Trying out a new WiFi card with my Turris Mox and kernel is unable to initialize the module. The module is designed specifically for compatibility with the ath10k driver and OpenWRT installations, which MOX is compatible with.
Not sure what is happening, will try in my PC. Attached is PDF with documentation on the WiFi module, everything indicates should be compatible with no issue.
Here is a link to the module with a datasheet:
Any help getting the module to work very appreciated, currently have WiFi down for testing and also have a small PCI to mPCI adapter I can use to insert the module into full Linux or Windows system for any testing or update.
Would like to get this module to work with my MOX.
The ath10k driver fails to initialize the module, as in the below output:
Feb 27 16:29:48 MOXi kernel: [ 10.868581] ath10k 4.19 driver, optimized for CT firmware, probing pci device: 0x46.
Feb 27 16:29:48 MOXi kernel: [ 10.877701] ath10k_pci 0000:00:00.0: enabling device (0000 -> 0002)
Feb 27 16:29:48 MOXi kernel: [ 10.884680] ath10k_pci 0000:00:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
Feb 27 16:29:48 MOXi kernel: [ 11.056424] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/fwcfg-pci-0000:00:00.0.txt failed with error -2
Feb 27 16:29:48 MOXi kernel: [ 11.067563] ath10k_pci 0000:00:00.0: Falling back to user helper
Feb 27 16:29:48 MOXi kernel: [ 11.947690] firmware ath10k!fwcfg-pci-0000:00:00.0.txt: firmware_loading_store: map pages failed
Feb 27 16:29:48 MOXi kernel: [ 11.956749] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
Feb 27 16:29:48 MOXi kernel: [ 11.967687] ath10k_pci 0000:00:00.0: Falling back to user helper
Feb 27 16:29:48 MOXi kernel: [ 11.983494] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
Feb 27 16:29:48 MOXi kernel: [ 11.993145] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/cal-pci-0000:00:00.0.bin failed with error -2
Feb 27 16:29:48 MOXi kernel: [ 12.003943] ath10k_pci 0000:00:00.0: Falling back to user helper
Feb 27 16:29:48 MOXi kernel: [ 12.022876] firmware ath10k!cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
Feb 27 16:29:48 MOXi kernel: [ 12.032564] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9984/hw1.0/ct-firmware-5.bin failed with error -2
Feb 27 16:29:48 MOXi kernel: [ 12.044057] ath10k_pci 0000:00:00.0: Falling back to user helper
Feb 27 16:29:48 MOXi kernel: [ 12.061034] firmware ath10k!QCA9984!hw1.0!ct-firmware-5.bin: firmware_loading_store: map pages failed
Feb 27 16:29:48 MOXi kernel: [ 12.070711] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9984/hw1.0/ct-firmware-2.bin failed with error -2
Feb 27 16:29:48 MOXi kernel: [ 12.081765] ath10k_pci 0000:00:00.0: Falling back to user helper
Feb 27 16:29:48 MOXi kernel: [ 12.096750] firmware ath10k!QCA9984!hw1.0!ct-firmware-2.bin: firmware_loading_store: map pages failed
Feb 27 16:29:48 MOXi kernel: [ 12.106794] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9984/hw1.0/firmware-6.bin failed with error -2
Feb 27 16:29:48 MOXi kernel: [ 12.117997] ath10k_pci 0000:00:00.0: Falling back to user helper
Feb 27 16:29:48 MOXi kernel: [ 12.133140] firmware ath10k!QCA9984!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
Feb 27 16:29:48 MOXi kernel: [ 12.181687] ath10k_pci 0000:00:00.0: qca9984/qca9994 hw1.0 target 0x01000000 chip_id 0x00000000 sub 168c:cafe
Feb 27 16:29:48 MOXi kernel: [ 12.192353] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Feb 27 16:29:48 MOXi kernel: [ 12.216249] ath10k_pci 0000:00:00.0: firmware ver 10.4-3.9.0.2-00021 api 5 features no-p2p,mfp,peer-flow-ctrl,btcoex-param,allows-mesh-bcast,no-ps crc32 9626782c
Feb 27 16:29:48 MOXi kernel: [ 13.473151] ath10k_pci 0000:00:00.0: board_file api 2 bmi_id 0:31 crc32 cf58c3bc
Feb 27 16:29:48 MOXi kernel: [ 16.119213] ath10k_pci 0000:00:00.0: firmware crashed! (guid 5d6bfe7d-aee6-4cf8-86b4-300f4c3c6d13)
Feb 27 16:29:48 MOXi kernel: [ 16.128711] ath10k_pci 0000:00:00.0: qca9984/qca9994 hw1.0 target 0x01000000 chip_id 0x00000000 sub 168c:cafe
Feb 27 16:29:48 MOXi kernel: [ 16.139205] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Feb 27 16:29:48 MOXi kernel: [ 16.155498] ath10k_pci 0000:00:00.0: firmware ver 10.4-3.9.0.2-00021 api 5 features no-p2p,mfp,peer-flow-ctrl,btcoex-param,allows-mesh-bcast,no-ps crc32 9626782c
Feb 27 16:29:48 MOXi kernel: [ 16.172359] ath10k_pci 0000:00:00.0: board_file api 2 bmi_id 0:31 crc32 cf58c3bc
Feb 27 16:29:48 MOXi kernel: [ 16.180037] ath10k_pci 0000:00:00.0: htt-ver 0.0 wmi-op 6 htt-op 4 cal otp max-sta 32 raw 0 hwcrypto 1
Feb 27 16:29:48 MOXi kernel: [ 16.191464] ath10k_pci 0000:00:00.0: firmware register dump:
Feb 27 16:29:48 MOXi kernel: [ 16.196985] ath10k_pci 0000:00:00.0: [00]: 0x01000000 0x00000000 0x009CCC84 0x00000000
