I just completed a “level 4” reset of the Omnia, restoring it back to factory defaults and using the latest recovery image.
One of the items I have installed in the Omnia is a 128GB mSATA SSD because I want to use LXC containers, and I know you should not use internal flash for that.
So, after the initial recovery reboot, I go to the storage tab in Foris and set the SSD as the storage volume:
The Omnia has not maintained the SSD as mounted after a reboot, and it appears to again be using internal flash as storage. Also, note the differences in the UUID between Foris and Luci, for what I think is the same device. Why is it doing this and how can I correct it?
I have exactly the same problem. I already had it with Turris OS version-3.10.7, it was fixed after updating to Turris OS version-3.10.8-2018-2018-10-15 12H23, and have again the same problem as yours.
What I did (I read it a few months ago on this forum):
login in the LUCI interface
menu: “System, Mount Points”: delete the the Mount Point you wish to use (provided that you don’t use it for NAS storage or other purpose)
add a new Mount Point (in my case:/mnt/sda , btrfs ) and enable it
connect via Putty or other (I personally use Secure CRT & Secure FX)
PS: pakon & suricata should be stopped as well if they are running
lxc, suricata & pakon have been moved to /mnt/sda and links (i.e. lxc, suricata and pakon) have been created in /srv
Now all the data are written in the internal SSD in /mnt/sda
I do not like too much this procedure but it works, hoping to get a fix ASAP.
Hi, I read the content of this script, a pity that I do not have the previous version (3.10.8) in order to check for any difference.
Anyway, I think that the problem is elsewhere but do not have much time to analyse it.
As well: a problem with the Pakon Pie-chart: unreadable, maybe linked to the high DPI of my screen.
Andrew
Hi, yes, you are right, this line #12 does not exist in the working Turris OS version-3.10.8-2018-2018-10-15 12H23.
I always keep all the previous in my machine, better to be wise when we have a working version;
v3.10.7 had the same issue but has the same instructions as in v3.10.8 i.e.
The added line is a fix for https://gitlab.labs.nic.cz/turris/foris-controller-storage-module/issues/1 The idea here is that if somehow mounting the storage device fails, then a RAMdisk 50MB in size will be mounted at /srv instead, preventing any applications from wearing out the internal flash.
