I have an ATT gateway nokia modem and am trying to set up the Turris Omnia behind it as a router.
How do I set up the port forwarding on the Omnia? The gateway is setup with a NAT server, so theoretically all the ports should be open and pointing towards the omnia. I can connect to the internet on the omnia wifi but no matter what I do, all the ports are closed and I cant get any forward to work.
Do I need to point the external IP of the omnia 168.1.167 to its internal ip? then route to my pc?