Feb 27 16:29:48 MOXi kernel: [ 16.205446] ath10k_pci 0000:00:00.0: [04]: 0x009CCC84 0x00060330 0x0000000D 0x00000000
Feb 27 16:29:48 MOXi kernel: [ 16.213458] ath10k_pci 0000:00:00.0: [08]: 0x00000004 0x00413FF0 0x00405524 0x00000001
Feb 27 16:29:48 MOXi kernel: [ 16.221843] ath10k_pci 0000:00:00.0: [12]: 0x00000000 0xFFFFFFFF 0x00973D28 0x00973D33
Feb 27 16:29:48 MOXi kernel: [ 16.229861] ath10k_pci 0000:00:00.0: [16]: 0x800E02EE 0x004069AC 0x00000004 0x00413FF0
Feb 27 16:29:48 MOXi kernel: [ 16.237970] ath10k_pci 0000:00:00.0: [20]: 0x00401F00 0x00401F04 0x00000004 0x00000000
Feb 27 16:29:48 MOXi kernel: [ 16.246260] ath10k_pci 0000:00:00.0: [24]: 0x800C383A 0x004069DC 0x00413E10 0x00400000
Feb 27 16:29:48 MOXi kernel: [ 16.254728] ath10k_pci 0000:00:00.0: [28]: 0x00000000 0x00000000 0x00413E10 0x00400000
Feb 27 16:29:48 MOXi kernel: [ 16.262671] ath10k_pci 0000:00:00.0: [32]: 0x00405524 0x00000001 0x00000000 0x00000000
Feb 27 16:29:48 MOXi kernel: [ 16.270786] ath10k_pci 0000:00:00.0: [36]: 0x809800A3 0x00406A0C 0x00413E20 0x009C53F4
Feb 27 16:29:48 MOXi kernel: [ 16.279161] ath10k_pci 0000:00:00.0: [40]: 0x00000000 0x00000000 0x0047EB48 0x00000004
Feb 27 16:29:48 MOXi kernel: [ 16.287447] ath10k_pci 0000:00:00.0: [44]: 0x00027E11 0x00000009 0x00000006 0x00000008
Feb 27 16:29:48 MOXi kernel: [ 16.295466] ath10k_pci 0000:00:00.0: [48]: 0x8098003A 0x00406A5C 0x00400000 0x00400600
Feb 27 16:29:48 MOXi kernel: [ 16.303927] ath10k_pci 0000:00:00.0: [52]: 0x80961A63 0x00406A4C 0x00400000 0x00000000
Feb 27 16:29:48 MOXi kernel: [ 16.311961] ath10k_pci 0000:00:00.0: [56]: 0xF2A56400 0x00000000 0x00402324 0x00000001
Feb 27 16:29:48 MOXi kernel: [ 16.320245] ath10k_pci 0000:00:00.0: Copy Engine register dump:
Feb 27 16:29:48 MOXi kernel: [ 16.326291] ath10k_pci 0000:00:00.0: [00]: 0x0004a000 7 7 24 23
Feb 27 16:29:48 MOXi kernel: [ 16.332859] ath10k_pci 0000:00:00.0: [01]: 0x0004a400 6 6 5 6
Feb 27 16:29:48 MOXi kernel: [ 16.339623] ath10k_pci 0000:00:00.0: [02]: 0x0004a800 0 0 127 0
Feb 27 16:29:48 MOXi kernel: [ 16.346286] ath10k_pci 0000:00:00.0: [03]: 0x0004ac00 0 0 0 0
Feb 27 16:29:48 MOXi kernel: [ 16.352944] ath10k_pci 0000:00:00.0: [04]: 0x0004b000 0 0 0 0
Feb 27 16:29:48 MOXi kernel: [ 16.359437] ath10k_pci 0000:00:00.0: [05]: 0x0004b400 0 0 0 0
Feb 27 16:29:48 MOXi kernel: [ 16.366371] ath10k_pci 0000:00:00.0: [06]: 0x0004b800 0 0 0 0
Feb 27 16:29:48 MOXi kernel: [ 16.373122] ath10k_pci 0000:00:00.0: [07]: 0x0004bc00 1 1 1 1
Feb 27 16:29:48 MOXi kernel: [ 16.379629] ath10k_pci 0000:00:00.0: [08]: 0x0004c000 0 0 127 0
Feb 27 16:29:48 MOXi kernel: [ 16.386296] ath10k_pci 0000:00:00.0: [09]: 0x0004c400 1 1 1 1
Feb 27 16:29:48 MOXi kernel: [ 16.392869] ath10k_pci 0000:00:00.0: [10]: 0x0004c800 0 0 0 0
Feb 27 16:29:48 MOXi kernel: [ 16.399718] ath10k_pci 0000:00:00.0: [11]: 0x0004cc00 0 0 0 0
Feb 27 16:29:48 MOXi kernel: [ 16.408488] ath10k_pci 0000:00:00.0: debug log header, dbuf: 0x96068c dropped: 4197376
Feb 27 16:29:48 MOXi kernel: [ 16.417536] ath10k_pci 0000:00:00.0: [0] next: 0x0 buf: 0x0 sz: 0 len: 0 count: 0 free: 0
Feb 27 16:29:48 MOXi kernel: [ 17.024394] ath10k_pci 0000:00:00.0: failed to receive control response completion, polling..
Feb 27 16:29:48 MOXi kernel: [ 18.054334] ath10k_pci 0000:00:00.0: ctl_resp never came in (-110)
Feb 27 16:29:48 MOXi kernel: [ 18.060785] ath10k_pci 0000:00:00.0: failed to connect to HTC: -110
Feb 27 16:29:48 MOXi kernel: [ 18.172859] ath10k_pci 0000:00:00.0: could not init core (-110)
Feb 27 16:29:48 MOXi kernel: [ 18.179304] ath10k_pci 0000:00:00.0: could not probe fw (-110)
Output of lshw, kernel log, and system log are below:
************** lshw
############## messages
== /var/log/messages ==
Feb 27 16:29:48 MOXi syslog-ng[2687]: syslog-ng starting up; version='3.35.1'
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Linux version 4.14.264 (packaging@turris.cz) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11397+89-524cbcf6f5)) #0 SMP Tue Feb 8 00:27:12 2022
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Machine model: CZ.NIC Turris Mox Board
Feb 27 16:29:48 MOXi kernel: [ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '')
Feb 27 16:29:48 MOXi kernel: [ 0.000000] bootconsole [ar3700_uart0] enabled
Feb 27 16:29:48 MOXi kernel: [ 0.000000] On node 0 totalpages: 262144
Feb 27 16:29:48 MOXi kernel: [ 0.000000] DMA zone: 4096 pages used for memmap
Feb 27 16:29:48 MOXi kernel: [ 0.000000] DMA zone: 0 pages reserved
Feb 27 16:29:48 MOXi kernel: [ 0.000000] DMA zone: 262144 pages, LIFO batch:31
Feb 27 16:29:48 MOXi kernel: [ 0.000000] psci: probing for conduit method from DT.
Feb 27 16:29:48 MOXi kernel: [ 0.000000] psci: PSCIv1.1 detected in firmware.
