:00 info /usr/sbin/cron[13144]: (root) CMD ( /usr/bin/notifier)
2016-12-11T13:55:01+00:00 info /usr/sbin/cron[13145]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796107] ath10k_pci 0000:02:00.0: ath10k_pci ATH10K_DBG_BUFFER:
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796117] ath10k: [0000]: 0063C074 14004C2F 00000161 0041F04C 00439058 00000000 00000000 0063C074
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796123] ath10k: [0008]: 14004C36 00439058 009BB504 00000011 00000000 00003D20 0063C074 14004C36
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796128] ath10k: [0016]: 00439058 0043DCC0 00000000 0000000C 00001D00 0063C074 14004C2A C6072421
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796132] ath10k: [0024]: F0040000 0000C607 2421F004 0000010C 0063C074 14005C03 00000000 B208406C
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796137] ath10k: [0032]: 00009424 009B8A58 00439058 0063C076 14004C32 00439058 00000080 00000001
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796141] ath10k: [0040]: 00000002 00000208 0063C076 17FC2801 71100B07 070A0003 0601B003 0000FFEA
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796145] ath10k: [0048]: 00FFFFFF 0063C076 17FC2801 71108880 00000008 00449CA8 00960043 00000FF0
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796150] ath10k: [0056]: 0063C076 17FC2801 71108880 0001000C 00449CA8 00960043 00F03C0F 0063C076
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796154] ath10k: [0064]: 17FC2801 71108880 0002000C 00449CA8 00960043 00F03C0F 0063C076 17FC2801
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796158] ath10k: [0072]: 71108880 0003000C 00449CA8 00960043 3F007007 0063C076 17FC2801 71108880
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796163] ath10k: [0080]: 0004000C 00449CA8 00960043 3F007007 0063C076 17FC2801 71108880 0005000B
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796167] ath10k: [0088]: 00449CA8 00960043 3B007007 0063C077 14004C36 00439058 009BB54C 00000006
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796172] ath10k: [0096]: 0000000C 00003D00 0063C08A 10004C1C 00439058 00000000 00000006 000000C0
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796176] ath10k: [0104]: 0063C08A 14004C32 00439058 000000E0 00000001 00000002 00004208 0063C090
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796180] ath10k: [0112]: 14004C24 00439058 00000000 00000000 00000040 00000001 0063C090 17FC2801
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796184] ath10k: [0120]: 71100B07 070A0003 0601B003 0000FFEA 00FFFFFF 0063C090 17FC2801 71108880
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796189] ath10k: [0128]: 00000008 00442EC8 00960043 00000FF0 0063C090 17FC2801 71108880 0001000C
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796193] ath10k: [0136]: 00442EC8 00960043 00F03C0F 0063C090 17FC2801 71108880 0002000C 00442EC8
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796199] ath10k: [0144]: 00960043 00F03C0F 0063C090 17FC2801 71108880 0003000C 00442EC8 00960043
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796203] ath10k: [0152]: 3F007007 0063C090 17FC2801 71108880 0004000C 00442EC8 00960043 3F007007
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796208] ath10k: [0160]: 0063C090 17FC2801 71108880 0005000B 00442EC8 00960043 3B007007
2016-12-11T13:55:02+00:00 debug kernel[]: [ 6378.796212] ath10k_pci 0000:02:00.0: ATH10K_END
2016-12-11T13:55:06+00:00 warning watchdog[]: Restarted nethist
No, I have the Encryption: WPA2 PSK (CCMP) “Force CCMP (AES)”. It helped me from this security behavior of OS X.
And also I have since that change Wi-Fi switched on. Just a note is set in LUCI. I have to also change the password in the LUCI. If you change password in FORIS than it returns to "Force TKIP and CCMP (AES). I will report it next week as feature request, but before that I want to complete the update of the system.
Please dont do post/create another thread about ath10k driver.
–> Ath10k (5GHz card) after upgrade to 3.3
