Openvpn was working, but it isnt anymore. Useally this works again when I pull out the latest medkit and start from scratch. Now im really busy, so ive de installed openvpn for now.
Is it possible to have a reset button so everything; services, certificates etc gets reset? Saves me a lot of work.
I think I have the same problem. Running and OpenVPNserver to acess my local network from outside. It seems like it stopped working 1-2days ago
Another thing that tha happend at the same time happening is that i get a constant message that updater is running, and has been doing this for 1-2 days days
It only says “Problem connecting to server”. I had it working in the past, using the easy setup menu in foris.
I dont remember that I have to open ports. That is what the easy setup menu in foris does I believe. Anyways, Im gonna wait until the next update to see if it works. If it doesnt Ill do a medkit flash again.
This is why I want that option to reset everything, certificates, running processes, old (not openvpn) vpn configurations. Im not that experienced with computers so I cant find the cause of this, so flashing medkit and starting from scratch seems the only option for me.
Just a pain in the butt the last couple of months if you ask me. Well, no free wifi for me for now on.