Feb 27 16:29:48 MOXi kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Feb 27 16:29:48 MOXi kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Feb 27 16:29:48 MOXi kernel: [ 0.000000] psci: SMC Calling Convention v1.1
Feb 27 16:29:48 MOXi kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x9c/0x494 with crng_init=0
Feb 27 16:29:48 MOXi kernel: [ 0.000000] percpu: Embedded 16 pages/cpu s26648 r8192 d30696 u65536
Feb 27 16:29:48 MOXi kernel: [ 0.000000] pcpu-alloc: s26648 r8192 d30696 u65536 alloc=16*4096
Feb 27 16:29:48 MOXi kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Detected VIPT I-cache on CPU0
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Speculative Store Bypass Disable mitigation not required
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Kernel command line: earlyprintk console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 mangled_fs=btrfs root=PARTUUID=00000000-01 rootflags=commit=5,subvol=@ rootwait rw cfg80211.freg=
Feb 27 16:29:48 MOXi kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Memory: 1019804K/1048576K available (7422K kernel code, 476K rwdata, 1940K rodata, 320K init, 304K bss, 28772K reserved, 0K cma-reserved)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Virtual kernel memory layout:
Feb 27 16:29:48 MOXi kernel: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] .text : 0xffffff8008080000 - 0xffffff80087c0000 ( 7424 KB)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] .rodata : 0xffffff80087c0000 - 0xffffff80089b0000 ( 1984 KB)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] .init : 0xffffff80089b0000 - 0xffffff8008a00000 ( 320 KB)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] .data : 0xffffff8008a00000 - 0xffffff8008a77008 ( 477 KB)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] .bss : 0xffffff8008a77008 - 0xffffff8008ac31a8 ( 305 KB)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
Feb 27 16:29:48 MOXi kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Feb 27 16:29:48 MOXi kernel: [ 0.000000] Hierarchical RCU implementation.
Feb 27 16:29:48 MOXi kernel: [ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32
Feb 27 16:29:48 MOXi kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Feb 27 16:29:48 MOXi kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Feb 27 16:29:48 MOXi kernel: [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Feb 27 16:29:48 MOXi kernel: [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Feb 27 16:29:48 MOXi kernel: [ 0.000000] GICv3: no VLPI support, no direct LPI support
Feb 27 16:29:48 MOXi kernel: [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000d1d40000
Feb 27 16:29:48 MOXi kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
Feb 27 16:29:48 MOXi kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
Feb 27 16:29:48 MOXi kernel: [ 0.000004] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
Feb 27 16:29:48 MOXi kernel: [ 0.008435] Console: colour dummy device 80x25
Feb 27 16:29:48 MOXi kernel: [ 0.012945] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=125000)
Feb 27 16:29:48 MOXi kernel: [ 0.023594] pid_max: default: 32768 minimum: 301
Feb 27 16:29:48 MOXi kernel: [ 0.028448] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
Feb 27 16:29:48 MOXi kernel: [ 0.035281] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
Feb 27 16:29:48 MOXi kernel: [ 0.043628] ASID allocator initialised with 32768 entries
Feb 27 16:29:48 MOXi kernel: [ 0.049208] Hierarchical SRCU implementation.
Feb 27 16:29:48 MOXi kernel: [ 0.054087] smp: Bringing up secondary CPUs ...
Feb 27 16:29:48 MOXi kernel: [ 0.059048] Detected VIPT I-cache on CPU1
Feb 27 16:29:48 MOXi kernel: [ 0.059078] GICv3: CPU1: found redistributor 1 region 0:0x00000000d1d60000
Feb 27 16:29:48 MOXi kernel: [ 0.059108] CPU1: Booted secondary processor [410fd034]
Feb 27 16:29:48 MOXi kernel: [ 0.059196] smp: Brought up 1 node, 2 CPUs
Feb 27 16:29:48 MOXi kernel: [ 0.079903] SMP: Total of 2 processors activated.
Feb 27 16:29:48 MOXi kernel: [ 0.084750] CPU features: detected: GIC system register CPU interface
Feb 27 16:29:48 MOXi kernel: [ 0.091371] CPU features: detected: 32-bit EL0 Support
Feb 27 16:29:48 MOXi kernel: [ 0.096671] CPU: All CPU(s) started at EL2
Feb 27 16:29:48 MOXi kernel: [ 0.100882] alternatives: patching kernel code
Feb 27 16:29:48 MOXi kernel: [ 0.106219] devtmpfs: initialized
Feb 27 16:29:48 MOXi kernel: [ 0.111947] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Feb 27 16:29:48 MOXi kernel: [ 0.122048] futex hash table entries: 512 (order: 4, 65536 bytes)
Feb 27 16:29:48 MOXi kernel: [ 0.128381] xor: measuring software checksum speed
Feb 27 16:29:48 MOXi kernel: [ 0.233281] 8regs : 1918.800 MB/sec
Feb 27 16:29:48 MOXi kernel: [ 0.333312] 8regs_prefetch: 1710.400 MB/sec
Feb 27 16:29:48 MOXi kernel: [ 0.433346] 32regs : 2358.800 MB/sec
Feb 27 16:29:48 MOXi kernel: [ 0.533378] 32regs_prefetch: 1984.400 MB/sec
Feb 27 16:29:48 MOXi kernel: [ 0.538045] xor: using function: 32regs (2358.800 MB/sec)
Feb 27 16:29:48 MOXi kernel: [ 0.543611] pinctrl core: initialized pinctrl subsystem
Feb 27 16:29:48 MOXi kernel: [ 0.549685] NET: Registered protocol family 16
Feb 27 16:29:48 MOXi kernel: [ 0.555256] cpuidle: using governor ladder
Feb 27 16:29:48 MOXi kernel: [ 0.559539] vdso: 2 pages (1 code @ ffffff80087c5000, 1 data @ ffffff8008a04000)
Feb 27 16:29:48 MOXi kernel: [ 0.567111] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Feb 27 16:29:48 MOXi kernel: [ 0.574323] DMA: preallocated 256 KiB pool for atomic allocations
Feb 27 16:29:48 MOXi kernel: [ 0.581834] d0012000.serial: ttyMV0 at MMIO 0xd0012000 (irq = 9, base_baud = 0) is a mvebu-uart
Feb 27 16:29:48 MOXi kernel: [ 0.590778] console [ttyMV0] enabled
Feb 27 16:29:48 MOXi kernel: [ 0.598081] bootconsole [ar3700_uart0] disabled
Feb 27 16:29:48 MOXi kernel: [ 0.787686] raid6: int64x1 gen() 321 MB/s
Feb 27 16:29:48 MOXi kernel: [ 0.957707] raid6: int64x1 xor() 317 MB/s
Feb 27 16:29:48 MOXi kernel: [ 1.127804] raid6: int64x2 gen() 521 MB/s
Feb 27 16:29:48 MOXi kernel: [ 1.297851] raid6: int64x2 xor() 450 MB/s
Feb 27 16:29:48 MOXi kernel: [ 1.467906] raid6: int64x4 gen() 779 MB/s
Feb 27 16:29:48 MOXi kernel: [ 1.637955] raid6: int64x4 xor() 551 MB/s
Feb 27 16:29:48 MOXi kernel: [ 1.808038] raid6: int64x8 gen() 939 MB/s
Feb 27 16:29:48 MOXi kernel: [ 1.978152] raid6: int64x8 xor() 562 MB/s
Feb 27 16:29:48 MOXi kernel: [ 2.148196] raid6: neonx1 gen() 593 MB/s
Feb 27 16:29:48 MOXi kernel: [ 2.318302] raid6: neonx1 xor() 625 MB/s
Feb 27 16:29:48 MOXi kernel: [ 2.488383] raid6: neonx2 gen() 985 MB/s
Feb 27 16:29:48 MOXi kernel: [ 2.658410] raid6: neonx2 xor() 947 MB/s
Feb 27 16:29:48 MOXi kernel: [ 2.828490] raid6: neonx4 gen() 1312 MB/s
Feb 27 16:29:48 MOXi kernel: [ 2.998566] raid6: neonx4 xor() 1171 MB/s
Feb 27 16:29:48 MOXi kernel: [ 3.168669] raid6: neonx8 gen() 1297 MB/s
Feb 27 16:29:48 MOXi kernel: [ 3.338725] raid6: neonx8 xor() 1132 MB/s
Feb 27 16:29:48 MOXi kernel: [ 3.342867] raid6: using algorithm neonx4 gen() 1312 MB/s
Feb 27 16:29:48 MOXi kernel: [ 3.348352] raid6: .... xor() 1171 MB/s, rmw enabled
Feb 27 16:29:48 MOXi kernel: [ 3.353393] raid6: using neon recovery algorithm
Feb 27 16:29:48 MOXi kernel: [ 3.359342] SCSI subsystem initialized
Feb 27 16:29:48 MOXi kernel: [ 3.363640] libata version 3.00 loaded.
