zdravim,
mam turris omni, aktualizace povoleny. chtel bych poprosit o radu v cem by mohl byt problem. po nejakem case mi DHCP prestane pridelovat IPV4 adresu pro WLAN0 (AC sit) klienty. IPV6 dostanou v poradku. pro WLAN1 (N sit) je vsechno v poradku IPV4 i IPV6, “kabelovi” klienti jsou taky v poradku IPV4 i IPV6. mam vcelku klasickou konfiguraci. v br-lan je eth0, eth2, wlan0 i wlan1. po restartu routeru vsechno funguje. prikladam config dhcp
config dnsmasq
option domainneeded '1'
option boguspriv '1'
option localise_queries '1'
option rebind_protection '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option expandhosts '1'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option resolvfile '/tmp/resolv.conf.auto'
option localservice '1'
option port '0'
option enable_tftp '1'
option tftp_root '/mnt/sda1/tftp'
option nonwildcard '0'
config boot 'linux'
option filename 'pxelinux.0'
option serveraddress '[x.x.x.x]'
option servername 'Turris'
config dhcp 'lan'
option interface 'lan'
option start '100'
option limit '150'
option leasetime '12h'
list dhcp_option '6,[x.x.x.x]'
option ra 'hybrid'
option dhcpv6 'hybrid'
option ndp 'hybrid'
option ra_management '1'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
