As I have noticed that my memory usage is really high on my MOX classic I was wondering if it is possible to run a pure openwrt without Foris on MOX hardware.
Has anyone tried this?
What would be the limitations?
Until then (re)Foris is removable from TOS if that is the aim.
Ok thx. How can it be removed?
Like most other packages
opkg remove
schnapps
is working and you are familiar with it in case things go sidewaysIs this pasted from official docs.tuirrs.cz?
I cannot find this. Can you copy the link?
This is the link to the updater but not to removing foris.
At least I dońt see it there but maybe all that staying at home has had an effect on my vision, too?
There is no documentation about the removal of (re)Foris from TOS, understandably.
True. That makes sense. Have you succefully removed re(Foris)?
Yes, albeit on a TO device. However, I am not going to populate step-by-step guide considering that someone not heeding the aforementioned and ending up with the device in an undesired state and then seeking support for it.
Those ones could be directly pointed to the wiki, it is clearly documented how to copy complete TOS on SD-card. So if really everything fails, one can easily start from scratch setting up MOX.
case in point.
Suggestions:
