Hello guys,
in the beginning I want to state I am more of monkey see, monkey do type of guy. Not much of a skilled with net and router settings. Therefore I am reaching out for a community help.
In these times my band decided to try to host Killing Floor seance but as I tried before I know there must be port forwarding set. I succeeded on my old oruter once before but can’t get a hold with my Omnia.
Could you please provide a guide how to properly set it up? Screenshot or something?
Well based on your screenshot your config is correct if you changed source zone as mentioned. Did you click „save and apply“? Maybe restart? Is there a modem/router in front of your Omnia that could intercept traffic? Do you have a Dual Stack Light Connection (also called Provider NAT or Carrier Grade NAT)?
do it in "network>firewall>traffic rules>new-port-forward-rule ,not in “portforward” section (that is maybe sometimes confusing where to use , i think that one just make the forwarding rule, but not open the port on wan:firewall actually so later you have to have port-fwd-rule and open-port-rule , so doing directly in traffic section you save one entry in uci-firewall
you have to make source zone “wan” with port-range and open for all ips
destination will be zone “lan” with direct target to some ip:port
you have to do TCP and UDP separately (ie two rules) .
save and apply and wait till firewall will restart
