I’ve got a new MOX with a fresh Turris OS 5.4.0 and want to install xinetd
on it (required for muninlite
% opkg install xinetd
Installing xinetd (2.3.15-5) to root...
Downloading https://repo.turris.cz/hbs/mox/packages/packages/xinetd_2.3.15-5_aarch64_cortex-a53.ipk
Configuring xinetd.
//usr/lib/opkg/info/xinetd.postinst: line 261: /etc/init.d/: Permission denied
The postinst script is only a few lines long, so the line number is misleading.
I installed strace
and reinstalled xinetd
. Same error again, and in the trace I found
8930 rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0
8930 close(10) = 0
8930 rt_sigaction(SIGQUIT, NULL, {sa_handler=SIG_IGN, sa_mask=[], sa_flags=0}, 8) = 0
8930 execve("/etc/init.d/", ["/etc/init.d/", "enabled"], 0x5588b2fbe8 /* 17 vars */) = -1 EACCES (Permission denied)
8930 writev(2, [{iov_base="//usr/lib/opkg/info/xinetd.posti"..., iov_len=37}, {iov_base=NULL, iov_len=0}], 2) = 37
8930 writev(2, [{iov_base="line 261: ", iov_len=10}, {iov_base=NULL, iov_len=0}], 2) = 10
8930 writev(2, [{iov_base="/etc/init.d/: Permission denied", iov_len=31}, {iov_base=NULL, iov_len=0}], 2) = 31
8930 writev(2, [{iov_base="", iov_len=0}, {iov_base="\n", iov_len=1}], 2) = 1
8930 exit_group(126) = ?
8930 +++ exited with 126 +++
So, something seems to try to exec the /etc/init.d/
directory, which doesn’t make any sense.
Any idea what’s going on?
Is the same happening on your devices?
