I think my question is pretty much this:
I can’t reach the web interface of my VDSL modem (Archer VR200v) anymore after setting it to bridge pppoe mode. According to TP-LINK support it should actually work. So I’m guessing I miss a static route on the turris.
The modem is on 192.168.1.1 while Turris LAN network is 10.0.0.0/24. What is the correct way to setup a static route so it will route requests of 192.168.1.1 to the WAN port?
root@turris:~# ip route
default via 87.186.xxx.xxx dev pppoe-wan proto static
10.0.0.0/24 dev br-lan proto kernel scope link src 10.0.0.1
87.186.xxx.xxx dev pppoe-wan proto kernel scope link src 79.203.xxx.xxx
Thanks a lot!
