Port forward for Wireguard server on internal network does not work any more [TOS6]
I have a Wireguard server on a host on my internal network. On TOS5 I setup a port forward for traffic from outside to this machine (UDP). It worked well.
On TOS6 this setup stopped working. I tried to delete / add port forward again, I still cannot connect my outside client to the internal Wireguard server.
Other port forwards work.
Any ideas? Do I need to change my Wireguard setup in some way?
Note: Wireguard is not running on Turris, I just have a port forward to another host
So it does work if I’m outside my own network. This is a change from TOS5. What is the best way to solve it (so it works also from inside)?
Solved by adding custom hostname for Wireguard and resolv it to correct host from inside.
