I’m asking for your advice, I installed openvpn and it doesn’t work
It works from the local network
but it doesn’t work from the “outside”. (tested on windows and android) - connection timed out
Any advice?
Any advice?
Are you sure you have public IP address? Did you set it up with Reforis?
