A couple weeks ago I got a Turris Omnia 2020, and took quite a while to setup everything the way I wanted. Made a mistake along the way, and decided to do a factory reset(Holding the button until 3 leds were lit). Setup everything again, taking another considerable chunk of time, and decided to update to the newest version.
But after issuing the update from the web interface, after the reboot the router has no web interface, and no ssh connection. Internet still works, so it kept my configuration. I rolled back to a snapshot holding the button until 2 leds were lit.
Running pkgupdate from ssh gives the same result, but prints the following messages:
sure enough, it is removing a bunch of stuff, including openssh-server.
opkg update also doesn’t seem very happy:
How can I update my router? preferably without loosing all my configuration a second time.
Thanks for any help.
