Hi, read somewhere that mounting drive with clear_cache option can resolve those issue but today experienced similar error:
root@turris:~# lxc-attach -n vrata
lxc-attach: vrata: parse.c: lxc_file_for_each_line_mmap: 107 I/O error - Failed to sendfile “/srv/lxc/vrata/config”
Failed to load config for vrata
Dec 7 10:07:01 turris crond[28318]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Dec 7 11:07:26 turris kernel: [347621.122276] sd 3:0:0:0: [sda] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:26 turris kernel: [347621.130677] sd 3:0:0:0: [sda] tag#20 CDB: opcode=0x28 28 00 00 1d 80 80 00 00 20 00
Dec 7 11:07:26 turris kernel: [347621.138449] print_req_error: I/O error, dev sda, sector 1933440
Dec 7 11:07:26 turris kernel: [347621.144483] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 424, flush 0, corrupt 0, gen 0
Dec 7 11:07:26 turris kernel: [347621.154810] sd 3:0:0:0: [sda] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:26 turris kernel: [347621.163203] sd 3:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:26 turris kernel: [347621.170972] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:26 turris kernel: [347621.176919] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 425, flush 0, corrupt 0, gen 0
Dec 7 11:07:26 turris kernel: [347621.186725] sd 3:0:0:0: [sda] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:26 turris kernel: [347621.195121] sd 3:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:26 turris kernel: [347621.202891] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:26 turris kernel: [347621.208828] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 426, flush 0, corrupt 0, gen 0
Dec 7 11:07:26 turris kernel: [347621.220128] sd 3:0:0:0: [sda] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:26 turris kernel: [347621.228533] sd 3:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:26 turris kernel: [347621.236309] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:26 turris kernel: [347621.242248] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 427, flush 0, corrupt 0, gen 0
Dec 7 11:07:26 turris kernel: [347621.254374] sd 3:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:26 turris kernel: [347621.262765] sd 3:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:26 turris kernel: [347621.270526] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:26 turris kernel: [347621.276475] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 428, flush 0, corrupt 0, gen 0
Dec 7 11:07:26 turris kernel: [347621.289737] sd 3:0:0:0: [sda] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:26 turris kernel: [347621.298150] sd 3:0:0:0: [sda] tag#25 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:26 turris kernel: [347621.305924] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:26 turris kernel: [347621.311861] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 429, flush 0, corrupt 0, gen 0
Dec 7 11:07:26 turris kernel: [347621.324859] sd 3:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:26 turris kernel: [347621.333268] sd 3:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 00 01 f8 80 00 00 20 00
Dec 7 11:07:26 turris kernel: [347621.341032] print_req_error: I/O error, dev sda, sector 129152
Dec 7 11:07:26 turris kernel: [347621.346985] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 430, flush 0, corrupt 0, gen 0
Dec 7 11:07:26 turris kernel: [347621.356740] sd 3:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:26 turris kernel: [347621.365131] sd 3:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:26 turris kernel: [347621.372903] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:26 turris kernel: [347621.378839] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 431, flush 0, corrupt 0, gen 0
Dec 7 11:07:27 turris kernel: [347622.273931] sd 3:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:27 turris kernel: [347622.282311] sd 3:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 00 1d 80 80 00 00 20 00
Dec 7 11:07:27 turris kernel: [347622.290099] print_req_error: I/O error, dev sda, sector 1933440
Dec 7 11:07:27 turris kernel: [347622.296135] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 432, flush 0, corrupt 0, gen 0
Dec 7 11:07:27 turris kernel: [347622.305663] sd 3:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:27 turris kernel: [347622.314082] sd 3:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:27 turris kernel: [347622.321849] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:27 turris kernel: [347622.327796] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 433, flush 0, corrupt 0, gen 0
Dec 7 11:07:31 turris kernel: [347626.156487] scsi_io_completion: 30 callbacks suppressed
Dec 7 11:07:31 turris kernel: [347626.156502] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:31 turris kernel: [347626.156763] sd 3:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:31 turris kernel: [347626.161856] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 1d 80 80 00 00 20 00
Dec 7 11:07:31 turris kernel: [347626.170140] sd 3:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:31 turris kernel: [347626.178419] print_req_error: 30 callbacks suppressed
Dec 7 11:07:31 turris kernel: [347626.178422] print_req_error: I/O error, dev sda, sector 1933440
Dec 7 11:07:31 turris kernel: [347626.178426] btrfs_dev_stat_print_on_error: 30 callbacks suppressed
Dec 7 11:07:31 turris kernel: [347626.178431] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 464, flush 0, corrupt 0, gen 0
