Hello
I seem to remember installing the Pakon Forris plugin? a few months back. I cannot remember how or where I found it. Was it a plugin and now part of the pakon package? IDK.
This morning I noticed suricata was working one core at 100%. I don’t really use pakon so I unchecked it thinking it would be removed along with the Suricata and the tab in Forris. Not so. Suricata is still being started by something(pakon-light?)and I still have the Pakon tab in forris. CPU is not being pegged any longer.
I do not have the device detection package nor have I ever installed it. Is something else using suricata and what is pakon-light?
PID USER PRI NI VIRT RES SHR S CPU% MEM% TIME+ Command
4224 root 20 0 50036 33228 3688 S 0.7 1.6 0:23.73 /usr/bin/suricata -c /etc/suricata-pakon/suricata.yaml -q 10 --pidfile /var/run/suricata/suricata.pid
4307 root 20 0 50036 33228 3688 S 0.7 1.6 0:19.55 /usr/bin/suricata -c /etc/suricata-pakon/suricata.yaml -q 10 --pidfile /var/run/suricata/suricata.pid
13136 root 20 0 1480 1116 808 R 0.7 0.1 0:01.74 htop
859 root 20 0 884 516 496 S 0.7 0.0 0:00.42 /sbin/ubusd
4258 root 20 0 11472 9252 3496 S 0.0 0.4 0:04.08 python /usr/bin/foris-ws -a ubus --host 127.0.0.1 --port 9080 ubus --path /var/run/ubus.sock
4305 root 20 0 50036 33228 3688 S 0.0 1.6 0:00.88 /usr/bin/suricata -c /etc/suricata-pakon/suricata.yaml -q 10 --pidfile /var/run/suricata/suricata.pid
3902 root 20 0 13800 12200 3576 S 0.0 0.6 0:06.40 python3 /usr/libexec/pakon-light/pakon-monitor.py
I had a /etc/suricata-pakon/
and
/etc/suricata
I rm -rf those folders then tried reinstalling then removing pakon. reboot etc…
Device | Turris Omnia - rtrom01 |
Serial number | 5153******* |
Turris OS version | 3.10.2 |
Kernel version | 4.4.136-695e41116993e0a4f080354e72f13d91-0 |
If anyone has some insight into this I am all ears.
Thank you
