Dle dostupných informací má tento DVB-T2 tuner fungovat od verze kernelu 4.7.
Zkouším ho zprovoznit na Turris Omnia s Turris OS 4.0.3 (HBT), prozatím neúspěšně.
Nejprve popis chování na Ubuntu 18.04.3 (kernel 4.15.0-72)
dmesg
[ 736.666299] usb 1-1: new high-speed USB device number 5 using xhci_hcd [ 736.815617] usb 1-1: New USB device found, idVendor=2040, idProduct=0265 [ 736.815625] usb 1-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2 [ 736.815631] usb 1-1: Product: dualHD [ 736.815635] usb 1-1: Manufacturer: HCW [ 736.815640] usb 1-1: SerialNumber: 0014042676 [ 736.872311] media: Linux media interface: v0.10 [ 736.878839] Linux video capture interface: v2.00 [ 736.884640] em28xx 1-1:1.0: New device HCW dualHD @ 480 Mbps (2040:0265, interface 0, class 0) [ 736.884643] em28xx 1-1:1.0: DVB interface 0 found: isoc [ 736.884689] em28xx 1-1:1.0: chip ID is em28174 [ 738.098352] em28xx 1-1:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0xe1e2cdc8 [ 738.098358] em28xx 1-1:1.0: EEPROM info: [ 738.098363] em28xx 1-1:1.0: microcode start address = 0x0004, boot configuration = 0x01 [ 738.105578] em28xx 1-1:1.0: AC97 audio (5 sample rates) [ 738.105584] em28xx 1-1:1.0: 500mA max power [ 738.105592] em28xx 1-1:1.0: Table at offset 0x27, strings=0x0e6a, 0x1888, 0x087e [ 738.106244] em28xx 1-1:1.0: Identified as Hauppauge WinTV-dualHD DVB (card=99) [ 738.110862] tveeprom: Hauppauge model 204109, rev B3I6, serial# 14042676 [ 738.110868] tveeprom: tuner model is SiLabs Si2157 (idx 186, type 4) [ 738.110874] tveeprom: TV standards PAL(B/G) NTSC(M) PAL(I) SECAM(L/L') PAL(D/D1/K) ATSC/DVB Digital (eeprom 0xfc) [ 738.110877] tveeprom: audio processor is None (idx 0) [ 738.110880] tveeprom: has no radio, has IR receiver, has no IR transmitter [ 738.110888] em28xx 1-1:1.0: dvb set to isoc mode. [ 738.111383] usbcore: registered new interface driver em28xx [ 738.128428] em28xx 1-1:1.0: Binding DVB extension [ 738.135586] i2c i2c-6: Added multiplexed i2c bus 7 [ 738.135589] si2168 6-0064: Silicon Labs Si2168-B40 successfully identified [ 738.135590] si2168 6-0064: firmware version: B 4.0.2 [ 738.142729] si2157 7-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached [ 738.142779] dvbdev: DVB: registering new adapter (1-1:1.0) [ 738.142782] em28xx 1-1:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)... [ 738.144143] em28xx 1-1:1.0: DVB extension successfully initialized [ 738.144145] em28xx: Registered (Em28xx dvb Extension) extension [ 738.151892] em28xx 1-1:1.0: Registering input extension [ 738.182094] Registered IR keymap rc-hauppauge [ 738.182468] rc rc0: 1-1:1.0 IR as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/rc/rc0 [ 738.182522] input: 1-1:1.0 IR as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/rc/rc0/input24 [ 738.182622] em28xx 1-1:1.0: Input extension successfully initialized [ 738.182624] em28xx: Registered (Em28xx Input Extension) extension
lsmod
Module Size Used by rc_hauppauge 16384 0 em28xx_rc 20480 0 rc_core 36864 3 em28xx_rc,rc_hauppauge si2157 16384 1 si2168 20480 1 i2c_mux 16384 1 si2168 em28xx_dvb 32768 0 dvb_core 126976 1 em28xx_dvb em28xx 90112 2 em28xx_rc,em28xx_dvb tveeprom 24576 1 em28xx v4l2_common 16384 1 em28xx videodev 184320 1 v4l2_common media 40960 3 videodev,si2157,em28xx
Nyní chování na Turris OS 4.0.3 (kernel 4.14.158)
dmesg