Dec 7 11:07:31 turris kernel: [347626.186102] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:31 turris kernel: [347626.226255] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 465, flush 0, corrupt 0, gen 0
Dec 7 11:07:31 turris kernel: [347626.236259] sd 3:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:31 turris kernel: [347626.237087] sd 3:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:31 turris kernel: [347626.244571] sd 3:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 00 1d 80 80 00 00 20 00
Dec 7 11:07:31 turris kernel: [347626.252859] sd 3:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:31 turris kernel: [347626.260532] print_req_error: I/O error, dev sda, sector 1933440
Dec 7 11:07:31 turris kernel: [347626.268207] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:31 turris kernel: [347626.274231] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 466, flush 0, corrupt 0, gen 0
Dec 7 11:07:31 turris kernel: [347626.280160] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 467, flush 0, corrupt 0, gen 0
Dec 7 11:07:31 turris kernel: [347626.299560] sd 3:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:31 turris kernel: [347626.300455] sd 3:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:31 turris kernel: [347626.307870] sd 3:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 00 01 f8 80 00 00 20 00
Dec 7 11:07:31 turris kernel: [347626.316168] sd 3:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:31 turris kernel: [347626.323844] print_req_error: I/O error, dev sda, sector 129152
Dec 7 11:07:31 turris kernel: [347626.331512] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:31 turris kernel: [347626.337448] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 468, flush 0, corrupt 0, gen 0
Dec 7 11:07:31 turris kernel: [347626.343382] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 469, flush 0, corrupt 0, gen 0
Dec 7 11:07:31 turris kernel: [347626.362140] sd 3:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:31 turris kernel: [347626.370434] sd 3:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:31 turris kernel: [347626.378119] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:31 turris kernel: [347626.384066] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 470, flush 0, corrupt 0, gen 0
Dec 7 11:07:31 turris kernel: [347626.460376] sd 3:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:31 turris kernel: [347626.468684] sd 3:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 00 1d 80 80 00 00 20 00
Dec 7 11:07:31 turris kernel: [347626.476369] print_req_error: I/O error, dev sda, sector 1933440
Dec 7 11:07:31 turris kernel: [347626.482402] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 471, flush 0, corrupt 0, gen 0
Dec 7 11:07:31 turris kernel: [347626.491887] sd 3:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:31 turris kernel: [347626.500202] sd 3:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:31 turris kernel: [347626.507883] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:31 turris kernel: [347626.513823] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 472, flush 0, corrupt 0, gen 0
Dec 7 11:07:31 turris kernel: [347626.524991] sd 3:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:31 turris kernel: [347626.533308] sd 3:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:31 turris kernel: [347626.540983] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:31 turris kernel: [347626.546928] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 473, flush 0, corrupt 0, gen 0
Dec 7 11:07:36 turris kernel: [347631.678677] scsi_io_completion: 28 callbacks suppressed
Dec 7 11:07:36 turris kernel: [347631.684036] sd 3:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:36 turris kernel: [347631.692419] sd 3:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 00 1d 80 80 00 00 20 00
Dec 7 11:07:36 turris kernel: [347631.695586] sd 3:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:36 turris kernel: [347631.700182] print_req_error: 28 callbacks suppressed
Dec 7 11:07:36 turris kernel: [347631.700185] print_req_error: I/O error, dev sda, sector 1933440
Dec 7 11:07:36 turris kernel: [347631.708568] sd 3:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:36 turris kernel: [347631.713619] btrfs_dev_stat_print_on_error: 28 callbacks suppressed
Dec 7 11:07:36 turris kernel: [347631.713623] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 502, flush 0, corrupt 0, gen 0
Dec 7 11:07:36 turris kernel: [347631.742870] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:36 turris kernel: [347631.748809] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 503, flush 0, corrupt 0, gen 0
Dec 7 11:07:36 turris kernel: [347631.758578] sd 3:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:36 turris kernel: [347631.758793] sd 3:0:0:0: [sda] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:36 turris kernel: [347631.766987] sd 3:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 00 1d 80 80 00 00 20 00
Dec 7 11:07:36 turris kernel: [347631.775350] sd 3:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:36 turris kernel: [347631.783113] print_req_error: I/O error, dev sda, sector 1933440
Dec 7 11:07:36 turris kernel: [347631.790868] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:36 turris kernel: [347631.796892] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 504, flush 0, corrupt 0, gen 0
Dec 7 11:07:36 turris kernel: [347631.802822] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 505, flush 0, corrupt 0, gen 0
