Prometheus-node-exporter-lua nechce startnout, čeká na iface br-lan
Snažím se rozchodit prometheus-node-exporter na turrisu, ale bezuspesne.
Sep 15 22:33:25 gw prometheus-node-exporter-lua: defering start until listen interface br-lan becomes ready
Zkusil jsem fix co zkouší tady prometheus-node-exporter-lua: daemon does not start after deferring itself to wait for interface to become ready · Issue #18748 · openwrt/packages · GitHub , ale bez úspěchu
root@gw:/etc/init.d$ bash -x ./prometheus-node-exporter-lua.new start
+ START=60
+ USE_PROCD=1
Pokud to pustim jen tak, tak se zda export funguje, jen nenaslocha na :9100
root@gw:~# /usr/bin/prometheus-node-exporter-lua
wifi_stations{ifname="wlan1"} 3
node_scrape_collector_duration_seconds{collector="wifi_stations"} 0.010161876678467
node_scrape_collector_success{collector="wifi_stations"} 1
