Hi.
I am going to buy Turris Omnia and the main reason is powerful router with full IPv6 support and VPN server. I have 100 Mbit/s up/down connectivity with dualstack and I want to provide this connectivity to a small office (5 computers or so). But the main question is about VPN. I’ve never used OpenVPN on my private Turris 1.0. I’d like to get as high speed as possible also for OpenVPN clients, but based on this discussion the speed will be around 50-60 Mbit/s max., correct? VPN Performance on Marvell CPU
Is IPv6 also supported for OpenVPN? I mean when I will be connected from dualstack network, it will use IPv6 connectivity to the VPN server and then IPv6 connectivity to the Internet? I will use a domain name for the router’s public IPs with both A and AAAA records. And if I will be on IPv4-only network, I will be connected via IPv4 to the VPN server but I’ll get IPv6 IP and connectivity from the VPN server?
And is there any update about routing all packets through the VPN server, or do we have to still configure it manually like here? OpenVPN server easy and fast
Thank you
