Youre right, just I did not need to reconfigure WIFI, it kept working fine.
(your links to translator does not work for me, it just displays “page is already in english” and nothing more)
Needless to say, I had to isolate one of the SSD’s pin Switch to force mSata until then it did not detect the SSD
I see port COM3 in system Windows 10 (driver is ready ) but i I can’t connect Putty terminal window - I would rather ask support to perform the necessary steps to install the system on an SSD.
The instructions for the procedure via serial port in the documentation are not sufficiently detailed for me. Unfortunately support does not respond almost at all
