Pkupdate: always the same package appears
Good Morning
Since the last update i have every night the same package which should be updated. Update process is working but after the recommended reboot and pgkupdate on console, the same packages appears (a lot of kmod packages!).
I thout it could be a storage problem. Then i deleted some snapshots. But after reboot the deleted snapshots appears in the list again. Very strange!
Has someone the same problem and a solution for that?
Best whishes
This looks like a flash failure. Another option is mixing upstream OpenWRT and our feeds. If you have not touched upstream OpenWRT then please contact our support. See https://doc.turris.cz/doc/en/howto/error_reporting
I opened a ticket on 16. but no one is in charge…