Feb 27 16:29:48 MOXi kernel: [ 3.363866] usbcore: registered new interface driver usbfs
Feb 27 16:29:48 MOXi kernel: [ 3.369239] usbcore: registered new interface driver hub
Feb 27 16:29:48 MOXi kernel: [ 3.374761] usbcore: registered new device driver usb
Feb 27 16:29:48 MOXi kernel: [ 3.380629] pxa2xx-i2c d0011000.i2c: could not find pctldev for node /soc/internal-regs@d0000000/pinctrl@13800/i2c1-pins, deferring probe
Feb 27 16:29:48 MOXi kernel: [ 3.394314] clocksource: Switched to clocksource arch_sys_counter
Feb 27 16:29:48 MOXi kernel: [ 3.407132] NET: Registered protocol family 2
Feb 27 16:29:48 MOXi kernel: [ 3.411719] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
Feb 27 16:29:48 MOXi kernel: [ 3.419152] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Feb 27 16:29:48 MOXi kernel: [ 3.426357] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
Feb 27 16:29:48 MOXi kernel: [ 3.433234] TCP: Hash tables configured (established 8192 bind 8192)
Feb 27 16:29:48 MOXi kernel: [ 3.439969] UDP hash table entries: 512 (order: 2, 16384 bytes)
Feb 27 16:29:48 MOXi kernel: [ 3.446122] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Feb 27 16:29:48 MOXi kernel: [ 3.452837] NET: Registered protocol family 1
Feb 27 16:29:48 MOXi kernel: [ 3.456927] PCI: CLS 0 bytes, default 128
Feb 27 16:29:48 MOXi kernel: [ 3.457559] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Feb 27 16:29:48 MOXi kernel: [ 3.469323] Crashlog allocated RAM at address 0x3f00000
Feb 27 16:29:48 MOXi kernel: [ 3.475116] workingset: timestamp_bits=46 max_order=18 bucket_order=0
Feb 27 16:29:48 MOXi kernel: [ 3.486068] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Feb 27 16:29:48 MOXi kernel: [ 3.491667] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Feb 27 16:29:48 MOXi kernel: [ 3.505389] io scheduler noop registered
Feb 27 16:29:48 MOXi kernel: [ 3.509453] io scheduler deadline registered (default)
Feb 27 16:29:48 MOXi kernel: [ 3.514804] io scheduler bfq registered
Feb 27 16:29:48 MOXi kernel: [ 3.521943] OF: PCI: host bridge /soc/pcie@d0070000 ranges:
Feb 27 16:29:48 MOXi kernel: [ 3.527591] OF: PCI: MEM 0xe8000000..0xefefffff -> 0xe8000000
Feb 27 16:29:48 MOXi kernel: [ 3.533832] OF: PCI: IO 0xefff0000..0xefffffff -> 0xefff0000
Feb 27 16:29:48 MOXi kernel: [ 3.540088] advk-pcie d0070000.pcie: issuing PERST via reset GPIO for 10ms
Feb 27 16:29:48 MOXi kernel: [ 3.654246] advk-pcie d0070000.pcie: link up
Feb 27 16:29:48 MOXi kernel: [ 3.658442] advk-pcie d0070000.pcie: PCI host bridge to bus 0000:00
Feb 27 16:29:48 MOXi kernel: [ 3.664794] pci_bus 0000:00: root bus resource [bus 00-ff]
Feb 27 16:29:48 MOXi kernel: [ 3.670710] pci_bus 0000:00: root bus resource [mem 0xe8000000-0xefefffff]
Feb 27 16:29:48 MOXi kernel: [ 3.677463] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0xefff0000-0xefffffff])
Feb 27 16:29:48 MOXi kernel: [ 3.687683] pci 0000:00:00.0: [168c:0046] type 00 class 0x028000
Feb 27 16:29:48 MOXi kernel: [ 3.687790] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
Feb 27 16:29:48 MOXi kernel: [ 3.688101] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
Feb 27 16:29:48 MOXi kernel: [ 3.688264] pci 0000:00:00.0: BAR 0: assigned [mem 0xe8000000-0xe81fffff 64bit]
Feb 27 16:29:48 MOXi kernel: [ 3.697215] mv_xor d0060900.xor: Marvell shared XOR driver
Feb 27 16:29:48 MOXi kernel: [ 3.764835] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Feb 27 16:29:48 MOXi kernel: [ 3.834817] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Feb 27 16:29:48 MOXi kernel: [ 3.842582] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Feb 27 16:29:48 MOXi kernel: [ 3.851109] cacheinfo: Unable to detect cache hierarchy for CPU 0
Feb 27 16:29:48 MOXi kernel: [ 3.860586] loop: module loaded
Feb 27 16:29:48 MOXi kernel: [ 3.869980] random: fast init done
Feb 27 16:29:48 MOXi kernel: [ 3.878277] m25p80 spi0.0: w25q64dw (8192 Kbytes)
Feb 27 16:29:48 MOXi kernel: [ 3.883012] 5 fixed-partitions partitions found on MTD device spi0.0
Feb 27 16:29:48 MOXi kernel: [ 3.889366] Creating 5 MTD partitions on "spi0.0":
Feb 27 16:29:48 MOXi kernel: [ 3.894390] 0x000000000000-0x000000020000 : "secure-firmware"
Feb 27 16:29:48 MOXi kernel: [ 3.900894] 0x000000020000-0x000000180000 : "u-boot"
Feb 27 16:29:48 MOXi kernel: [ 3.906185] 0x000000180000-0x000000190000 : "u-boot-env"
Feb 27 16:29:48 MOXi kernel: [ 3.911766] 0x000000190000-0x0000007f0000 : "Rescue system"
Feb 27 16:29:48 MOXi kernel: [ 3.917829] 0x0000007f0000-0x000000800000 : "dtb"
Feb 27 16:29:48 MOXi kernel: [ 3.923340] moxtet spi0.1: Found SD Turris Mox CPU module
Feb 27 16:29:48 MOXi kernel: [ 3.928963] moxtet spi0.1: PCIe module found
Feb 27 16:29:48 MOXi kernel: [ 3.933198] moxtet spi0.1: Topaz Switch module found
Feb 27 16:29:48 MOXi kernel: [ 3.941275] mv88e6085 d0032004.mdio-mii:02: switch 0x3400 detected: Marvell 88E6141, revision 0
Feb 27 16:29:48 MOXi kernel: [ 3.976331] mvneta d0030000.ethernet eth0: Using device tree mac address d8:58:d7:00:b6:ba
Feb 27 16:29:48 MOXi kernel: [ 3.986201] mvneta d0040000.ethernet eth1: Using device tree mac address d8:58:d7:00:b6:bb
