I’m glad to be here, received my Turris Omnia yesterday!
I configured device using reForis and enabled W-LAN (which is working properly), but PCI1 LED still is off. Not as in the product pictures, where it is lit.
Might this be a software bug?
When I boot up the device, LEDs show these states:
There are usually 2 wifi cards and 3 PCI slots. I’m not sure what’s the factory placement of the wifi cards, but definitely one of the PCI slots is empty so its LED should be off. The other PCI LEDs are lit only when there is an AP configured for the card (if I remember correctly).
Luci (advanced administration) would show you how is the LED configured. I don’t remember on which page (search either for Rainbow or LED configuration).
In that case, it seems like a bug to me. Can you try switching to the testing branch HBT and enabling the experimental Latest firmware package list (Reforis->Package Management->Packages, select Latest firmware and all three subitems). This latest firmware could fix some of the problems. If your Omnia is new, it should work without issues. On older pieces (i.e. manufactured in 2017), installation of the latest firmware is prone to fail and partially brick the device. Please note that even if you have a newer Omnia, the Latest firmware package list is experimental and in worst case, you might need a 3.3 V UART->USB cable to debirck the device. Use on your own risk.
Its not different. Since Turris team upstreamed leds patches to mainline kernel the naming convention for leds changed. Dont do what @peci1 suggested just select the new names of leds in luci and restart rainbow service. So rgb:wlan-1 and rgb:wan etc.
Good point! I haven’t expected this to be a problem because the Omnia is new. So is the migration from older versions not working (in case it came with older TOS), or is the default config wrong?
Hmm, 6.0 was the first version to use the new LED driver that started using rgb: instead of omnia-leds: . Moreover, there were several critical bugs in the 6.0 release. I actually wonder they shipped a router with this release.
I think more investigation is not needed and the problem was due to the problematic 6.0 version you started with. But Turris team, feel free to dig into it Shipping routers with broken config is definitely a problem if there are still some in stock.
I bought it through Amazon Prime just recently. So there are more people that should have this problem.
Gladly it was “just” a broken LED, nothing more serious.
