I’m attempting to run Pulseaudio on my Turris Omnia, but unfortunately it segfaults as soon as it starts. This is happening with the newest pulseaudio-daemon
and pulseaudio-daemon-avahi
on TurrisOS 5.1.4
I’ve tried running it with strace to see if I could glean anything useful, but unfortunately not.
Perhaps someone has some ideas?
Linux turris 4.14.206 #0 SMP Fri Nov 13 04:11:07 2020 armv7l GNU/Linux
The trace is:
root@turris:~# strace pulseaudio
execve("/usr/bin/pulseaudio", ["pulseaudio"], 0xbe9addd0 /* 13 vars */) = 0
set_tls(0xb6feb5d8) = 0
set_tid_address(0xb6fec1b0) = 13586
open("/usr/lib/pulseaudio/libpulsecore-12.2.so", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fcntl64(3, F_SETFD, FD_CLOEXEC) = 0
fstat64(3, {st_mode=S_IFREG|0755, st_size=499947, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0@\376\0\0004\0\0\0"..., 936) = 936
mmap2(NULL, 569344, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6edd000
mmap2(0xb6f65000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x78000) = 0xb6f65000
close(3) = 0
open("/usr/lib/pulseaudio/libpulse.so.0", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/etc/ld-musl-armhf.path", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/libpulse.so.0", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libpulse.so.0", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/libpulse.so.0", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0755, st_size=278540, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0 \242\0\0004\0\0\0"..., 936) = 936
mmap2(NULL, 348160, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6e88000
mmap2(0xb6edb000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x43000) = 0xb6edb000
close(3) = 0
open("/usr/lib/pulseaudio/libpulsecommon-12.2.so", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0755, st_size=409747, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\08\370\0\0004\0\0\0"..., 936) = 936
mmap2(NULL, 479232, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6e13000
mmap2(0xb6e86000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x63000) = 0xb6e86000
close(3) = 0
open("/usr/lib/pulseaudio/libwrap.so.0", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/libwrap.so.0", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libwrap.so.0", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/libwrap.so.0", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0755, st_size=21543, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\244\34\0\0004\0\0\0"..., 936) = 936
mmap2(NULL, 90112, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6dfd000
mmap2(0xb6e11000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x4000) = 0xb6e11000
close(3) = 0
open("/usr/lib/pulseaudio/libsndfile.so.1", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/libsndfile.so.1", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libsndfile.so.1", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/libsndfile.so.1", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=361156, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\370&\0\0004\0\0\0"..., 936) = 936
mmap2(NULL, 438272, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6d92000
mmap2(0xb6df9000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x57000) = 0xb6df9000
mmap2(0xb6dfb000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb6dfb000
close(3) = 0
open("/usr/lib/pulseaudio/libltdl.so.7", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/libltdl.so.7", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libltdl.so.7", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/libltdl.so.7", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0755, st_size=28681, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0P\32\0\0004\0\0\0"..., 936) = 936
mmap2(NULL, 98304, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6d7a000
mmap2(0xb6d90000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x6000) = 0xb6d90000
close(3) = 0
open("/usr/lib/pulseaudio/libcap.so.2", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/libcap.so.2", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/local/lib/libcap.so.2", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/usr/lib/libcap.so.2", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=12442, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\230\16\0\0004\0\0\0"..., 936) = 936
mmap2(NULL, 81920, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6d66000
mmap2(0xb6d78000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2000) = 0xb6d78000
close(3) = 0
open("/usr/lib/pulseaudio/libgcc_s.so.1", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
open("/lib/libgcc_s.so.1", O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=40963, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0000E\0\0004\0\0\0"..., 936) = 936
mmap2(NULL, 110592, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0xb6d4b000
mmap2(0xb6d64000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x9000) = 0xb6d64000
close(3) = 0
mprotect(0xb6f65000, 8192, PROT_READ) = 0
mprotect(0xb6edb000, 4096, PROT_READ) = 0
mprotect(0xb6e86000, 4096, PROT_READ) = 0
mprotect(0xb6e11000, 4096, PROT_READ) = 0
mprotect(0xb6df9000, 4096, PROT_READ) = 0
mprotect(0xb6d90000, 4096, PROT_READ) = 0
mprotect(0xb6d78000, 4096, PROT_READ) = 0
mprotect(0xb6d64000, 4096, PROT_READ) = 0
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_ACCERR, si_addr=0x44e250} ---
+++ killed by SIGSEGV +++
Segmentation fault
