I’m using the Omnia with a VDSL connection of “Deutsche Telekom”.
I have to insert VLAN 7 to get a connection. So I went in LuCI to “Network” → “Interfaces” → “WAN Edit” → “Physical Settings” and changed the interface from eth2 to eth2.7.
see Image1/2
Today I updated to version 4.0.5.
Unfortunately now the Foris administration interface doesn’t recognize the WAN connection any more.
With Turris OS 3.11.16 this worked…
see Image 3
Is there any way to fix this? Or did I do something wrong?
Best regards,
Martin
With TurrisOS 4.0.1 it is impossible to set VLAN IF via Luci such as eth2.7. I have set the VLAN TAG on the modem side. This is the best current approach. Don’t put VLAN TAG on both sides of PPPoE connection. I am using a DryTec Vigor 160 modem.