Feb 27 16:29:48 MOXi kernel: [ 3.994956] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Feb 27 16:29:48 MOXi kernel: [ 4.001446] ehci-pci: EHCI PCI platform driver
Feb 27 16:29:48 MOXi kernel: [ 4.006294] ehci-platform: EHCI generic platform driver
Feb 27 16:29:48 MOXi kernel: [ 4.011458] ehci-orion: EHCI orion driver
Feb 27 16:29:48 MOXi kernel: [ 4.016022] orion-ehci d005e000.usb: EHCI Host Controller
Feb 27 16:29:48 MOXi kernel: [ 4.021548] orion-ehci d005e000.usb: new USB bus registered, assigned bus number 1
Feb 27 16:29:48 MOXi kernel: [ 4.029362] orion-ehci d005e000.usb: irq 13, io mem 0xd005e000
Feb 27 16:29:48 MOXi kernel: [ 4.064263] orion-ehci d005e000.usb: USB 2.0 started, EHCI 1.00
Feb 27 16:29:48 MOXi kernel: [ 4.070960] hub 1-0:1.0: USB hub found
Feb 27 16:29:48 MOXi kernel: [ 4.074631] hub 1-0:1.0: 1 port detected
Feb 27 16:29:48 MOXi kernel: [ 4.079794] usbcore: registered new interface driver usb-storage
Feb 27 16:29:48 MOXi kernel: [ 4.086223] i2c /dev entries driver
Feb 27 16:29:48 MOXi kernel: [ 4.090472] armada_37xx_wdt d0008300.watchdog: Initial timeout 120 sec
Feb 27 16:29:48 MOXi kernel: [ 4.097832] sdhci: Secure Digital Host Controller Interface driver
Feb 27 16:29:48 MOXi kernel: [ 4.104230] sdhci: Copyright(c) Pierre Ossman
Feb 27 16:29:48 MOXi kernel: [ 4.108555] sdhci-pltfm: SDHCI platform and OF driver helper
Feb 27 16:29:48 MOXi kernel: [ 4.114719] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
Feb 27 16:29:48 MOXi kernel: [ 4.120587] xenon-sdhci d00d8000.sdhci: Got CD GPIO
Feb 27 16:29:48 MOXi kernel: [ 4.126892] NET: Registered protocol family 10
Feb 27 16:29:48 MOXi kernel: [ 4.132462] Segment Routing with IPv6
Feb 27 16:29:48 MOXi kernel: [ 4.136160] NET: Registered protocol family 17
Feb 27 16:29:48 MOXi kernel: [ 4.140873] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Feb 27 16:29:48 MOXi kernel: [ 4.154523] 8021q: 802.1Q VLAN Support v1.8
Feb 27 16:29:48 MOXi kernel: [ 4.160534] Btrfs loaded, crc32c=crc32c-arm64-ce
Feb 27 16:29:48 MOXi kernel: [ 4.169516] rtc-ds1307 0-006f: registered as rtc0
Feb 27 16:29:48 MOXi kernel: [ 4.173991] i2c i2c-0: PXA I2C adapter
Feb 27 16:29:48 MOXi kernel: [ 4.178477] mv88e6085 d0032004.mdio-mii:02: switch 0x3400 detected: Marvell 88E6141, revision 0
Feb 27 16:29:48 MOXi kernel: [ 4.207447] DSA: switch 0 0 parsed
Feb 27 16:29:48 MOXi kernel: [ 4.210617] DSA: tree 0 parsed
Feb 27 16:29:48 MOXi kernel: [ 4.926211] mv88e6085 d0032004.mdio-mii:02 lan1 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:11] driver [Marvell 88E6390]
Feb 27 16:29:48 MOXi kernel: [ 5.036222] mv88e6085 d0032004.mdio-mii:02 lan2 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:12] driver [Marvell 88E6390]
Feb 27 16:29:48 MOXi kernel: [ 5.146215] mv88e6085 d0032004.mdio-mii:02 lan3 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:13] driver [Marvell 88E6390]
Feb 27 16:29:48 MOXi kernel: [ 5.256217] mv88e6085 d0032004.mdio-mii:02 lan4 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:14] driver [Marvell 88E6390]
Feb 27 16:29:48 MOXi kernel: [ 5.273391] xhci-hcd d0058000.usb: xHCI Host Controller
Feb 27 16:29:48 MOXi kernel: [ 5.278581] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 2
Feb 27 16:29:48 MOXi kernel: [ 5.286489] xhci-hcd d0058000.usb: hcc params 0x0a000998 hci version 0x100 quirks 0x0000000000010010
Feb 27 16:29:48 MOXi kernel: [ 5.295723] xhci-hcd d0058000.usb: irq 12, io mem 0xd0058000
Feb 27 16:29:48 MOXi kernel: [ 5.302058] hub 2-0:1.0: USB hub found
Feb 27 16:29:48 MOXi kernel: [ 5.305721] hub 2-0:1.0: 1 port detected
Feb 27 16:29:48 MOXi kernel: [ 5.309744] xhci-hcd d0058000.usb: xHCI Host Controller
Feb 27 16:29:48 MOXi kernel: [ 5.315137] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 3
Feb 27 16:29:48 MOXi kernel: [ 5.323029] xhci-hcd d0058000.usb: Host supports USB 3.0 SuperSpeed
Feb 27 16:29:48 MOXi kernel: [ 5.329313] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
Feb 27 16:29:48 MOXi kernel: [ 5.338272] hub 3-0:1.0: USB hub found
Feb 27 16:29:48 MOXi kernel: [ 5.341910] hub 3-0:1.0: 1 port detected
Feb 27 16:29:48 MOXi kernel: [ 5.346469] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
Feb 27 16:29:48 MOXi kernel: [ 5.414260] mmc0: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA
Feb 27 16:29:48 MOXi kernel: [ 5.422290] xenon-sdhci d00d8000.sdhci: Got CD GPIO
Feb 27 16:29:48 MOXi kernel: [ 5.484455] mmc1: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA
Feb 27 16:29:48 MOXi kernel: [ 5.496391] armada-37xx-rwtm-mailbox d00b0000.mailbox: Trust Status: 00000000
Feb 27 16:29:48 MOXi kernel: [ 5.626424] Turris Mox serial number 0000000D300013C9
Feb 27 16:29:48 MOXi kernel: [ 5.631584] board version 22
Feb 27 16:29:48 MOXi kernel: [ 5.635254] burned RAM size 1024 MiB
Feb 27 16:29:48 MOXi kernel: [ 5.896468] rtc-ds1307 0-006f: setting system clock to 2022-02-28 00:29:26 UTC (1646008166)
Feb 27 16:29:48 MOXi kernel: [ 5.896519] random: crng init done
Feb 27 16:29:48 MOXi kernel: [ 6.086548] Waiting for root device PARTUUID=00000000-01...