Dec 7 11:07:36 turris kernel: [347631.803313] sd 3:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:36 turris kernel: [347631.815513] sd 3:0:0:0: [sda] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:36 turris kernel: [347631.821155] sd 3:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 00 01 f8 80 00 00 20 00
Dec 7 11:07:36 turris kernel: [347631.829540] sd 3:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:36 turris kernel: [347631.829544] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:36 turris kernel: [347631.829550] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 506, flush 0, corrupt 0, gen 0
Dec 7 11:07:36 turris kernel: [347631.837918] print_req_error: I/O error, dev sda, sector 129152
Dec 7 11:07:36 turris kernel: [347631.837924] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 507, flush 0, corrupt 0, gen 0
Dec 7 11:07:36 turris kernel: [347631.884010] sd 3:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:36 turris kernel: [347631.892413] sd 3:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:36 turris kernel: [347631.900180] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:36 turris kernel: [347631.906123] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 508, flush 0, corrupt 0, gen 0
Dec 7 11:07:36 turris kernel: [347631.982687] sd 3:0:0:0: [sda] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:36 turris kernel: [347631.991077] sd 3:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 00 1d 80 80 00 00 20 00
Dec 7 11:07:36 turris kernel: [347631.998855] print_req_error: I/O error, dev sda, sector 1933440
Dec 7 11:07:36 turris kernel: [347632.004883] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 509, flush 0, corrupt 0, gen 0
Dec 7 11:07:36 turris kernel: [347632.014416] sd 3:0:0:0: [sda] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:36 turris kernel: [347632.022809] sd 3:0:0:0: [sda] tag#18 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:36 turris kernel: [347632.030570] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:36 turris kernel: [347632.036517] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 510, flush 0, corrupt 0, gen 0
Dec 7 11:07:36 turris kernel: [347632.047585] sd 3:0:0:0: [sda] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:36 turris kernel: [347632.055980] sd 3:0:0:0: [sda] tag#19 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:36 turris kernel: [347632.063754] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:36 turris kernel: [347632.069691] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 511, flush 0, corrupt 0, gen 0
Dec 7 11:07:45 turris kernel: [347640.238620] scsi_io_completion: 36 callbacks suppressed
Dec 7 11:07:45 turris kernel: [347640.238630] sd 3:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:45 turris kernel: [347640.252354] sd 3:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:45 turris kernel: [347640.260114] print_req_error: 36 callbacks suppressed
Dec 7 11:07:45 turris kernel: [347640.260117] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:45 turris kernel: [347640.271117] btrfs_dev_stat_print_on_error: 36 callbacks suppressed
Dec 7 11:07:45 turris kernel: [347640.271122] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 548, flush 0, corrupt 0, gen 0
Dec 7 11:07:45 turris kernel: [347640.287575] sd 3:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:45 turris kernel: [347640.295974] sd 3:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 00 1d 80 80 00 00 20 00
Dec 7 11:07:45 turris kernel: [347640.303750] print_req_error: I/O error, dev sda, sector 1933440
Dec 7 11:07:45 turris kernel: [347640.309774] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 549, flush 0, corrupt 0, gen 0
Dec 7 11:07:45 turris kernel: [347640.320730] sd 3:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:07:45 turris kernel: [347640.329047] sd 3:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 08 1d c0 00 00 20 00
Dec 7 11:07:45 turris kernel: [347640.336733] print_req_error: I/O error, dev sda, sector 531904
Dec 7 11:07:45 turris kernel: [347640.342677] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 550, flush 0, corrupt 0, gen 0
Dec 7 10:07:53 turris sshd[28518]: Accepted password for root from 192.168.1.2 port 45673 ssh2
Dec 7 10:07:53 turris sshd[28521]: Accepted password for root from 192.168.1.2 port 45676 ssh2
Dec 7 10:08:01 turris crond[28557]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
Dec 7 11:08:05 turris kernel: [347661.008384] sd 3:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:08:05 turris kernel: [347661.016798] sd 3:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 00 08 20 40 00 00 20 00
Dec 7 11:08:05 turris kernel: [347661.024582] print_req_error: I/O error, dev sda, sector 532544
Dec 7 11:08:05 turris kernel: [347661.030532] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 551, flush 0, corrupt 0, gen 0
Dec 7 11:08:05 turris kernel: [347661.052507] sd 3:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
Dec 7 11:08:05 turris kernel: [347661.060915] sd 3:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 00 08 20 40 00 00 20 00
Dec 7 11:08:05 turris kernel: [347661.068686] print_req_error: I/O error, dev sda, sector 532544
Dec 7 11:08:05 turris kernel: [347661.074652] BTRFS error (device sda): bdev /dev/sda errs: wr 133, rd 552, flush 0, corrupt 0, gen 0
Also when loading PiHole GUI status was “UNKNOWN” before gui couldn’t even load so I presume that option clear_cache did at least something.
