I am having trouble to get simple port forwarding rules to work.
The traffic is incoming on the turris:
root@router:~# tcpdump -i any port 22 and inbound and not src host 192.168.1.106
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on any, link-type LINUX_SLL (Linux cooked v1), capture size 262144 bytes
12:05:47.355189 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [.], ack 353183265, win 2047, options [nop,nop,TS val 290517235 ecr 1205336816], length 0
12:05:47.355189 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [.], ack 1, win 2047, options [nop,nop,TS val 290517235 ecr 1205337003,nop,nop,sack 1 {4294967261:1}], length 0
12:05:47.355553 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [.], ack 37, win 2048, options [nop,nop,TS val 290517235 ecr 1205337006], length 0
12:05:47.355553 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [P.], seq 0:36, ack 37, win 2048, options [nop,nop,TS val 290517235 ecr 1205337006], length 36
12:05:47.355553 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [P.], seq 36:80, ack 37, win 2048, options [nop,nop,TS val 290517235 ecr 1205337006], length 44
12:05:47.498785 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [.], ack 73, win 2047, options [nop,nop,TS val 290517378 ecr 1205337175], length 0
12:05:47.498905 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [P.], seq 80:116, ack 73, win 2048, options [nop,nop,TS val 290517378 ecr 1205337175], length 36
12:05:47.764113 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [.], ack 109, win 2047, options [nop,nop,TS val 290517643 ecr 1205337276], length 0
12:05:47.764113 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [.], ack 145, win 2048, options [nop,nop,TS val 290517643 ecr 1205337345], length 0
12:05:47.764489 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [P.], seq 116:152, ack 145, win 2048, options [nop,nop,TS val 290517643 ecr 1205337345], length 36
12:05:47.764490 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [P.], seq 152:204, ack 145, win 2048, options [nop,nop,TS val 290517643 ecr 1205337345], length 52
12:05:47.769163 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [P.], seq 204:380, ack 145, win 2048, options [nop,nop,TS val 290517649 ecr 1205337442], length 176
12:05:47.770846 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [.], ack 181, win 2047, options [nop,nop,TS val 290517650 ecr 1205337447], length 0
12:05:47.770846 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [.], ack 241, win 2048, options [nop,nop,TS val 290517650 ecr 1205337447], length 0
12:05:47.771674 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [.], ack 242, win 2048, options [nop,nop,TS val 290517650 ecr 1205337449], length 0
12:05:47.785427 IP 192.168.1.140.22 > 192.168.1.106.65085: Flags [F.], seq 380, ack 242, win 2048, options [nop,nop,TS val 290517665 ecr 1205337449], length 0
12:05:49.318724 IP XXXXXXXXXX.nicesrv.de.22 > 192.168.178.33.65138: Flags [S.], seq 583084176, ack 3354047146, win 28960, options [mss 1412,sackOK,TS val 1125267200 ecr 550632766,nop,wscale 11], length 0
12:05:49.335404 IP XXXXXXXXXX.nicesrv.de.22 > 192.168.178.33.65138: Flags [.], ack 22, win 15, options [nop,nop,TS val 1125267217 ecr 550632783], length 0
12:05:49.343628 IP XXXXXXXXXX.nicesrv.de.22 > 192.168.178.33.65138: Flags [P.], seq 1:22, ack 22, win 15, options [nop,nop,TS val 1125267225 ecr 550632783], length 21
12:05:49.359232 IP XXXXXXXXXX.nicesrv.de.22 > 192.168.178.33.65138: Flags [P.], seq 22:1070, ack 22, win 15, options [nop,nop,TS val 1125267241 ecr 550632808], length 1048
12:05:49.890463 IP XXXXXXXXXX.nicesrv.de.22 > 192.168.178.33.65138: Flags [P.], seq 3450:3518, ack 3554, win 20, options [nop,nop,TS val 1125267772 ecr 550633328], length 68
12:05:49.890463 IP XXXXXXXXXX.nicesrv.de.22 > 192.168.178.33.65138: Flags [P.], seq 3518:3606, ack 3554, win 20, options [nop,nop,TS val 1125267772 ecr 550633328], length 88
12:05:49.891604 IP XXXXXXXXXX.nicesrv.de.22 > 192.168.178.33.65138: Flags [P.], seq 3606:3730, ack 3554, win 20, options [nop,nop,TS val 1125267773 ecr 550633328], length 124
12:05:49.966244 IP XXXXXXXXXX.nicesrv.de.22 > 192.168.178.33.65138: Flags [P.], seq 3606:3730, ack 3554, win 20, options [nop,nop,TS val 1125267848 ecr 550633343], length 124
12:05:50.206905 IP XXXXXXXXXX.nicesrv.de.22 > 192.168.178.33.65138: Flags [P.], seq 3450:3730, ack 3554, win 20, options [nop,nop,TS val 1125268088 ecr 550633343], length 280
12:05:50.436813 IP XXXXXXXXXX.nicesrv.de.22 > 192.168.178.33.65138: Flags [.], ack 3598, win 20, options [nop,nop,TS val 1125268319 ecr 550633839], length 0