Feb 27 16:29:48 MOXi kernel: [ 6.189758] mmc1: new high speed SDHC card at address aaaa
Feb 27 16:29:48 MOXi kernel: [ 6.197260] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
Feb 27 16:29:48 MOXi kernel: [ 6.208787] mmcblk1: p1
Feb 27 16:29:48 MOXi kernel: [ 6.259288] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Feb 27 16:29:48 MOXi kernel: [ 6.266861] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 1th superblock
Feb 27 16:29:48 MOXi kernel: [ 6.278090] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Feb 27 16:29:48 MOXi kernel: [ 6.285482] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 2th superblock
Feb 27 16:29:48 MOXi kernel: [ 6.293561] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Feb 27 16:29:48 MOXi kernel: [ 6.300955] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 1th superblock
Feb 27 16:29:48 MOXi kernel: [ 6.308977] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Feb 27 16:29:48 MOXi kernel: [ 6.316386] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 2th superblock
Feb 27 16:29:48 MOXi kernel: [ 6.328212] BTRFS: device fsid d4095269-196b-4cdf-ba05-8ecc3e28da76 devid 1 transid 255 /dev/root
Feb 27 16:29:48 MOXi kernel: [ 6.344170] BTRFS info (device mmcblk1p1): disk space caching is enabled
Feb 27 16:29:48 MOXi kernel: [ 6.351293] BTRFS info (device mmcblk1p1): has skinny extents
Feb 27 16:29:48 MOXi kernel: [ 6.375406] BTRFS info (device mmcblk1p1): enabling ssd optimizations
Feb 27 16:29:48 MOXi kernel: [ 6.392114] VFS: Mounted root (btrfs filesystem) on device 0:12.
Feb 27 16:29:48 MOXi kernel: [ 6.403061] devtmpfs: mounted
Feb 27 16:29:48 MOXi kernel: [ 6.406498] Freeing unused kernel memory: 320K
Feb 27 16:29:48 MOXi kernel: 6.540588] init: Console is alive
Feb 27 16:29:48 MOXi kernel: 6.543996] init: - watchdog -
Feb 27 16:29:48 MOXi kernel: 7.063055] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Feb 27 16:29:48 MOXi kernel: [ 7.086857] usbcore: registered new interface driver uas
Feb 27 16:29:48 MOXi kernel: 7.092559] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Feb 27 16:29:48 MOXi kernel: 7.107272] init: - preinit -
Feb 27 16:29:48 MOXi kernel: 9.302661] mount_root: mounting /dev/root
Feb 27 16:29:48 MOXi kernel: [ 9.308209] BTRFS info (device mmcblk1p1): disk space caching is enabled
Feb 27 16:29:48 MOXi kernel: [ 9.444135] F2FS-fs (mtdblock1): Magic Mismatch, valid(0xf2f52010) - read(0x910003fd)
Feb 27 16:29:48 MOXi kernel: [ 9.452309] F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 1th superblock
Feb 27 16:29:48 MOXi kernel: 9.495718] urandom-seed: Seeding with /etc/urandom.seed
Feb 27 16:29:48 MOXi kernel: 9.829682] procd: - early -
Feb 27 16:29:48 MOXi kernel: 9.832734] procd: - watchdog -
Feb 27 16:29:48 MOXi kernel: 10.474701] procd: - watchdog -
Feb 27 16:29:48 MOXi kernel: 10.478814] procd: - ubus -
Feb 27 16:29:48 MOXi kernel: 10.535846] procd: - init -
Feb 27 16:29:48 MOXi kernel: 10.641003] kmodloader: loading kernel modules from /etc/modules.d/*
Feb 27 16:29:48 MOXi kernel: [ 10.657047] zram: Added device: zram0
Feb 27 16:29:48 MOXi kernel: [ 10.668242] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Feb 27 16:29:48 MOXi kernel: [ 10.682258] ip6_tables: (C) 2000-2006 Netfilter Core Team
Feb 27 16:29:48 MOXi kernel: [ 10.692658] Netfilter messages via NETLINK v0.30.
