I’m trying to use the built-in OpenVPN wizard to setup a connection to my Omnia, but it is causing a lot of issues. When I initially try to connect, the device will be unable to complete establishing the connection. If I click the "apply configuration button, and then try to connect, it works long enough for the device to establish a connection, but then almost immediately stops working again. Moreover, local machines are no longer able to connect to the Internet until the router is rebooted.
I messed around trying to get OpenVPN working on my own earlier on, but I though I’d deleted all the files I added, and removed any modifications. If I want to make sure all OpenVPN files are wiped, is there a command I can use?
Here is the output from cat /var/log/messages | grep openvpn:
2017-04-26T21:42:52+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 TLS: Initial packet from [AF_INET]REMOTEIP:39285, sid=b11e2012 5f366d22
2017-04-26T21:42:52+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 VERIFY OK: depth=1, CN=openvpn
2017-04-26T21:42:52+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 VERIFY OK: depth=0, CN=Xperia_Z5
2017-04-26T21:42:52+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 peer info: IV_GUI_VER=net.openvpn.connect.android_1.1.17-76
2017-04-26T21:42:52+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 peer info: IV_VER=3.0.12
2017-04-26T21:42:52+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 peer info: IV_PLAT=android
2017-04-26T21:42:52+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 peer info: IV_NCP=2
2017-04-26T21:42:52+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 peer info: IV_TCPNL=1
2017-04-26T21:42:52+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 peer info: IV_PROTO=2
2017-04-26T21:42:52+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 peer info: IV_LZO=1
2017-04-26T21:42:53+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
2017-04-26T21:42:53+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 [Xperia_Z5] Peer Connection Initiated with [AF_INET]REMOTEIP:39285
2017-04-26T21:42:53+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39285 PUSH: Received control message: ‘PUSH_REQUEST’
2017-04-26T21:42:53+02:00 notice openvpn(server_turris)[23054]: Xperia_Z5/REMOTEIP:39285 MULTI_sva: pool returned IPv4=10.111.111.6, IPv6=(Not enabled)
2017-04-26T21:42:53+02:00 notice openvpn(server_turris)[23054]: Xperia_Z5/REMOTEIP:39285 MULTI: Learn: 10.111.111.6 → Xperia_Z5/REMOTEIP:39285
2017-04-26T21:42:53+02:00 notice openvpn(server_turris)[23054]: Xperia_Z5/REMOTEIP:39285 MULTI: primary virtual IP for Xperia_Z5/REMOTEIP:39285: 10.111.111.6
2017-04-26T21:42:54+02:00 notice openvpn(server_turris)[23054]: Xperia_Z5/REMOTEIP:39285 PUSH: Received control message: ‘PUSH_REQUEST’
2017-04-26T21:42:54+02:00 notice openvpn(server_turris)[23054]: Xperia_Z5/REMOTEIP:39285 SENT CONTROL [Xperia_Z5]: ‘PUSH_REPLY,route 10.0.0.0 255.255.255.0,route 10.111.111.1,topology net30,ping 10,ping-restart 120,ifconfig 10.111.111.6 10.111.111.5,peer-id 0,cipher AES-256-GCM’ (status=1)
2017-04-26T21:42:54+02:00 notice openvpn(server_turris)[23054]: Xperia_Z5/REMOTEIP:39285 Data Channel Encrypt: Cipher ‘AES-256-GCM’ initialized with 256 bit key
2017-04-26T21:42:54+02:00 notice openvpn(server_turris)[23054]: Xperia_Z5/REMOTEIP:39285 Data Channel Decrypt: Cipher ‘AES-256-GCM’ initialized with 256 bit key
2017-04-26T21:44:55+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39147 TLS: Initial packet from [AF_INET]REMOTEIP:39147, sid=833e0c28 9ad17da3
2017-04-26T21:45:05+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39170 TLS: Initial packet from [AF_INET]REMOTEIP:39170, sid=0f01d807 d15c2c5f
2017-04-26T21:45:15+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39216 TLS: Initial packet from [AF_INET]REMOTEIP:39216, sid=073af22b da62225f
2017-04-26T21:45:25+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39193 TLS: Initial packet from [AF_INET]REMOTEIP:39193, sid=5bb8e120 62dd20b1
2017-04-26T21:45:35+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39308 TLS: Initial packet from [AF_INET]REMOTEIP:39308, sid=a257a042 9950c74c
2017-04-26T21:45:45+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39331 TLS: Initial packet from [AF_INET]REMOTEIP:39331, sid=9d862b3b b60fa1be
2017-04-26T21:45:55+02:00 err openvpn(server_turris)[23054]: REMOTEIP:39147 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2017-04-26T21:45:55+02:00 err openvpn(server_turris)[23054]: REMOTEIP:39147 TLS Error: TLS handshake failed
2017-04-26T21:45:55+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39147 SIGUSR1[soft,tls-error] received, client-instance restarting
2017-04-26T21:46:05+02:00 err openvpn(server_turris)[23054]: REMOTEIP:39170 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2017-04-26T21:46:05+02:00 err openvpn(server_turris)[23054]: REMOTEIP:39170 TLS Error: TLS handshake failed
2017-04-26T21:46:05+02:00 notice openvpn(server_turris)[23054]: REMOTEIP:39170 SIGUSR1[soft,tls-error] received, client-instance restarting
