PPPoE nenastaví korektně vlastnosti spojení, LUCI interface hlasí neznámou chybu
Zkouším zprovoznit DSL bridge přes ZTE ZXHN H267A, na omnii se vytvoří interface s verejnou IP, nenastavi se ale defaultni routa a DNS.
V syslogu je všechno ok,
V síťových rozhraních svítí neznámá chyba, viz. screenshot.
Dle toho, co jsem našel by to mělo fungovat, neví někdo ?
Summary
May 14 19:57:47 turris pppd[18896]: Plugin rp-pppoe.so loaded.
May 14 19:57:47 turris pppd[18896]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
May 14 19:57:47 turris pppd[18896]: pppd 2.4.7 started by root, uid 0
May 14 19:57:47 turris pppd[18896]: PPP session is 1
May 14 19:57:47 turris pppd[18896]: Connected to 50:40:61:6d:9e:01 via interface eth2
May 14 21:57:47 turris kernel: [14638.737980] pppoe-WAN_PPPoe: renamed from ppp0
May 14 19:57:47 turris pppd[18896]: Renamed interface ppp0 to pppoe-WAN_PPPoe_O2
May 14 19:57:47 turris pppd[18896]: Using interface pppoe-WAN_PPPoe_O2
May 14 19:57:47 turris pppd[18896]: Connect: pppoe-WAN_PPPoe_O2 ↔ eth2
May 14 19:57:51 turris pppd[18896]: Remote message: Login ok
May 14 19:57:51 turris pppd[18896]: PAP authentication succeeded
May 14 19:57:51 turris pppd[18896]: peer from calling number 50:40:61:6D:9E:01 authorized
May 14 19:57:51 turris pppd[18896]: local LL address fe80::9434:c77a:36ec:9b0a
May 14 19:57:51 turris pppd[18896]: remote LL address fe80::5240:61ff:fe6d:9e01
May 14 19:57:51 turris pppd[18896]: local IP address 90.180.63.53
May 14 19:57:51 turris pppd[18896]: remote IP address 10.10.10.1
May 14 19:57:51 turris pppd[18896]: primary DNS address 160.218.161.54
May 14 19:57:51 turris pppd[18896]: secondary DNS address 194.228.41.65
289: pppoe-WAN_PPPoe: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1492 qdisc fq_codel state UNKNOWN group default qlen 3
link/ppp
inet 90.180.63.53 peer 10.10.10.1/32 scope global pppoe-WAN_PPPoe
inet6 fe80::9434:c77a:36ec:9b0a/10 scope link
root@turris:~# ip r
192.168.1.0/24 dev br-lan proto kernel scope link src 192.168.1.1
/etc/config/network
config interface ‘WAN_PPPoe_O2’
option proto ‘pppoe’
option ipv6 ‘auto’
option auto ‘0’
option ifname ‘eth2’
option password ‘o2’
option username ‘o2’
option mtu ‘1500’
U xDSL ale i jiných služeb je třeba nastavit vlan na Wan portu v případě Bridge režimu modemu, v případě O2 CZ je třeba teda vytvořit rozhraní eth2.848 a na něm vytáčet. https://docs.turris.cz/basics/luci/vlan/luci-vlan/
není ta vlana 848 ukončená na tom DSL bridge modemu, kde je soucasti konfigurace ?
Pokud nahodím interface eth2.848, tak se to na něj nechyta, kdežto přímo na eth2 se to chytne hned. Rovnez v tracu z omnie eth2, prikladam screenshot, neni vlan 848 propagovana.
54: eth2.848@eth2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1492 qdisc noqueue state UP group default qlen 1000
link/ether d8:58:d7:01:10:8b brd ff:ff:ff:ff:ff:ff
inet6 fe80::da58:d7ff:fe01:108b/64 scope link
Je nějaký posun? Mám podobný problém u optického internetu od Tčka.
May 4 23:54:57 XXX netifd: wan (13380): ppp: warning: Sleeping for ‘10’ seconds
May 4 23:55:02 XXX insmod: module is already loaded - ppp_generic
May 4 23:55:02 XXX insmod: module is already loaded - pppox
May 4 23:55:02 XXX insmod: module is already loaded - pppoe
May 4 23:55:02 XXX netifd: wan (14350): ppp: warning: Sleeping for ‘10’ seconds
May 4 23:55:13 XXX pppd[14616]: Plugin pppoe.so loaded.
May 4 23:55:13 XXX pppd[14616]: PPPoE plugin from pppd 2.4.9
May 4 23:55:13 XXX pppd[14616]: pppd 2.4.9 started by root, uid 0
May 4 23:55:28 XXX pppd[14616]: Timeout waiting for PADO packets
May 4 23:55:28 XXX pppd[14616]: Unable to complete PPPoE Discovery
May 4 23:55:28 XXX pppd[14616]: Exit.
May 4 23:55:28 XXX insmod: module is already loaded - ppp_generic
May 4 23:55:28 XXX insmod: module is already loaded - pppox
May 4 23:55:28 XXX insmod: module is already loaded - pppoe
May 4 23:55:28 XXX netifd: wan (14692): ppp: warning: Sleeping for ‘10’ seconds
Chyba u operátora … vyřešeno