[ 5851.900726] usb 2-1: new high-speed USB device number 3 using xhci-hcd [ 5852.081019] usb 2-1: config 1 interface 0 altsetting 0 endpoint 0x84 has wMaxPacketSize 0, skipping [ 5852.090120] usb 2-1: config 1 interface 0 altsetting 0 endpoint 0x85 has wMaxPacketSize 0, skipping [ 5852.099901] em28xx 2-1:1.0: New device HCW dualHD @ 480 Mbps (2040:0265, interface 0, class 0) [ 5852.108605] em28xx 2-1:1.0: DVB interface 0 found: isoc [ 5852.113925] em28xx 2-1:1.0: chip ID is em28174 [ 5853.416660] em28xx 2-1:1.0: EEPROM ID = 26 00 01 00, EEPROM hash = 0xe1e2cdc8 [ 5853.423848] em28xx 2-1:1.0: EEPROM info: [ 5853.427781] em28xx 2-1:1.0: microcode start address = 0x0004, boot configuration = 0x01 [ 5853.441947] em28xx 2-1:1.0: AC97 audio (5 sample rates) [ 5853.447278] em28xx 2-1:1.0: 500mA max power [ 5853.451583] em28xx 2-1:1.0: Table at offset 0x27, strings=0x0e6a, 0x1888, 0x087e [ 5853.459207] em28xx 2-1:1.0: Identified as Hauppauge WinTV-dualHD DVB (card=99) [ 5853.477366] tveeprom: Hauppauge model 204109, rev B3I6, serial# 14042676 [ 5853.484103] tveeprom: tuner model is SiLabs Si2157 (idx 186, type 4) [ 5853.490487] tveeprom: TV standards PAL(B/G) NTSC(M) PAL(I) SECAM(L/L') PAL(D/D1/K) ATSC/DVB Digital (eeprom 0xfc) [ 5853.500796] tveeprom: audio processor is None (idx 0) [ 5853.505857] tveeprom: has no radio, has IR receiver, has no IR transmitter [ 5853.512774] em28xx 2-1:1.0: dvb set to isoc mode.
lsmod (em28xx musel být vložen ručně pomocí modprobe)
dvb_core 81920 2 dvb_usb_v2,dvb_usb dvb_pll 16384 0 dvb_usb 24576 0 dvb_usb_v2 20480 0 em28xx 69632 0 i2c_mux_gpio 16384 0 rc_core 28672 2 dvb_usb_v2,dvb_usb si2157 16384 0 si2168 20480 0 tveeprom 20480 1 em28xx usbserial 24576 2 qcserial,usb_wwan v4l2_common 16384 1 em28xx videodev 114688 1 v4l2_common
lsusb
Bus 002 Device 003: ID 2040:0265 Hauppauge
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=em28xx, 480M
lsusb -v
Bus 002 Device 003: ID 2040:0265 Hauppauge Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x2040 Hauppauge idProduct 0x0265 bcdDevice 1.00 iManufacturer 3 HCW iProduct 1 dualHD iSerial 2 0014042676 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 55 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 500mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 0 bInterfaceProtocol 0 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x84 EP 4 IN bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0000 1x 0 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x85 EP 5 IN bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x0000 1x 0 bytes bInterval 1 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 1 bNumEndpoints 2 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 0 bInterfaceProtocol 0 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x84 EP 4 IN bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x03ac 1x 940 bytes bInterval 1 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x85 EP 5 IN bmAttributes 1 Transfer Type Isochronous Synch Type None Usage Type Data wMaxPacketSize 0x03ac 1x 940 bytes bInterval 1 Device Qualifier (for other device speed): bLength 10 bDescriptorType 6 bcdUSB 2.00 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 bNumConfigurations 1 Device Status: 0x0000 (Bus Powered)
ls /lib/firmware -l
-rw-r--r-- 1 root root 6919 Dec 18 22:54 dvb-demod-si2168-b40-01.fw
Další moduly z Ubuntu se mi v balíčcích Turris OS nepodařilo dohledat. Nebo například v balíčku kmod-i2c-mux není žádný modul (i2c_mux.ko).
Jelikož již nejsem schopen sám se s tím pohnout z místa, chtěl bych požádat o pomoc. Předem velice děkuji.
PS: První spuštění Tvheadend (nutnost použití “tvheadend -C”) není také úplně uživatelsky přívětivé.
