i have the problem that when i want to install banIP, i am told it has to install “logd”.
But this will not be installed because it is already used by syslog_ng.
Can I safely use the overwrite option in this case?
Maybe @dibdot has some advice?
please just wait for the next banIP version. The current version has never been tested on my turris device. I let you know, when the update is available.
Thanks for your answer, I will wait.
I came across it when I was looking for a way to block Facebook. Unfortunately “adblock” does not have such a separate list.
anudeepND has such a list available:
just let you know that banIP 0.7.1 is now in OpenWrt master. It has been successfully tested with Turris OS 5.2.0 (hbl branch). The download links etc. will be found here.
Please note: remove your old banIP installation (incl. config) before you try to update to latest release.
after the update to Turris OS6 came me again your great “banIP” in mind and what can I say …
Runs absolutely round and a big thank you at this point!
Keep up the good work, I would also support financially!
