Hilfe,
mam dve omnie propojene openVPN. Dnes jsem updatnul server na posledni verzi 3.x vse bez problemu, klient se po rebootu serveru bez problemui pripojil. Pote jsem rebootnul klienta (bez upadatu) a uz se znovu nepripojil. Klient je nedostupny na chate, v jinem okrese. Ze zoufalstvi jsem server updatnul na posledni verzi 5.x ale vysledek je stejny. Zacykli se to v resetu spojeni.
Dik za pomoc
Apr 5 16:53:47 turris openvpn(server_turris)[3716]: TCP connection established with [AF_INET]85.160.47.183:12373
Apr 5 16:53:48 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 TLS: Initial packet from [AF_INET]85.160.47.183:12373, sid=73f997ef 376f7144
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 VERIFY OK: depth=1, C=CZ, ST=CA, L=Praha, O=Fort-Funston, OU=MyOrganizationalUnit, CN=Fort-Funston CA, name=EasyRSA, emailAddress=me@myhost.mydomain
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 VERIFY OK: depth=0, C=CZ, ST=CA, L=Praha, O=Fort-Funston, OU=MyOrganizationalUnit, CN=fujitsu, name=EasyRSA, emailAddress=me@myhost.mydomain
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 peer info: IV_VER=2.4.6
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 peer info: IV_PLAT=linux
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 peer info: IV_PROTO=2
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 peer info: IV_NCP=2
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 peer info: IV_LZ4=1
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 peer info: IV_LZ4v2=1
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 peer info: IV_LZO=1
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 peer info: IV_COMP_STUB=1
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 peer info: IV_COMP_STUBv2=1
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 peer info: IV_TCPNL=1
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: 85.160.47.183:12373 [fujitsu] Peer Connection Initiated with [AF_INET]85.160.47.183:12373
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: fujitsu/85.160.47.183:12373 MULTI_sva: pool returned IPv4=10.111.111.6, IPv6=(Not enabled)
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: fujitsu/85.160.47.183:12373 MULTI: Learn: 10.111.111.6 -> fujitsu/85.160.47.183:12373
Apr 5 16:53:49 turris openvpn(server_turris)[3716]: fujitsu/85.160.47.183:12373 MULTI: primary virtual IP for fujitsu/85.160.47.183:12373: 10.111.111.6
Apr 5 16:53:50 turris openvpn(server_turris)[3716]: fujitsu/85.160.47.183:12373 PUSH: Received control message: ‘PUSH_REQUEST’
Apr 5 16:53:50 turris openvpn(server_turris)[3716]: fujitsu/85.160.47.183:12373 SENT CONTROL [fujitsu]: ‘PUSH_REPLY,route 192.168.1.0 255.255.255.0,route 10.111.111.1,topology net30,ping 10,ping-restart 120,ifconfig 10.111.111.6 10.111.111.5,peer-id 0,cipher AES-256-GCM’ (status=1)
Apr 5 16:53:50 turris openvpn(server_turris)[3716]: fujitsu/85.160.47.183:12373 Data Channel: using negotiated cipher ‘AES-256-GCM’
Apr 5 16:53:50 turris openvpn(server_turris)[3716]: fujitsu/85.160.47.183:12373 Outgoing Data Channel: Cipher ‘AES-256-GCM’ initialized with 256 bit key
Apr 5 16:53:50 turris openvpn(server_turris)[3716]: fujitsu/85.160.47.183:12373 Incoming Data Channel: Cipher ‘AES-256-GCM’ initialized with 256 bit key
Apr 5 16:53:50 turris openvpn(server_turris)[3716]: fujitsu/85.160.47.183:12373 Connection reset, restarting [0]
Apr 5 16:53:50 turris openvpn(server_turris)[3716]: fujitsu/85.160.47.183:12373 SIGUSR1[soft,connection-reset] received, client-instance restarting