Feb 27 16:29:48 MOXi kernel: [ 10.699357] ip_set: protocol 6
Feb 27 16:29:48 MOXi kernel: [ 10.726744] Loading modules backported from Linux version v4.19.221-0-g5fd3cce374df
Feb 27 16:29:48 MOXi kernel: [ 10.734507] Backport generated by backports.git v4.19.221-1-0-g07fffc43
Feb 27 16:29:48 MOXi kernel: [ 10.772020] hidraw: raw HID events driver (C) Jiri Kosina
Feb 27 16:29:48 MOXi kernel: [ 10.780794] Mirror/redirect action on
Feb 27 16:29:48 MOXi kernel: [ 10.793049] u32 classifier
Feb 27 16:29:48 MOXi kernel: [ 10.795879] input device check on
Feb 27 16:29:48 MOXi kernel: [ 10.799414] Actions configured
Feb 27 16:29:48 MOXi kernel: [ 10.809776] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
Feb 27 16:29:48 MOXi kernel: [ 10.816234] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
Feb 27 16:29:48 MOXi kernel: [ 18.203971] Bluetooth: Core ver 2.22
Feb 27 16:29:48 MOXi kernel: [ 18.207654] NET: Registered protocol family 31
Feb 27 16:29:48 MOXi kernel: [ 18.212104] Bluetooth: HCI device and connection manager initialized
Feb 27 16:29:48 MOXi kernel: [ 18.218815] Bluetooth: HCI socket layer initialized
Feb 27 16:29:48 MOXi kernel: [ 18.223911] Bluetooth: L2CAP socket layer initialized
Feb 27 16:29:48 MOXi kernel: [ 18.228913] Bluetooth: SCO socket layer initialized
Feb 27 16:29:48 MOXi kernel: [ 18.235392] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Feb 27 16:29:48 MOXi kernel: [ 18.240820] Bluetooth: BNEP filters: protocol multicast
Feb 27 16:29:48 MOXi kernel: [ 18.244345] ath10k_pci 0000:00:00.0: cannot restart a device that hasn't been started
Feb 27 16:29:48 MOXi kernel: [ 18.246376] Bluetooth: BNEP socket layer initialized
Feb 27 16:29:48 MOXi kernel: [ 18.260159] Bridge firewalling registered
Feb 27 16:29:48 MOXi kernel: [ 18.270027] usbcore: registered new interface driver btusb
Feb 27 16:29:48 MOXi kernel: [ 18.283996] Ebtables v2.0 registered
Feb 27 16:29:48 MOXi kernel: [ 18.289127] Bluetooth: HCI UART driver ver 2.3
Feb 27 16:29:48 MOXi kernel: [ 18.293388] Bluetooth: HCI UART protocol H4 registered
Feb 27 16:29:48 MOXi kernel: [ 18.299027] Bluetooth: HCI UART protocol BCSP registered
Feb 27 16:29:48 MOXi kernel: [ 18.304476] Bluetooth: HCI UART protocol ATH3K registered
Feb 27 16:29:48 MOXi kernel: [ 18.311856] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Feb 27 16:29:48 MOXi kernel: [ 18.317795] Bluetooth: HIDP socket layer initialized
Feb 27 16:29:48 MOXi kernel: [ 18.325442] ip_tables: (C) 2000-2006 Netfilter Core Team
Feb 27 16:29:48 MOXi kernel: [ 18.353771] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
Feb 27 16:29:48 MOXi kernel: [ 18.363541] ctnetlink v0.93: registering with nfnetlink.
Feb 27 16:29:48 MOXi kernel: [ 18.404110] Bluetooth: RFCOMM TTY layer initialized
Feb 27 16:29:48 MOXi kernel: [ 18.408987] Bluetooth: RFCOMM socket layer initialized
Feb 27 16:29:48 MOXi kernel: [ 18.414158] Bluetooth: RFCOMM ver 1.11
Feb 27 16:29:48 MOXi kernel: [ 18.420697] usbcore: registered new interface driver ums-alauda
Feb 27 16:29:48 MOXi kernel: [ 18.427337] usbcore: registered new interface driver ums-cypress
Feb 27 16:29:48 MOXi kernel: [ 18.434664] usbcore: registered new interface driver ums-datafab
Feb 27 16:29:48 MOXi kernel: [ 18.441614] usbcore: registered new interface driver ums-freecom
Feb 27 16:29:48 MOXi kernel: [ 18.448932] usbcore: registered new interface driver ums-isd200
Feb 27 16:29:48 MOXi kernel: [ 18.455895] usbcore: registered new interface driver ums-jumpshot
Feb 27 16:29:48 MOXi kernel: [ 18.462852] usbcore: registered new interface driver ums-karma
Feb 27 16:29:48 MOXi kernel: [ 18.469910] usbcore: registered new interface driver ums-sddr09
Feb 27 16:29:48 MOXi kernel: [ 18.476801] usbcore: registered new interface driver ums-sddr55
Feb 27 16:29:48 MOXi kernel: [ 18.484047] usbcore: registered new interface driver ums-usbat
Feb 27 16:29:48 MOXi kernel: [ 18.521828] xt_time: kernel timezone is -0000
Feb 27 16:29:48 MOXi kernel: [ 18.542976] PPP generic driver version 2.4.2
Feb 27 16:29:48 MOXi kernel: [ 18.549167] NET: Registered protocol family 24
Feb 27 16:29:48 MOXi kernel: 18.568640] kmodloader: done loading kernel modules from /etc/modules.d/*
Feb 27 16:29:48 MOXi kernel: [ 19.140724] zram0: detected capacity change from 0 to 522190848
Feb 27 16:29:48 MOXi kernel: [ 19.159741] Adding 509948k swap on /dev/zram0. Priority:-2 extents:1 across:509948k SS
Feb 27 16:29:48 MOXi kernel: [ 21.910536] IPv6: ADDRCONF(NETDEV_UP): br-guest_turris: link is not ready
Feb 27 16:29:48 MOXi kernel: [ 21.951674] mvneta d0040000.ethernet eth1: configuring for inband/2500base-x link mode
Feb 27 16:29:48 MOXi kernel: [ 21.960718] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Feb 27 16:29:48 MOXi kernel: [ 21.999806] mv88e6085 d0032004.mdio-mii:02 lan1: configuring for phy/ link mode
Feb 27 16:29:48 MOXi kernel: [ 22.023483] br-guest_turris: port 1(lan1) entered blocking state
Feb 27 16:29:48 MOXi kernel: [ 22.029824] br-guest_turris: port 1(lan1) entered disabled state
Feb 27 16:29:48 MOXi kernel: [ 22.045341] device lan1 entered promiscuous mode
Feb 27 16:29:48 MOXi kernel: [ 22.049890] device eth1 entered promiscuous mode
Feb 27 16:29:48 MOXi kernel: [ 22.097576] mv88e6085 d0032004.mdio-mii:02 lan3: configuring for phy/ link mode
Feb 27 16:29:48 MOXi kernel: [ 22.113550] br-guest_turris: port 2(lan3) entered blocking state
Feb 27 16:29:48 MOXi kernel: [ 22.119698] br-guest_turris: port 2(lan3) entered disabled state
Feb 27 16:29:48 MOXi kernel: [ 22.130341] mvneta d0040000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
Feb 27 16:29:48 MOXi kernel: [ 22.176525] device lan3 entered promiscuous mode
Feb 27 16:29:48 MOXi kernel: [ 22.216085] mv88e6085 d0032004.mdio-mii:02 lan4: configuring for phy/ link mode
Feb 27 16:29:48 MOXi kernel: [ 22.230290] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Feb 27 16:29:48 MOXi kernel: [ 22.237095] br-guest_turris: port 3(lan4) entered blocking state