But there is no outgoing traffic:
root@router:/etc/config# tcpdump -i br-lan port 22 and not src host 192.168.1.106 and not dst host 192.168.1.106
listening on br-lan, link-type EN10MB (Ethernet), capture size 262144 bytes
^C
0 packets captured
1 packet received by filter
0 packets dropped by kernel
/etc/config/firewall
config defaults
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
option synflood_protect '1'
config zone
option name 'lan'
list network 'lan'
option forward 'ACCEPT'
config zone
option name 'wan'
list network 'wan'
list network 'wan6'
option masq '1'
option mtu_fix '1'
option sentinel_fwlogs '1'
option sentinel_minipot '1'
option haas_proxy '1'
option sentinel_dynfw '1'
option input 'DROP'
option forward 'DROP'
config forwarding
option src 'lan'
option dest 'wan'
config rule
option name 'Allow-DHCP-Renew'
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fc00::/6'
option dest_ip 'fc00::/6'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option name 'Allow-ICMPv6-Input'
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'destination-unreachable'
list icmp_type 'packet-too-big'
list icmp_type 'time-exceeded'
list icmp_type 'bad-header'
list icmp_type 'unknown-header-type'
list icmp_type 'router-solicitation'
list icmp_type 'neighbour-solicitation'
list icmp_type 'router-advertisement'
list icmp_type 'neighbour-advertisement'
option limit '1000/sec'
config rule
option name 'Allow-ICMPv6-Forward'
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option name 'Allow-IPSec-ESP'
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option name 'Allow-ISAKMP'
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config include
option path '/etc/firewall.user'
config zone 'guest_turris'
option enabled '1'
list network 'guest_turris'
option input 'REJECT'
option name 'tr_guest'
config forwarding 'guest_turris_forward_wan'
option enabled '1'
option name 'guest to wan forward'
option dest 'wan'
option src 'tr_guest'
config rule 'guest_turris_dns_rule'
option enabled '1'
option name 'guest dns rule'
option proto 'tcpudp'
option dest_port '53'
config rule 'guest_turris_dhcp_rule'
option enabled '1'
option name 'guest dhcp rule'
option proto 'udp'
option src_port '67-68'
option dest_port '67-68'
config rule 'wan_ssh_turris_rule'
option name 'wan_ssh_turris_rule'
option enabled '0'
option dest_port '22'
option proto 'tcp'
option src 'wan'
config rule 'wan_http_turris_rule'
option name 'wan_http_turris_rule'
option enabled '0'
option dest_port '80'
option proto 'tcp'
option src 'wan'
config rule 'wan_https_turris_rule'
option name 'wan_https_turris_rule'
option enabled '0'
option dest_port '443'
option proto 'tcp'
option src 'wan'
config rule 'turris_wan_6in4_rule'
option enabled '0'
config zone 'turris_vpn_client'
option name 'tr_vpn_cl'
option masq '1'
config forwarding 'turris_vpn_client_forward'
option src 'lan'
option dest 'tr_vpn_cl'
config zone 'vpn_turris'
option enabled '1'
option name 'vpn_turris'
option masq '1'
list network 'vpn_turris'
config rule 'vpn_turris_rule'
option enabled '1'
option name 'vpn_turris_rule'
option src 'wan'
option dest_port '1194'
option proto 'tcp'
config forwarding 'vpn_turris_forward_lan_in'
option enabled '1'
option src 'vpn_turris'
option dest 'lan'
config forwarding 'vpn_turris_forward_lan_out'
option enabled '1'
option src 'lan'
option dest 'vpn_turris'
config forwarding 'vpn_turris_forward_wan_out'
option enabled '0'
option dest 'wan'
config redirect
option src 'wan'
option name 'nginx (jira / conf / gitlab)'
option src_dport '80'
option target 'DNAT'
option dest_ip '192.168.1.238'
option dest 'lan'
list proto 'tcp'
option enabled '0'
config redirect
option src 'wan'
option name 'nginx-sec'
option src_dport '443'
option dest 'lan'
list proto 'tcp'
option enabled '0'
config redirect
option src 'wan'
option name 'ssh (gitlab)'
option src_dport '22'
option dest_ip '192.168.1.182'
list proto 'tcp'
option dest 'lan'
option enabled '1'
config include 'bcp38'
option type 'script'
option path '/usr/lib/bcp38/run.sh'
option family 'IPv4'
option reload '1'
config include 'miniupnpd'
option path '/usr/share/miniupnpd/firewall.include'
option family 'any'
option reload '1'
config rule
option src 'wan'
option target 'DROP'
option proto 'all'
option extra '-m limit --limit 3/min --limit-burst 10 -j LOG --log-prefix "FW_DROP: "'
The target system 192.168.1.182 is pingable as well as ssh is working from the turris to the .182 box.
I cannot seem to find the issue and I think that I have hit a bug somehow.
