Has anyone played with this configuration?
If so, can someone share the knowledge, step by step?
Why are you not trying to run it in a Linux container instead?
I have Pihole running in a Linux Ubuntu 20.04 container and it works flawlessly.
Can you link a guide?
Well not a guide, but rather just the normal guide to use.
Do you know how to setup a Linux container (LXC) on you Turris Omnia? Do PLEASE put a mSATA drive in your Turris Omnia and do NOT use the eMMC. I use a Samsung SSD 860 EVO mSATA 1TB
It works without any problems.
Manual putting mSATA ssd: Turris Omnia: How to connect an mSATA disk - YouTube
Linux container manual: Linux containers [Turris wiki]
Pihole manual: How to Install Pi-Hole on Ubuntu (Beginner’s Guide) – RaspberryTips
REMEMBER: Point the Linux container directory to the right directory. In my case is like this. So it is pointing to my mSATA mount
/etc/lxc/lxc.conf:
lxc.lxcpath = /mnt/LXC
For the auto-start of the container after for example a reboot.
/etc/config/lxc-auto
config container
option name K-Router-LXC
option timeout 300
root@K-Router:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/mmcblk0p1 7.3G 315.9M 6.8G 4% /
devtmpfs 512.0K 0 512.0K 0% /dev
tmpfs 1008.1M 2.1M 1005.9M 0% /tmp
/dev/sda2 910.0G 144.3G 764.1G 16% /mnt/LXC
/dev/sda1 4.0G 3.4M 4.0G 0% /mnt/monitoring
Yes, I have an mSATA SSD.
Of course, I once put a Pi-hole on the LXC, but at the moment I don’t own one. As TurrisOS 6.x supports docker, I wanted to try this method.
I found a guide:
Unfortunately, I’m stuck on this:
root@turris:~# pwd
/root
root@turris:~# ls -al
drwxr-xr-x 1 root root 114 Feb 6 19:36 .
drwxr-xr-x 1 root root 146 Feb 1 16:24 ..
drwx------ 1 root root 4 Nov 11 23:55 .cache
drwx------ 1 root root 12 Jan 21 22:40 .config
drwx------ 1 root root 10 Nov 11 23:55 .local
drwx------ 1 root root 30 Nov 13 11:36 .ssh
-rw-r--r-- 1 root root 254 Feb 4 23:38 .wget-hsts
-rw-r--r-- 1 root root 987 Feb 6 19:36 docker-compose.yml
drwxr-xr-x 1 root root 126 Feb 6 19:32 pihole
root@turris:~# docker-compose up -d pihole
Building with native build. Learn about native build in Compose here: https://docs.docker.com/go/compose-native-build/
Creating network "root_internal" with the default driver
ERROR: Failed to Setup IP tables: Unable to enable SKIP DNAT rule: (iptables failed: iptables --wait -t nat -I DOCKER -i br-8880e85ebb73 -j RETURN: iptables: No chain/target/match by that name.
(exit status 1))
Anyone have any advice?
Restart docker and working:
root@turris:~# /etc/init.d/dockerd restart
Creating network "lan" with driver "macvlan"
Pulling pihole (pihole/pihole:2021.09)...
2021.09: Pulling from pihole/pihole
5f46b20dcee3: Pull complete
0fc08ea2cc1b: Pull complete
1efc5911b4dd: Pull complete
c54f511bf874: Pull complete
e133dc5f804c: Pull complete
c3f9bffcbe07: Pull complete
ac287de2dccb: Pull complete
1864c859b776: Pull complete
Digest: sha256:42837bd859b91b5584e9df185a59b16fda2f04109d68f050889a58274ff27004
Status: Downloaded newer image for pihole/pihole:2021.09
Creating pihole ... done
As far i see docker runs meanwhile directly on OpenWRT.
I search a working Docker-compose fiele for that configuration.
I assume that some updates are the cause why.
not work.