Feb 27 16:29:48 MOXi kernel: [ 22.243364] br-guest_turris: port 3(lan4) entered disabled state
Feb 27 16:29:48 MOXi kernel: [ 22.265884] device lan4 entered promiscuous mode
Feb 27 16:29:48 MOXi kernel: [ 22.316769] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Feb 27 16:29:48 MOXi kernel: [ 22.336886] mv88e6085 d0032004.mdio-mii:02 lan2: configuring for phy/ link mode
Feb 27 16:29:48 MOXi kernel: [ 22.349841] br-lan: port 1(lan2) entered blocking state
Feb 27 16:29:48 MOXi kernel: [ 22.355332] br-lan: port 1(lan2) entered disabled state
Feb 27 16:29:48 MOXi kernel: [ 22.385421] device lan2 entered promiscuous mode
Feb 27 16:29:48 MOXi kernel: [ 22.399629] mv88e6085 d0032004.mdio-mii:02: p2: hw VLAN 1 already used by br-guest_turris
Feb 27 16:29:48 MOXi kernel: [ 22.524685] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510]
Feb 27 16:29:48 MOXi kernel: [ 22.533942] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
Feb 27 16:29:48 MOXi kernel: [ 25.735321] mvneta d0030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Feb 28 00:29:49 MOXi dnsmasq[1]: started, version 2.80 DNS disabled
Feb 28 00:29:49 MOXi dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Feb 28 00:29:49 MOXi dnsmasq-script[1]: /sbin/hotplug-call: .: line 6: can't open '/lib/functions.sh': No such file or directory
Feb 28 00:29:49 MOXi dnsmasq[1]: script process exited with status 2
Feb 28 00:29:51 MOXi ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Feb 28 00:29:51 MOXi ucitrack: Setting up /etc/config/network reload dependency on /etc/config/radvd
Feb 28 00:29:51 MOXi ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Feb 28 00:29:51 MOXi ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Feb 28 00:29:51 MOXi ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Feb 28 00:29:51 MOXi ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Feb 28 00:29:51 MOXi ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Feb 28 00:29:51 MOXi ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Feb 28 00:29:52 MOXi ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Feb 28 00:29:52 MOXi ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Feb 28 00:29:52 MOXi ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Feb 28 00:29:53 MOXi crond[4243]: (CRON) STARTUP (1.5.7)
Feb 28 00:29:53 MOXi crond[4243]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 28% if used.)
Feb 28 00:29:53 MOXi crond[4243]: (CRON) INFO (running with inotify support)
Feb 28 00:29:55 MOXi turris: Router Turris successfully started.
Feb 28 00:29:55 MOXi procd: - init complete -
Feb 28 00:29:59 MOXi firewall: Reloading firewall due to ifup of lan (br-lan)
Feb 27 16:30:00 MOXi kernel: [ 40.049244] mv88e6085 d0032004.mdio-mii:02 lan2: Link is Up - 1Gbps/Full - flow control rx/tx
Feb 27 16:30:00 MOXi kernel: [ 40.077266] br-lan: port 1(lan2) entered blocking state
Feb 27 16:30:00 MOXi kernel: [ 40.082705] br-lan: port 1(lan2) entered forwarding state
Feb 28 00:30:00 MOXi netifd: Network device 'lan2' link is up
Feb 27 16:30:00 MOXi kernel: [ 40.107193] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Feb 28 00:30:00 MOXi netifd: bridge 'br-lan' link is up
Feb 28 00:30:00 MOXi netifd: Interface 'lan' has link connectivity
Feb 28 00:30:01 MOXi crond[4733]: (root) CMD (/usr/bin/notifier)
Feb 28 00:30:01 MOXi crond[4732]: (root) CMDOUT (There is no message to send.)
Feb 28 00:30:01 MOXi crond[4732]: (root) CMDEND (/usr/bin/notifier)
Feb 28 00:30:01 MOXi odhcpd[2281]: Failed to send to ff02::1%guest_turris@br-guest_turris (Address not available)
Feb 28 00:30:01 MOXi odhcpd[2281]: Failed to send to ff02::1%lan@br-lan (Address not available)
Feb 27 16:30:01 MOXi sentinel: INFO [certgen.action_spec_init:89] Valid certificate found
Feb 28 00:30:06 MOXi dnsmasq[1]: exiting on receipt of SIGTERM
Feb 28 00:30:06 MOXi dnsmasq[1]: started, version 2.80 DNS disabled
Feb 28 00:30:06 MOXi dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Feb 28 00:30:06 MOXi dnsmasq-dhcp[1]: DHCP, IP range 192.168.73.100 -- 192.168.73.249, lease time 12h
Feb 28 00:30:06 MOXi dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Feb 28 00:30:06 MOXi dnsmasq-script[1]: /sbin/hotplug-call: .: line 6: can't open '/lib/functions.sh': No such file or directory
Feb 28 00:30:06 MOXi dnsmasq[1]: script process exited with status 2
Feb 28 00:30:12 MOXi dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.73.247 00:2b:67:76:a2:e1
Feb 28 00:30:12 MOXi dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.73.247 00:2b:67:76:a2:e1
Feb 28 00:30:12 MOXi dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.73.247 00:2b:67:76:a2:e1
Feb 28 00:30:12 MOXi dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.73.247 00:2b:67:76:a2:e1 ryzen
Feb 28 00:30:12 MOXi dnsmasq-script[1]: /sbin/hotplug-call: .: line 6: can't open '/lib/functions.sh': No such file or directory
Feb 28 00:30:12 MOXi dnsmasq[1]: script process exited with status 2
Feb 28 00:30:14 MOXi firewall: Reloading firewall due to ifup of wan (eth0)
Feb 28 00:30:19 MOXi firewall: Reloading firewall due to ifup of wan6 (eth0)
Feb 27 16:31:08 MOXi sentinel: INFO [certgen.action_spec_init:89] Valid certificate found
Kernel Log:
[ 6.540588] init: Console is alive
[ 6.543996] init: - watchdog -
[ 7.063055] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 7.092559] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 7.107272] init: - preinit -
[ 9.302661] mount_root: mounting /dev/root
[ 9.495718] urandom-seed: Seeding with /etc/urandom.seed
[ 9.829682] procd: - early -
[ 9.832734] procd: - watchdog -
[ 10.474701] procd: - watchdog -
[ 10.478814] procd: - ubus -
[ 10.535846] procd: - init -
[ 10.641003] kmodloader: loading kernel modules from /etc/modules.d/*
[ 18.568640] kmodloader: done loading kernel modules from /etc/modules.d/*
System Log:
Feb 28 00:31:35 MOXi : luci: accepted login on / for root from 192.168.73.247
