Dobrý den,
nastavil jsem ve forisu OpenVPN. Stáhl jsem si konfiguraci a použil v notebooku. Když se pokusím připojit s jiné sítě, tak se mi zobrazí toto:
Tue Feb 05 14:09:37 2019 OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 26 2018
Tue Feb 05 14:09:37 2019 Windows version 6.2 (Windows 8 or greater) 64bit
Tue Feb 05 14:09:37 2019 library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10
Enter Management Password:
Tue Feb 05 14:09:37 2019 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Tue Feb 05 14:09:37 2019 Need hold release from management interface, waiting…
Tue Feb 05 14:09:37 2019 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Tue Feb 05 14:09:38 2019 MANAGEMENT: CMD ‘state on’
Tue Feb 05 14:09:38 2019 MANAGEMENT: CMD ‘log all on’
Tue Feb 05 14:09:38 2019 MANAGEMENT: CMD ‘echo all on’
Tue Feb 05 14:09:38 2019 MANAGEMENT: CMD ‘bytecount 5’
Tue Feb 05 14:09:38 2019 MANAGEMENT: CMD ‘hold off’
Tue Feb 05 14:09:38 2019 MANAGEMENT: CMD ‘hold release’
Tue Feb 05 14:09:38 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]213.xxx.xxxx.xxx:1194
Tue Feb 05 14:09:38 2019 Socket Buffers: R=[65536->65536] S=[65536->65536]
Tue Feb 05 14:09:38 2019 UDP link local: (not bound)
Tue Feb 05 14:09:38 2019 UDP link remote: [AF_INET]213.xxx.xxx.xxx:1194
Tue Feb 05 14:09:38 2019 MANAGEMENT: >STATE:1549372178,WAIT,
Tue Feb 05 14:10:38 2019 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Tue Feb 05 14:10:38 2019 TLS Error: TLS handshake failed
Tue Feb 05 14:10:38 2019 SIGUSR1[soft,tls-error] received, process restarting
Tue Feb 05 14:10:38 2019 MANAGEMENT: >STATE:1549372238,RECONNECTING,tls-error,
Tue Feb 05 14:10:38 2019 Restart pause, 5 second(s)
Poradíte co s tím
