My ISP requires the following settings which I cannot trace either on Foris or LuCI:
- AFTR (AdressfamilyTransitionRouter)
- IP4 via DS-Lite protocol
- IP6 via via DHCPv6 Prefix-Delegation
How/where to set those?
did you tried to use peeraddr
option? (maybe via ssh if it’s not available in Foris/LuCi)
these might help if not already seen:
https://wiki.openwrt.org/doc/uci/network6
https://openwrt.org/docs/guide-user/network/ucicheatsheet
https://openwrt.org/docs/guide-user/network/ipv6_ipv4_transitioning
@MiKe peeraddr
was not the solution but reminding me that some reading at OpenWRT sometimes helps.
Dual-Stack Lite
is supported in LuCI -> Network -> Interfaces -> Add new interface -> Protocol Dual-Stack Lite
In advanced settings it then can be linked to the PPPoE interface (in this case named SPF). In short that how it looks like in /etc/config/network
config interface 'DS_Lite'
option proto 'dslite'
option peeraddr 'aftr......'
list tunlink 'SPF'
